#31
Bill,
If the initial rope tension is too low, the pilot should just release and not stagger around for long periods. Elevator authority should not be a problem when rope tension is low. From experience, I have never seen uncontrollable pitch ups on slow tows, only on fast ones. |
#32
On Thu, 19 Mar 2009 15:41:38 -0700, bildan wrote:
As the glider leaves the ground, the inertial rotation will begin but if the acceleration continues, the elevator effectiveness will also continue to increase with the square of the airspeed. Rotation can't happen instantly because the glider has mass and rotational inertia. In fact, the pilot has to start backing off the down elevator to allow the glider to rotate into the climb. That depends on what you're flying and how lead footed the winch driver is. I have an early (H.201) Std Libelle. I remember having a fairly 'vigorous' launch on a calm day from a V8 Supacat. I started with full forward trim as usual but possibly with not quite as much additional forward pressure as I normally use. The glider started to pitch up shortly after lifting off. Applying full down elevator maintained but didn't reduce the pitch-up rate until the full climb attitude, when rotation eased off and I was able to ease back to no stick pressure. This started to happen around 50 kts, the rotation rate was acceptable and the full climb angle post rotation was steep but not excessive. I had around 65 kts when rotation had stopped. My Std. Libelle normally lifts off both wheels almost simultaneously, even with full forward trim plus a bit of forward pressure. I usually have no problems holding or reducing that attitude as the speed builds up past 50 kts. However, on this occasion I want to emphasize that I went fairly briskly to full forward stick as rotation started and REMAINED THERE through rotation into full climb. At that attitude when I eased back to the trimmed position as the rotation slowed. If the acceleration had been higher I could have been in real trouble. Now, I always ask to be launched "like a Junior but 10 kts slower", which gives a nice lift-off and constant attitude until 50 kts and rising is on the clock. At that point a reduction in forward pressure gives a nice, controllable rotation into full climb. Easing the stick back as the rotation slows gives a nice full climb attitude at just over 60 kts. Vwinch is 65. Caveat: I've never winched an H.201B, which has a bigger tail than the H.201, so its winch behavior may be different. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#33
On Mar 19, 5:49*pm, Martin Gregorie
wrote: On Thu, 19 Mar 2009 15:41:38 -0700, bildan wrote: As the glider leaves the ground, the inertial rotation will begin but if the acceleration continues, the elevator effectiveness will also continue to increase with the square of the airspeed. *Rotation can't happen instantly because the glider has mass and rotational inertia. In fact, the pilot has to start backing off the down elevator to allow the glider to rotate into the climb. That depends on what you're flying and how lead footed the winch driver is. I have an early (H.201) Std Libelle. I remember having a fairly 'vigorous' launch on a calm day from a V8 Supacat. I started with full forward trim as usual but possibly with not quite as much additional forward pressure as I normally use. The glider started to pitch up shortly after lifting off. Applying full down elevator maintained but didn't reduce the pitch-up rate until the full climb attitude, when rotation eased off and I was able to ease back to no stick pressure. This started to happen around 50 kts, the rotation rate was acceptable and the full climb angle post rotation was steep but not excessive. I had around 65 kts when rotation had stopped. My Std. Libelle normally lifts off both wheels almost simultaneously, even with full forward trim plus a bit of forward pressure. I usually have no problems holding or reducing that attitude as the speed builds up past 50 kts. However, on this occasion I want to emphasize that I went fairly briskly to full forward stick as rotation started and REMAINED THERE through rotation into full climb. At that attitude when I eased back to the trimmed position as the rotation slowed. If the acceleration had been higher I could have been in real trouble. Now, I always ask to be launched "like a Junior but 10 kts slower", which gives a nice lift-off and constant attitude until 50 kts and rising is on the clock. At that point a reduction in forward pressure gives a nice, controllable rotation into full climb. Easing the stick back as the rotation slows gives a nice full climb attitude at just over 60 kts. Vwinch is 65. Caveat: I've never winched an H.201B, which has a bigger tail than the H.201, so its winch behavior may be different. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Martin, your post has all the ingredients I'm talking about. If you know your glider, you'll know if it will require down elevator and roughly how much. It's probably a good idea to start the roll with full down elevator to eliminate 'reaction time'. The problem occurs when the nose is allowed to rise too far and the pilot then tries to correct the situation. This has been a hard fought discussion but I kept at it because there is a lot of good things in it that winch novices need to think about. |
