A little off topic
Old March 30th 09, 08:25 PM posted to rec.aviation.soaring
vaughn
Default A little off topic
"Andy" wrote in message
Interesting references - thanks! This was another case where my
natural procrastination paid off. The air line beween my compressor
and the ceiling mounted hose reel is a piece of standard air hose. I
had been meaning to tidy it up with a neatly installed hard line for
years and had been thinking of using PVC. I'll spend the next
procrastination phase considering copper.
If your air hose is big enough to support your flow rate, just use some PVC
pipe to make a neat conduit for it. It will pretty things up, if properly
installed it will get rid of your low spots, and it will be perfectly safe.
Vaughn
Old March 30th 09, 08:42 PM posted to rec.aviation.soaring
On Mar 30, 2:42*pm, Andy wrote:
On Mar 29, 8:45*am, "bumper" wrote:
I know it's often done, but you may want to avoid using PVC or similar pipe
for compressed air, especially if it's exposed above ground. Do a Google
search on compressed air, PVC pipe accidents or see:
Interesting references - thanks! *This was another case where my
natural procrastination paid off. *The *air line beween my compressor
and the ceiling mounted hose reel is a piece of standard air hose. *I
years and had been thinking of using PVC. *I'll spend the next
Andy
One benefit of copper is it becomes a natural cooling coil to help get
rid of moisture. We have 100 ft in an array across top of shop ceiling
and drip leg for condensate.
No water in our air.
PVC has proven over time to be a time bomb unless at pretty low
pressures.
UH
Off-topic, but in need of help Alan Erskine Aviation Photos 20 January 5th 07 06:21 AM
Off-topic, but in need of help dennis Aviation Photos 0 January 4th 07 10:40 PM
Almost on topic... Richard Lamb Home Built 22 January 30th 06 06:55 PM
off topic, just a little--maybe? L.D. Home Built 5 August 27th 05 04:56 PM
off topic Randall Robertson Simulators 0 January 2nd 04 01:29 PM
