motorgliders as towplanes
Old March 21st 09, 03:19 PM posted to rec.aviation.soaring
Bob Kuykendall
Default Metric Hardware ( was Aerodynamics of Towing)
On Mar 20, 8:17*pm, Uncle Fuzzy wrote:
...My favorite example was an exhaust stud on a 1998 Olds
Intrigue. *Engine side - SAE exhaust flange side - metric.
SAE and metric threads on the same stud? Yup, that's odd all right.
My favorite example of transitional hardware is the Volvo 240 series.
You'd find SAE hardware on anything it inherited from the 140 series
(most bodywork, a lot of the driveline) and metric on anything
introduced new with the 240 (B21 or later engine, M41 or M46
transmission, MacPhereson strut front suspension).
Thanks, Bob K.
  #252
Old March 21st 09, 04:48 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
Default aerodynamics of gliding
On Fri, 20 Mar 2009 14:30:04 +0000, Jim Beckman wrote:
But it *does* make it the right answer to the written test when that
test is given by that same authority. For the test, concentrate not on
what is necessarily true, but on what the FAA wants for an answer.
After the written is out of the way, just learn to fly the aircraft.
Yes, and I learnt it as the answer to that Bronze question. It just
annoys me that official publications should enshrine myths as some sort
of truth.
Its no better than introductory texts showing packets of air dividing at
the LE of a ring and meeting up again at the TE, when a photo taken in a
wind tunnel shows clearly that doesn't happen. Far better to publish the
photo than a bogus diagram.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #253
Old March 21st 09, 07:23 PM posted to rec.aviation.soaring
The Real Doctor
On 21 Mar, 13:30, Jim Beckman wrote:
*Are there any British
gliders left that are old enough to have used Whitworth hardware?
The UK car industry switched over to UNF/UNC in the early sixties, but
I wouldn'r be suprised to find Whitworth/BSF in anything Slingsby made
until the late 60's. They were masters of improvisation ... for many
years Slingsby glider main wheels were surplus Spitfire tailwheels.
I have to keep a full set of imperial tools for my Herald and a full
set of metric ones for my DS. I still have a Whitworth set from when I
had a 1959 Morris Minor but it doesn;t get much use. The Micra just
never needs mending, so nut sizes are irrelevant ...
Ian
  #254
Old March 21st 09, 07:25 PM posted to rec.aviation.soaring
The Real Doctor
My friendly local tool shop used to sell UNF/UNC nuts and bolts ...
with metric heads. Confused the hell out of me when I had to replace
some of them years later.
Ian
  #255
Old March 21st 09, 07:28 PM posted to rec.aviation.soaring
The Real Doctor
On 21 Mar, 16:48, Martin Gregorie
Oh, that one drives me mad. Not only does it not happen ... there is
no conceivable reason why it should happen. And yet many many websites
and books cite it as fact. Grrrrrrrrrrrrrrrrrr.
Incidentally, if you don't have a copy of "An Album of Fluid Motion"
by Milton Van Dyke, get it. You'll love it. Every gliding club should
have one.
Ian
  #256
Old March 21st 09, 08:01 PM posted to rec.aviation.soaring
On Sat, 21 Mar 2009 12:28:59 -0700, The Real Doctor wrote:
Incidentally, if you don't have a copy of "An Album of Fluid Motion" by
Milton Van Dyke, get it. You'll love it. Every gliding club should have
one.
Another recommendation:
http://www.av8n.com/how/ gives a good description of how an aeroplane
works. A lot of it is similar to "Stick and Rudder", so its written for
pilots rather than aircraft designers. However, section 3 has excellent
descriptions and diagrams showing how a wing works. It was recommended to
me by a professional aerodynamicist who is a model designer and has flown
gliders.
org |
  #257
Old March 21st 09, 08:18 PM posted to rec.aviation.soaring
one.
Here's a link to animated visualizations of the flow past a wing:
http://www.av8n.com/irro/ - click the flag of your favored language to
see the visualizations.
org |
  #258
Old March 21st 09, 11:01 PM posted to rec.aviation.soaring
The Real Doctor
On 21 Mar, 20:18, Martin Gregorie
one.