#34
On Mar 19, 5:04*pm, wrote:
Bill, If the initial rope tension is too low, the pilot should just release and not stagger around for long periods. Elevator authority should not be a problem when rope tension is low. From experience, I have never seen uncontrollable pitch ups on slow tows, only on fast ones. Right, and you DON'T start the rotation. If you do, that's when the problem starts and you run out of elevator control. |
#35
As I have tried to explain to Bill on numerous occasions, and on various
forums, the uncontrollable over-rotation you get from an over-powered winch launch is caused by the pull line to the belly hook being below the glider's centre of gravity and centre of pressure. This causes a rotation for mechanical rather than aerodynamic control reasons. This is why high winged gliders, such as the K6 and K8 are most at risk. If you get such a launch, even holding the stick hard forward all the time from 'take up slack' will not prevent the over-rotation, although it might slightly reduce your chances of instant death from a flick spin. Such events can be easily avoided by by controlling the winch so that the ground run acceleration is not more than about 1.0g (or less for the types mentioned above). This will still get you airborne and climbing within about 3-4 seconds, which most pilots find quite fast enough! It will also make very little difference to the achieved height. Derek Copeland At 22:41 19 March 2009, bildan wrote: As the glider leaves the ground, the inertial rotation will begin but if the acceleration continues, the elevator effectiveness will also continue to increase with the square of the airspeed. Rotation can't happen instantly because the glider has mass and rotational inertia. In fact, the pilot has to start backing off the down elevator to allow the glider to rotate into the climb. Now, contrast this with a slow acceleration. The glider staggers into the air and the nose-up inertial couple starts the rotation but the low speed and acceleration doesn't provide adequate control. The nose rises as the pilot struggles to control it with inadequate airspeed..... I've collected stories on this type of accident for decades and they ALWAYS happen with slow acceleration. |
#36
Sorry, I forgot to add that there are a few types where holding the stick
hard forward to contain an over-rotation is not a good idea, as you can stall the elevator/tailplane and make the situation even worse! These are mostly gliders with all-flying tailplanes, such as the Standard Cirrus. Again, all these unpleasantries can be avoided by just a slight moderation of the ground run acceleration, if you have a powerful winch. Derek C At 13:00 20 March 2009, Derek Copeland wrote: As I have tried to explain to Bill on numerous occasions, and on various forums, the uncontrollable over-rotation you get from an over-powered winch launch is caused by the pull line to the belly hook being below the glider's centre of gravity and centre of pressure. This causes a rotation for mechanical rather than aerodynamic control reasons. This is why high winged gliders, such as the K6 and K8 are most at risk. If you get such a launch, even holding the stick hard forward all the time from 'take up slack' will not prevent the over-rotation, although it might slightly reduce your chances of instant death from a flick spin. Such events can be easily avoided by by controlling the winch so that the ground run acceleration is not more than about 1.0g (or less for the types mentioned above). This will still get you airborne and climbing within about 3-4 seconds, which most pilots find quite fast enough! It will also make very little difference to the achieved height. Derek Copeland |
#37
Dick Johnson said in 2001:
In my opinion it is reasonably safe to ground launch a Phoebus A,B, or C sailplane as long as the initial acceleration is not too great. The all-moving horizontal tail on these sailplanes have more propensity to stall than those of sailplanes equipped with conventional fixed stabilizer/elevator configurations. When the all-moving stabilizer stalls during an excessively high acceleration take-off, pushing the control stick forward usually just puts the horizontal tail deeper into its stall, and therefore it is even more ineffective. At low airspeeds, the nose up couple produced by a strong tow rope pull and a high sailplane CG location can easily overpower the aerodynamic nose down capability of an elevator control system, and that leads to an uncontrollable nose up pitch during take-off. In a number of instances, this has lead to the sailplane stalling and crashing; usually with fatal results. The Phoebus is not the only sailplane that is susceptible to this fault, so be careful of high initial tow acceleration - auto as well as winch. I have been there! Dick Johnson |
