The other day I saw a watch advertised as a watch for pilots that
includes an altimeter. While I have seen these before for mountain climbers this is the first I have seen targeted at pilots. My first question in seeing it was "Where is the Kollsman window?" I tried to find more data online but I can't seem to find one of these that can adjust. I assume they are all set to 29.92 but I am trying to figure out how useful this feature would be if it can't be adjusted for local conditions. |
![]() "es330td" wrote in message ... I am trying to figure out how useful this feature would be if it can't be adjusted for local conditions. I have worn one for several years now, but the altimeter has only limited usefulness. The first thing I noticed is that the altimeter does not read continuously. Probably to save battery life, it only updates occasionally. With several button pushes, you can "interrogate" it at will, but that is not much help when you are busy in (say) a landing pattern. The other problem, (as you have already guessed) is calibration. There is no way to set mine according to atmospheric pressure. Instead, you calibrate the reading to the "proper" altitude in exactly the same manner as you set your watch to the proper time. This is OK for local flights because I can just set if for field elevation before I take off, but not so useful for X-country flying. Vaughn |
es330td wrote:
The other day I saw a watch advertised as a watch for pilots that includes an altimeter. While I have seen these before for mountain climbers this is the first I have seen targeted at pilots. My first question in seeing it was "Where is the Kollsman window?" I tried to find more data online but I can't seem to find one of these that can adjust. I assume they are all set to 29.92 but I am trying to figure out how useful this feature would be if it can't be adjusted for local conditions. Yeah. No Kollsman window -- no problem. I use mine religiously. Mostly to keep an extra instrument to watch the cabin altitude on A320's that I fly over the Atlantic. It's kinda neat -- watching the cabin altitude on your wrist, and seeing it match to the highlighted altitude on the LCD. (Of course, this is all simulated. Not a real flight. But all them same). T |
![]() "es330td" wrote in message ... The other day I saw a watch advertised as a watch for pilots that includes an altimeter. While I have seen these before for mountain climbers this is the first I have seen targeted at pilots. My first question in seeing it was "Where is the Kollsman window?" I tried to find more data online but I can't seem to find one of these that can adjust. I assume they are all set to 29.92 but I am trying to figure out how useful this feature would be if it can't be adjusted for local conditions. Here is a GPS watch that has altimeter, speed and a lot more. http://www.aim-sportline.com/mytach/index_eng.htm |
On Mar 12, 10:15*am, "Darkwing" theducksmail"AT"yahoo.com wrote:
"es330td" wrote in message ... The other day I saw a watch advertised as a watch for pilots that includes an altimeter. *While I have seen these before for mountain climbers this is the first I have seen targeted at pilots. *My first question in seeing it was "Where is the Kollsman window?" *I tried to find more data online but I can't seem to find one of these that can adjust. *I assume they are all set to 29.92 but I am trying to figure out how useful this feature would be if it can't be adjusted for local conditions. Here is a GPS watch that has altimeter, speed and a lot more. http://www.aim-sportline.com/mytach/index_eng.htm Pilots can't use this. GPS altitude (while theoretically correct) is not the same as pressure altitude because pressure does not vary in a linear fashion with altitude; if it did, flight levels above 29,920 feet would require liquid oxygen on board for the engines. |
![]() "es330td" wrote in message ... On Mar 12, 10:15 am, "Darkwing" theducksmail"AT"yahoo.com wrote: "es330td" wrote in message ... The other day I saw a watch advertised as a watch for pilots that includes an altimeter. While I have seen these before for mountain climbers this is the first I have seen targeted at pilots. My first question in seeing it was "Where is the Kollsman window?" I tried to find more data online but I can't seem to find one of these that can adjust. I assume they are all set to 29.92 but I am trying to figure out how useful this feature would be if it can't be adjusted for local conditions. Here is a GPS watch that has altimeter, speed and a lot more. http://www.aim-sportline.com/mytach/index_eng.htm Pilots can't use this. GPS altitude (while theoretically correct) is not the same as pressure altitude because pressure does not vary in a linear fashion with altitude; if it did, flight levels above 29,920 feet would require liquid oxygen on board for the engines. Looks to me that you have a new product to invent! |
On Mar 12, 2:00*pm, es330td wrote:
