Winch Launch Safety Study
Old March 22nd 09, 03:29 AM posted to rec.aviation.soaring
Default Winch Launch Safety Study
Bill,
I also wonder if you have considered gusts and turbulence on elevator
authority. The winch RPM speed is not affected by this and will
continue accelerating if that 's what you want, when gusts or
turbulence affect the elevator. Even Tension controlled winches may
not be able to reduce tension quickly enough if this happens. That's
why the initial tension should not be too high to begin with.
I would like to hear your description of how winch settings should be
with some metrics. I know you advocate high initial tow acceleration
launches. But that doesn't really tell me the specifics.
  #42
Old March 22nd 09, 10:00 AM posted to rec.aviation.soaring
Del C[_2_]
As far I can find out, Bill has only done a few hundred launches on rather
underpowered and overgeared old US Gehrlein type winches, plus a couple of
launches on his 'US Superwinch' in a Grob G103 before the drum was
crushed by the synthetic cable, something else I warned him about! The
G103, being low winged and quite heavy, is not prone to over-rotation
accidents anyway, as identified in the Aerokourier report.
I have personally witnessed several vastly overpowered launches involving
K6 and K8 gliders, and have sat through 3 myself, in a K8, a Standard
Cirrus and a DG101. They really do go into a near vertical climb, often
despite the best efforts of the pilot to control the rotation.
Particularly in the DG case I was lucky not to join the accidents
statistics, as I slipped back up the seat as the glider rotated and was
only able to keep the stick just off the backstop with my fingertips.
Just about everyone in Europe, where we we have a lot of winch launching
experience, disagrees with Bill's views. As to engineering data, I have
seen none whatsoever from Bill, whereas I have supplied quite a lot plus
illustrative videos on the Yahoo Winch Design Group.
If you know the position of the belly hook and the centres of gravity and
pressure in a given glider, it should be possible to calculate the
rotational couple for various levels of pull, and at what level it will
overpower the elevator.
Derek Copeland
At 01:24 22 March 2009, bildan wrote:
On Mar 20, 7:00=A0am, Derek Copeland wrote:
As I have tried to explain to Bill on numerous occasions, and on
various
forums, the uncontrollable over-rotation you get from an over-powered
winch launch is caused by the pull line to the belly hook being below
glider's centre of gravity and centre of pressure. This causes a
rotation
for mechanical rather than aerodynamic control reasons. This is why
high
winged gliders, such as the K6 and K8 are most at risk.
If you get such a launch, even holding the stick hard forward all the
tim=
e
from 'take up slack' will not prevent the over-rotation, although it
might slightly reduce your chances of instant death from a flick spin.
Such events can be easily avoided by by controlling the winch so that
ground run acceleration is not more than about 1.0g (or less for the
type=
s
mentioned above). This will still get you airborne and climbing within
about 3-4 seconds, which most pilots find quite fast enough! It will
also
make very little difference to the achieved height.
Derek Copeland
At 22:41 19 March 2009, bildan wrote:
As the glider leaves the ground, the inertial rotation will begin but
if the acceleration continues, the elevator effectiveness will also
continue to increase with the square of the airspeed. =A0Rotation
can't
happen instantly because the glider has mass and rotational inertia.
In fact, the pilot has to start backing off the down elevator to
allow
the glider to rotate into the climb.
Now, contrast this with a slow acceleration. =A0The glider staggers
into
the air and the nose-up inertial couple starts the rotation but the
low speed and acceleration doesn't provide adequate control. =A0The
nose
rises as the pilot struggles to control it with inadequate
airspeed.....
I've collected stories on this type of accident for decades and they
ALWAYS happen with slow acceleration.
And just as often I've challenged you to produce ANY engineering data
to support your mere opinion. You have not and I believe you cannot.
  #43
Old March 22nd 09, 06:22 PM posted to rec.aviation.soaring
Willy VINKEN[_2_]
Can anyone tell me more about how a Standard Cirrus handles when
winched?
We use a GMC V8 325 HP petrol engine with standard automatic gearbox.
No problems until now with K8, K6 and Astir Jeans.
I plan to fit my Cirrus with a CG hook. Cirruses imported to France
where all equipped with a nose hook.
Willy VINKEN OO-ZNY
Derek Copeland
  #44
Old March 22nd 09, 07:30 PM posted to rec.aviation.soaring
Del C[_2_]
winched?
Willy VINKEN OO-ZNY
As long as you don't get an overpowered winch launch it's fine. The
ailerons are slightly ineffective at low speed, so try to choose a fit
looking wing runner if you can. If it's one of the all-flying tailplane
versions, just hold the stick about two-thirds forward and leave it there
until you are established in the full climb. Just concentrate on keeping
the wings level and the glider running straight during the ground run and
rotation. If there is any chance of dropping a wingtip onto the ground,
pull off immediately. It will naturally rotate quite enthusiatically after
lift off, but avoid ramming the stick hard forward to contain this, as this
is what can stall the tailplane.