#38
On Mar 20, 4:52*pm, wrote:
Dick Johnson said in 2001: In my opinion it is reasonably safe to ground launch a Phoebus A,B, or C sailplane as long as the initial acceleration is not too great. The all-moving horizontal tail on these sailplanes have more propensity to stall than those of sailplanes equipped with conventional fixed stabilizer/elevator configurations. When the all-moving stabilizer stalls during an excessively high acceleration take-off, pushing the control stick forward usually just puts the horizontal tail deeper into its stall, and therefore it is even more ineffective. * At low airspeeds, the nose up couple produced by a strong tow rope pull and a high sailplane CG location can easily overpower the aerodynamic nose down capability of an elevator control system, and that leads to an uncontrollable nose up pitch during take-off. In a number of instances, this has lead to the sailplane stalling and crashing; usually with fatal results. The Phoebus is not the only sailplane that is susceptible to this fault, so be careful of high initial tow acceleration - auto as well as winch. I have been there! * Dick Johnson Careful, Dick Johnson was a very old personal friend of mine. I discussed this with him on many occasions and his opinion in no way differed from mine. As I have said many times, There are a very few gliders with control difficulties and the Phoenix is one of them. Most of the other problem glider were of that generation or earlier. There are very few of them left. Just because a few gliders have a problem is no reason to operate as if they all do. |
#39
On Mar 20, 7:00*am, Derek Copeland wrote:
As I have tried to explain to Bill on numerous occasions, and on various forums, the uncontrollable over-rotation you get from an over-powered winch launch is caused by the pull line to the belly hook being below the glider's centre of gravity and centre of pressure. This causes a rotation for mechanical rather than aerodynamic control reasons. This is why high winged gliders, such as the K6 and K8 are most at risk. If you get such a launch, even holding the stick hard forward all the time from 'take up slack' will not prevent the over-rotation, although it might slightly reduce your chances of instant death from a flick spin. Such events can be easily avoided by by controlling the winch so that the ground run acceleration is not more than about 1.0g (or less for the types mentioned above). This will still get you airborne and climbing within about 3-4 seconds, which most pilots find quite fast enough! It will also make very little difference to the achieved height. Derek Copeland At 22:41 19 March 2009, bildan wrote: As the glider leaves the ground, the inertial rotation will begin but if the acceleration continues, the elevator effectiveness will also continue to increase with the square of the airspeed. *Rotation can't happen instantly because the glider has mass and rotational inertia. In fact, the pilot has to start backing off the down elevator to allow the glider to rotate into the climb. Now, contrast this with a slow acceleration. *The glider staggers into the air and the nose-up inertial couple starts the rotation but the low speed and acceleration doesn't provide adequate control. *The nose rises as the pilot struggles to control it with inadequate airspeed..... I've collected stories on this type of accident for decades and they ALWAYS happen with slow acceleration. And just as often I've challenged you to produce ANY engineering data to support your mere opinion. You have not and I believe you cannot. |
#40
Bill,
Aside from your rude remarks and your inability to admit your mistakes on several points (an automatic transmissions do not operate like a cruise control), etc.....I have only posted that an article on winch safety came out and was making people aware of it, nothing more. And I am not the author either. However, the accident stats and their carefully determined causes are what they are. So are the real world experiences in a variety of gliders described in this thread suffering from too strong initial launch acceleration. And they were not only with types of planes that you think it can only happen to. Dick Johnson's own words: "...be careful of high initial tow acceleration..." Now let me ask you a question for once: What rope tension, measured in g do you recommend for the first seconds of the launch? Or do you advocate RPM controlled winches over tension controlled ones? |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Safety of winch launch vrs. aero tow? | Gary Boggs | Soaring | 172 | November 13th 03 06:59 PM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
