Dipole Transponder Antennas
Old April 14th 09, 10:15 PM posted to rec.aviation.soaring
Tony Condon[_2_]
Default Dipole Transponder Antennas
Has anyone used a Dipole antenna on their transponder? I understand that
the dipole gives better coverage above where the "standard" antennas
usually only project down and to the sides. Aircraft Spruce carries
dipoles, they are a little spendy, but might be worth it. Any experience
out there?
-Tony Condon
Cherokee II N373Y
Old April 14th 09, 10:36 PM posted to rec.aviation.soaring
jcarlyle
There are a number of people in this group who used dipole antennas.
I've got the L2 model from Advanced Aircraft Electronics in my ASW-19,
it was $99 if I remember right.
Because I have a fiberglass tail boom, all I had to do was glue the
dipole to the supplied strip of balsa, then glue the dipole into the
tail boom in a vertical position. No need for a ground plane at all,
and as you point out it radiates both upwards and downwards.
It seems to work very well, but I couldn't tell you just how much
better it performs than a monopole under the same circumstances. For
me its biggest advantage was the ease of installation.
-John
out there?
-Tony Condon
Cherokee II N373Y
Old April 14th 09, 11:41 PM posted to rec.aviation.soaring
Bob Backer
+1
Works great, easy to install. W & W has them too.
-John
out there?
-Tony Condon
Cherokee II N373Y
Old April 15th 09, 12:00 AM posted to rec.aviation.soaring
Brian Bange[_2_]
I had the same experience with this antenna. In your wooden
ship this is just the ticket. I bought mine from Tim at Wings and
Wheels. Works great and is super easy to install.
Brian
antennas.
ASW-19,
all,
much
circumstances. For
-John
understand that
"standard" antennas
carries
experience
out there?
-Tony Condon
Cherokee II N373Y
Old April 15th 09, 03:00 AM posted to rec.aviation.soaring
Tony Condon[_2_]
Thanks,
after seeing the ones that Tim has, it makes more sense. The antennas
that Aircraft Spruce carries are different, and I cant see as well how
they mount. Will be very easy to mount that antenna in the web of sticks
in the tail of the Cherokee.
-Tony Condon
Cherokee II N373Y
Old April 15th 09, 06:05 AM posted to rec.aviation.soaring
I have use an L2 in my LS8 for five years. Just slap it on the inside
of the fuse with velcro. Works super. Approach reads me clearly in
all orientations.
Old April 17th 09, 01:32 AM posted to rec.aviation.soaring
Frank[_1_]
On Apr 14, 4:15*pm, Tony Condon
usually only project down and to the sides. *Aircraft Spruce carries
dipoles, they are a little spendy, but might be worth it. *Any experience
out there?
-Tony Condon
Cherokee II N373Y
A dipole and a monopole with a proper groundplane both have
approximately the same pattern, both above and below the plane of the
groundplane. The whole idea of a 'groundplane' is to produce a
virtual mirror image of the monopole. Monopole/groudplane
combinations are particularly convenient for metal-skinned aircraft,
where the requisite groundplane is essentially free. A dipole
arrangement might be much simpler than a monopole/groundplane for a
glider.
Frank(TA)
Old April 17th 09, 07:10 AM posted to rec.aviation.soaring
Eric Greenwell
Frank wrote:
On Apr 14, 4:15 pm, Tony Condon
out there?
-Tony Condon
Cherokee II N373Y
glider.
The patterns are different, and the bigger the ground plane, the bigger
the difference. The monopole with a large ground plane radiates only on
the side with the antenna. The "mirror image" you mention is just a
convenient way to think about how a conducting surface affects the
electric field. In practice, it blocks the field. Look up "Faraday
cage", as an example.
If a metal airplane needs a good signal on the top and the bottom, it
uses two antennas, one on each side. In Tony's wood and fabric glider,
the dipole is an good choice.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Antennas [email protected] Home Built 1 February 19th 09 08:32 PM
Transponder vs. Portable Transponder Detectors John Murphy Soaring 16 December 20th 08 08:25 AM
Antennas Terry Home Built 3 April 24th 05 07:42 PM
Antennas Terry Home Built 3 April 22nd 05 04:14 AM
Transponder Antennas...again Kilo Charlie Soaring 5 January 7th 05 11:24 AM
