#21
On Feb 18, 10:03*am, JJ Sinclair wrote:
With all the talk about computer generated panels, I would offer this. It is quite easy to redo an old fiberglass panel.............just grind the back of the panel down until its paper thin, then clamp a smooth surface to the front (I use a clean hunk of aluminum), then lay in 3 layers of medium cloth (92125) and after its cured, pop off the front piece and you have a clean, flat new panel to drill what and where you like. I use hole-saws in a drill press (drilling from the rear) Tidy up any minor depressions with bondo, prime and paint with flat-black spray can. The original panel mounting holes can be drilled out again and everything fits back in the cockpit with mininum hassle. Cheers, JJ Just a quick variation on this theme. I had a minor panel reconfigure job last week involving the relocation of some panel mount fuses and switches in order to take advantage of that space for a new transponder. I used JJ's approach with some minor modifications and it worked outstandingly well: - Used a piece of plywood instead of aluminum and covered it with duct tape as the release agent. - Filled from the back using Bondo impregnated with chopped glass as the filler (these were only dime-sized holes) - Upon removal, had a very smooth surface complete with "simulated glass weave" thanks to the pattern in the duct tape. - Quick surface coat of regular bondo folloed by flat black spray and ended up with a perfect repair. Saved me probably $200 for a new panel blank not to mention countless hours re-drilling all of the instrument holes. Thanks JJ |
On Apr 1, 2:42*pm, Papa3 wrote:
On Feb 18, 10:03*am, JJ Sinclair wrote: With all the talk about computer generated panels, I would offer this. It is quite easy to redo an old fiberglass panel.............just grind the back of the panel down until its paper thin, then clamp a smooth surface to the front (I use a clean hunk of aluminum), then lay in 3 layers of medium cloth (92125) and after its cured, pop off the front piece and you have a clean, flat new panel to drill what and where you like. I use hole-saws in a drill press (drilling from the rear) Tidy up any minor depressions with bondo, prime and paint with flat-black spray can. The original panel mounting holes can be drilled out again and everything fits back in the cockpit with mininum hassle. Cheers, JJ Just a quick variation on this theme. *I had a minor panel reconfigure job last week involving the relocation of some panel mount fuses and switches in order to take advantage of that space for a new transponder. * I used JJ's approach with some minor modifications and it worked outstandingly well: - *Used a piece of plywood instead of aluminum and covered it with duct tape as the release agent. - *Filled from the back using Bondo impregnated with chopped glass as the filler (these were only dime-sized holes) - *Upon removal, had a very smooth surface complete with "simulated glass weave" thanks to the pattern in the duct tape. - *Quick surface coat of regular bondo folloed by flat black spray and ended up with a perfect repair. Saved me probably $200 for a new panel blank not to mention countless hours re-drilling all of the instrument holes. Thanks JJ I do it JJ's way and have done probably 20 panels this way. Little cost, and you don't have to doall the stuff that's right all over again. I find satin Rustoleum give nice finish and seems to resist scuffs a little better than flat. UH |
| Thread Tools | |
| Display Modes | |
| PIK-20D Instrument panel | Solo | Soaring | 5 | February 15th 09 07:50 PM |
| HELP -designing new panel | freestone | Instrument Flight Rules | 4 | February 22nd 06 02:34 AM |
| IFR PANEL | Flyhighdave | Home Built | 4 | January 18th 05 05:24 AM |
| IFR PANEL | Flyhighdave | Home Built | 4 | January 17th 05 08:15 PM |
| 182 panel | Jim | Owning | 2 | August 2nd 03 10:06 PM |
