XC-Soar PDA weirdness
Old April 27th 09, 04:50 PM posted to rec.aviation.soaring
Brad[_2_]
Default XC-Soar PDA weirdness
I have a question regarding XC-Soar and am running it on an iPAQ3850.
I loaded the latest version 5.2.3F.
When I first loaded the program everything worked as advertised,
except I've never seen the landable fields show up as colored dots,
well yesterday for one session they showed up as yellow dots, but not
anymore. Also the Visual Glide feature worked for awhile, and now does
not appear when activated. Also seems that the set up profile I am
constantly resetting does not hold after closing the program.
All in all I am flying with this latest release and am happy with it,
and the above mentioned items are more a curiosity than anything else,
but I am curious if it is my PDA ignorance, or is the program still
somewhat "buggy" I've also heard PDA's can be somewhat tempramental.
Thanks,
Brad
Old April 27th 09, 06:15 PM posted to rec.aviation.soaring
David Salmon[_2_]
Hi Brad
The profile save is a bit un-user friendly, I have recently suggested it
be changed.
What happens is that when you shut down, the current profile is saved as a
file called xcsoar registry.prf. If when you open the program again you
select this file when asked, then you should get exactly the same profile
as when you shut down. You can save this with another, more convenient
name by browsing to it on your SD card and re-naming it to whatever you
want, leaving the suffix as prf. If however, you already have another
profile saved and open that instead, you will get whatever that was, not
the changes.
Re the landable fields, go to Config-Setup system page 11 and the 3rd item
down gives a choice of WinPilot or Alternate. Win Pilot should give the
purple dot with the green ring. Incidentally, landable means a waypoint
with an A attribute that is reachable at safety height, nothing to do with
it's surface.
Dave
Thanks,
Brad
David Salmon[_2_]
Hi Brad
be changed.
the changes.
it's surface.
Dave
Thanks,
Brad
Old April 27th 09, 06:50 PM posted to rec.aviation.soaring
Brad[_2_]
On Apr 27, 9:15*am, David Salmon wrote:
Hi Brad
be changed.
the changes.
it's surface.
Dave
Thanks,
Brad- Hide quoted text -
- Show quoted text -
Hi Dave,
thanks for the information. I changed to winpilot and got the purple
dots to show, also named a .prf file to read: my_profile.prf but when
I restart and select that file, the program still loads with the zoom
set to auto! no big deal, but it is one of those little things that us
ADD guys get all flipped out over when it doesn't work....
Cheers,
Brad
Old April 27th 09, 11:20 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
dots to show, also named a .prf file to read: my_profile.prf but when I
restart and select that file, the program still loads with the zoom set
to auto! no big deal, but it is one of those little things that us ADD
I think you'll find that some items (auto zoom is one, whether the
display shows topo, terrain or both) can be overridden during a flight
but next start-up will revert to what you configured. The idea is that
what you configured is what you get when you boot it up as opposed to how
you left it last time. That works for me, but ymmv.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old April 28th 09, 06:25 PM posted to rec.aviation.soaring
PCool
Thanks David for explaining.
But did the Visual Glide appear back ? ;-) I didn't code it to make it
invisible, you know ... hehe.
paolo
"Martin Gregorie" ha scritto nel
messaggio ...
org |
Old April 28th 09, 07:45 PM posted to rec.aviation.soaring
Brad[_2_]
But did the Visual Glide appear back ? ;-) *I didn't code it to make it
paolo
martin@ * | Martin Gregorie
org * * * |- Hide quoted text -
nope, visual glide is back..............I replayed a flight on the PDA
and then tried Visual Glide, it shows up now.
thanks!
Brad
PS..........still don't seem to get the .prf file to hold the zoom
setting that I set, how exactly does one save a .prf file anyway? I
went in to the config menu and made some changes there, and then
saved, this was after I created a my_setup.prf file, hoping that what
ever changes I made would be saved to that file. Not so upon starting
XC soar and accessing my file.
OLC weirdness DRN Soaring 4 March 10th 09 12:13 PM
Garmin/Avidyne OBS weirdness Ron Garret Instrument Flight Rules 1 March 5th 08 10:44 PM
Citation Weirdness Charles Talleyrand Piloting 3 June 29th 07 02:08 AM
KX-155 weirdness kontiki Owning 3 September 7th 06 05:33 PM
GPS WEIRDNESS Instrument Flight Rules 5 March 18th 05 07:33 PM