Here's a link to animated visualizations of the flow past a wing:http://www.av8n.com/irro/- click the flag of your favored language to
I've never really liked that Joukowski transform stuff. The arbitrary
definition of circulation worries me, and anyway no real wing behaves
anything like that. It's a fair way of visualising the flow, roughly,
but I prefer to jump straight into circulation theory and model my
wings as vortices.
Ian
  #259
Old March 21st 09, 11:35 PM posted to rec.aviation.soaring
Tech Support
UF
Don't bitch.The P-51, with Merlin engine, had one set of tools for
engine and another set for airplane. That was back in 40's (WWII) )
Crew chief carried two bags when he went to work on bird.
Have a nice Day.
Big John
On Fri, 20 Mar 2009 20:17:15 -0700 (PDT), Uncle Fuzzy
On Mar 19, 6:08 pm, Doug Hoffman wrote:
I just wish the US would perform its conversion to metric units for
*everything*. *The sooner the better. *But that job is being handled by
our highly efficient government. *Don't hold your breath. *:-)
Kind of a hijack, but what I wish is that aircraft hardware
manufacturers would get their crap together and produce a coherent
metric equivalent of the AN system of common aircraft hardware.
The magic of the AN hardware system is not that they offer any
particularly high strength (they don't; for the most part AN bolts are
equivalent to Grade 5 hardware store bolts) or any particularly high
precision (again, they're about the same as the bolts at Ace or True
Value). The magic is that AN bolts have just enough thread for a nut
and somewhere between 0" and about 0.125" of washers, and that they
come in length increments of 0.125". Those two elements let you create
a nice, tidy bolted joint of virtually any practical grip length, and
not have the threaded portion of the bolt loaded in shear, and not
have a bunch of threads hanging out of the nut. Furthermore, common AN
hardware is very attractively priced, for the most part you can buy
them from any of several aircraft parts outlets at the same or even
lower prices as Grade 5 bolts at a mom&pop hardware store.
By contrast, metric aircraft hardware has no coherent system of
markings, thread lengths, and grip lengths. It averages twice or
thrice the cost of AN hardware when you can find it, and is available
from only a few outlets. When you need a replacement bolt for your
European aircraft, you have virtually no choice but to order it
directly from the manufacturer at huge markups and with huge shipping
charges.
I like the metric system, and I like metric hardware. I appreciate
that even American cars are, by and large, assembled with metric nuts
and bolts these days. But given the choice between about $500 worth of
AN hardware per aircraft and twice or thrice that in metric nuts and
bolts that offer no greater utility, hmmm, I think I'll go with the
less expensive option.
End rant.
Hi Bob,
Yes. *There may be some niche areas like aircraft hardware that would at
least require legacy support for a period of years. *Makes me wonder
what Boeing/Cessna and others are doing now and plan to do in the future
in that respect.
Regards,
-Doug
Btw, American designed cars and trucks do more than just assemble with
metric fasteners. *Nominal dimensions are typically, e.g., 100 mm for a
bracket width instead of 4.0". *We call that "hard metric" design. *Some
user interface items like wheel lug nuts may still be SAE.- Hide quoted text -
- Show quoted text -
While we're 'Ranting'.... Bob, that would be nice, wouldn't it? It
took me 2 tries to get the right bolt from Grob when I went throught
my control system a few years ago.
DON'T get me started on US auto makers. I have two Dodge Trucks. I
HATE the fact that evey time I get under one to work on it, I need to
take BOTH metric and SAE tools. Pick a STANDARD! My favorite example
was an exhaust stud on a 1998 Olds Intrigue. Engine side - SAE
Rant off.
I feel better now.
  #260
Old March 22nd 09, 02:12 AM posted to rec.aviation.soaring
The Real Doctor
The Citroen 2CV came with two (I think, may have been three) spanners
which allowed you to do anything up to and including a full engine
rebuild.
Ian
Seeking towplanes for Region 9 [email protected] Soaring 0 May 17th 06 12:03 AM
US:Restricted Towplanes Judy Ruprecht Soaring 8 November 5th 04 11:27 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Take-upReels on Towplanes Nyal Williams Soaring 9 April 21st 04 12:39 AM
Helicopters and Towplanes Burt Compton Soaring 6 September 11th 03 05:21 PM
