Any Ballistic Recovery Chute Users?
Old April 4th 09, 01:14 AM posted to rec.aviation.soaring
Ian
Default Any Ballistic Recovery Chute Users?
I would be very interested, for professional reasons, to hear from
anyone who has used a ballistic recovery chute in a glider.
Ian
Old April 4th 09, 02:00 AM posted to rec.aviation.soaring
Gregg Ballou
from
Ian
Only one I've heard of was the sparrowhawk that broke during
highspeed flight testing. I believe the ballistic chute
attachments failed and the pilot used a regular parachute.
Story was in Soaring sometime in the last couple of years.
Old April 4th 09, 02:23 AM posted to rec.aviation.soaring
Uncle Fuzzy
On Apr 3, 6:00*pm, Gregg Ballou wrote:
At 00:14 04 April 2009, Ian wrote:I would be very interested, for professional reasons, to hear
from
Ian
highspeed flight testing. * I believe the ballistic chute
attachments failed and the pilot used a regular parachute. *
August '08 article in Soaring magazine "Lord, if You're Up There" was
written about that incident. Also read
http://newsgroups.derkeiler.com/Arch.../msg00364.html
Old April 4th 09, 06:08 PM posted to rec.aviation.soaring
Mark Jardini
Apis Bee is sold with ballistic recovery as standard equipment. It has
a lower powered engine for German regulations than the Apis M. It is
available as an option on the M model. I have not heard of it being
used. I have not seen reference to the testing either....
Mark
Apis M 821AC
Old April 5th 09, 01:18 AM posted to rec.aviation.soaring
ventus2[_2_]
You may want to also contact Hanko Streifeneder who fitted the ballistic
chute to the Discus for purposes of testing and certification.
http://www.streifly.de/gesamtrettungssystem-e.htm
or their home page
http://www.streifly.de/home-e.htm
Old April 5th 09, 10:58 PM posted to rec.aviation.soaring
Jim Logajan
By "used" do you mean has one installed in their glider, or had to deploy
one due to an inflight emergency? I'm assuming the latter.
Old April 6th 09, 03:57 AM posted to rec.aviation.soaring
Mike Bamberg
There has been at least one installed in an HP-16:
http://www.soaridaho.com/Schreder/HP...S_in_HP-16.htm
Old April 6th 09, 04:27 AM posted to rec.aviation.soaring
Jim Logajan
deploy one due to an inflight emergency? I'm assuming the latter.
BRS, the most well known U.S. vendor of such chutes, keeps a list of "lives
saved" he
http://brsparachutes.com/files/Docum...ives-Saved.pdf
I see some hang gliders listed where BRS chutes were deployed, but I didn't
see any conventional gliders listed (but I'm not that familiar with model
names, so may have overlooked them.) My own search of the U.S. NTSB
database yielded two accidents where the aircraft had ballistic chutes
that proved of no value due to circumstances of the accidents - accident
IDs SEA04FA111 and DFW07LA006:
http://www.ntsb.gov/ntsb/brief.asp?e...25X00871&key=1
http://www.ntsb.gov/ntsb/brief.asp?e...30X01573&key=1
(The latter accident has already been mentioned.)
If one includes motorgliders, then all the Pipistrel and Lambada
motorgliders have ballistic chutes available either as standard equipment
or options, depending on the model:
http://www.mcp.com.au/pipistrel-usa/
http://www.urbanairusa.com/
Old April 6th 09, 12:51 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
Is it just me or is that BRS set up likely to fail on deployment?
I notice that the parachute risers pass round round the front of the
angle extrusion carrying the shoulder straps without, apparently, any
protection to stop the metal edge from cutting the webbing.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old April 6th 09, 02:13 PM posted to rec.aviation.soaring
The Real Doctor
Yup, the latter. Someone who has actually pressed the Big Red Button.
Ian
All Cessna Piston Singles to be Offered With Ballistic Recovery Parachutes Larry Dighera Piloting 8 October 12th 07 05:01 AM
Ballistic Rocket Chute FS Victor Bravo Home Built 12 April 25th 06 01:40 AM
Ballistic parachutes - RVs Ric Home Built 3 September 19th 04 04:09 AM
Ballistic parachutes with pushers anonymous coward Home Built 18 May 18th 04 11:28 PM
Ballistic chute saves 4 souls Bob Babcock Home Built 28 April 27th 04 09:29 PM