On Mar 12, 10:15*am, "Darkwing" theducksmail"AT"yahoo.com wrote: "es330td" wrote in message ... The other day I saw a watch advertised as a watch for pilots that includes an altimeter. *While I have seen these before for mountain climbers this is the first I have seen targeted at pilots. *My first question in seeing it was "Where is the Kollsman window?" *I tried to find more data online but I can't seem to find one of these that can adjust. *I assume they are all set to 29.92 but I am trying to figure out how useful this feature would be if it can't be adjusted for local conditions. Here is a GPS watch that has altimeter, speed and a lot more. http://www.aim-sportline.com/mytach/index_eng.htm Pilots can't use this. *GPS altitude (while theoretically correct) is not the same as pressure altitude because pressure does not vary in a linear fashion with altitude; if it did, flight levels above 29,920 feet would require liquid oxygen on board for the engines. You're correct that GPS altitude will differ from pressure-based altitude, but it's not because of the non-linearity. That's taken into account when the altimeter converts from pressure to the equivalent altitude. The difference is that the pressure-based altimeter assumes the standard atmosphere model (and above the transition altitude also assumes a fixed sea-level pressure of 29.93 "Hg). If the actual atmospheric conditions differ from the standard model then any pressure-based altimeter will differ from the actual value. Of course the GPS measurement also suffers from its own error sources and generally has greater random fluctuations - but it's not affected so directly by atmospheric variation from the standard model. But pressure-based altimeter watches are commonly available. I used to have a pretty cheap ($30) Casio with this function and I could calibrate it either based on a currently known altitude or by setting the sea-level pressure (i.e. the Kollsman window 29.92 setting when appropriate). It updated the reading every 6 seconds and worked well but I never used it for aviation other than for curiousity. |
I have a Suunto Vector altimeter watch, and though I usually just set
it to ground level before taking off, it also has a "sea level pressure mode" which is equivalent to setting the Kollsman window. Before that I had an Avocet altimeter watch; I don't really recall but I think it had a similar setting. If find it most useful for paragliding; I don't use it in the plane. -Dana On Wed, 11 Mar 2009 22:49:30 -0700 (PDT), es330td wrote: The other day I saw a watch advertised as a watch for pilots that includes an altimeter. While I have seen these before for mountain climbers this is the first I have seen targeted at pilots. My first question in seeing it was "Where is the Kollsman window?" I tried to find more data online but I can't seem to find one of these that can adjust. I assume they are all set to 29.92 but I am trying to figure out how useful this feature would be if it can't be adjusted for local conditions. -- In the 60's people took acid to make the world weird. Now the world is weird, people take prozac to make it normal. |
On Mar 13, 4:43 am, Dana M. Hague wrote:
Before that I had an Avocet altimeter watch; I don't really recall but I think it had a similar setting. If find it most useful for paragliding; I don't use it in the plane. And that's about how much I used any fancy watches I had. Most of these watches are just expensive ways to impress non-pilots (and they usually don't care) and they're so big and thick that they're forever in the way or catching on something. The one I wear now is a $30 Timex "turn and pull" analog watch that lets me set the alarm real quick and easy. No tiny numbers or a multitude of buttons and modes to get confused with when I want to set the thing, or reset when I want to sleep for another half hour. And it's not so ridiculously big. Dan |
What he said, Casio, years ago. I wore it flying and mountain hiking
several times, too. It was reasonably accurate to about 10,000', then it started running lower than either the aircraft altimeter or the trail elevation signs said. Its barometric setting was by setting it to a known altitude. David Peter Rathmann wrote: On Mar 12, 2:00 pm, es330td wrote: But pressure-based altimeter watches are commonly available. I used to have a pretty cheap ($30) Casio with this function and I could calibrate it either based on a currently known altitude or by setting the sea-level pressure (i.e. the Kollsman window 29.92 setting when appropriate). It updated the reading every 6 seconds and worked well but I never used it for aviation other than for curiousity. |
Tag Heuer Aquaracer Quartz Men's Watch #waf1110.ft8009 - Fake Watch | [email protected] | Piloting | 0 | April 24th 08 10:06 AM |
Best Pilot Watch for $100 | Jay Honeck | Piloting | 45 | December 1st 07 10:30 PM |
Best Pilot Watch for $100? | Jay Honeck | Piloting | 28 | November 18th 07 08:51 AM |
Pilot watch not a real EB6 | BillJosephson | Piloting | 12 | March 18th 07 04:16 AM |
AOPA ZULU Time Pilot watch on eBay | Cecil E. Chapman | Products | 0 | October 13th 03 06:40 PM |