Don't try to winch launch on a nose hook, because it will give a very
poor launch, and there is no back release mechanism on a the type of nose
hook fitted to this type.
The Standard Cirrus doesn't have the best positioned shoulder strap
mountings, so make sure you do your safety harness up as tightly as
possible to avoid slipping back up the seat, due to the acceleration.
Derek Copeland
  #45
Old March 23rd 09, 11:15 AM posted to rec.aviation.soaring
John Vella Grech
winched?
Willy VINKEN OO-ZNY
We operated a Standard Cirrus for 3 years on the winch and found no
handling problems provided the elevator was moved progressively. The AMT
is quite powerfull and has been known to stall on full down deflection ,
but we never experienced it .
rather
of
involving
launching
have
plus
and
Derek Copeland
  #46
Old March 24th 09, 06:45 AM posted to rec.aviation.soaring
Gavin Short[_2_]
winched?
Willy VINKEN OO-ZNY
there
and
after
this
nose
Derek Copeland
I concur with Derek. I brace my right arm against my thigh and hold the
stick part way down so any bumps on the ground run will have much less
effect. (I learnt on a UK hill site). Mine has a all flying tail and I do
what Derek describes. I don't need to adjust the position of the stick
(in terms of pitch) until well into the climb and that is just fine
tuning.
Yes, tighten the straps before launch and press firmly back on the pedals
before launch to compress parachute/back rest arrangements (I have 50mm of
dynafoam behind me) to ensure you don't slip back on launch.
No problems with a V8 power Tost winch.
Fitting winglets last season made the ailerons more responsive at low
speed.
Read the flight manual about launching (which basically says what Derek
and I have). Also look at the Standard Cirrus website
http://www.standardcirrus.org
and also look at the Std Cirrus Forum. There is a search facility so look
for 'launch'.
The Std Cirrus hook is well protected by 2 parallel metal strips.
Practice getting the cable on yourself so you can describe to helpers how
they should fit the cable. They tend to get a bit confused because they
can't see the hook like K8s and Astirs etc.
As my first CFI says: Its a glider - go any fly it as you would a glider!
Gavin
Std Cirrus, CNN now G-SCNN, #173
LSV Viersen, Keiheuvel, Belgium
  #47
Old March 24th 09, 12:45 PM posted to rec.aviation.soaring
MaD
In addition to what Gavin and Derek said I think it is also important
to know that the location of your Centre of Gravity has a significant
influence on the winch launch characterisitics of the Standard Cirrus.
Make sure it is no-where near the rear end of the allowable range. I
can't remember the figures but recall having it close to mid-range and
always felt comfortable.
To prevent sliding into the baggage compartment I always took the
pedals right back and trapped myself between pedals and rear canopy
rim during winch launch.
Marcel Dünner
  #48
Old March 24th 09, 01:45 PM posted to rec.aviation.soaring
Derek Copeland[_2_]
Some of you might be interested in the latest British Gliding Association
(BGA) Winch Launching Safety Campaign, which includes some frightening
simulations of what can go wrong if you approach winching in a too
cavalier manner. Taking off with the stick hard back, possibly as a result
of sliding back up the seat, is one of them, and has been responsible for
several fatal accidents in the UK. See:
http://www.gliding.co.uk/bgainfo/saf...nch-safety.htm
Derek Copeland
Marcel D=FCnner
  #49
Old March 24th 09, 04:17 PM posted to rec.aviation.soaring
ucsdcpc
...... and do the quiz .....
chris
Derek Copeland
Marcel D=FCnner
  #50
Old March 24th 09, 04:18 PM posted to rec.aviation.soaring
bildan
On Mar 21, 9:00*pm, wrote:
Bill,
Aside from your rude remarks and your inability to admit your mistakes
on several points (an automatic transmissions do not operate like a
cruise control), etc.....
I didn't say anything remotely like that. I said they ASSIST the
driver in maintaining speed by increasing torque multipication when
climbing hills.
Now let me ask you a question for once: What rope tension, measured in
g do you recommend for the first seconds of the launch? Or do you
advocate RPM controlled winches over tension controlled ones?
I advocate tension controlled winches and the tension should be the
maximum safe value.
Pay out winch launch to 2500ft agl.. WAVEGURU Soaring 8 June 5th 07 07:06 AM
Winch Launch Videos Mike Schumann Soaring 2 January 19th 06 11:27 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Safety of winch launch vrs. aero tow? Gary Boggs Soaring 172 November 13th 03 06:59 PM
Winch launch M B Soaring 0 October 30th 03 07:33 PM
