Source for Metric/liters water meter?
Old May 1st 09, 05:21 AM posted to rec.aviation.soaring
John Bojack[_2_]
Default Source for Metric/liters water meter?
Anyone know of a source for a water meter that measures in liters?
Thanks,
J4
Old May 1st 09, 09:42 AM posted to rec.aviation.soaring
Stealth Pilot[_2_]
On Fri, 1 May 2009 00:21:27 -0400, "John Bojack"
Thanks,
J4
make one.
1 litre = 1,000 cubic centimeters.
kitchen utensils shops should sell litre jugs.
they are about the size of a quart container.
Old May 1st 09, 11:19 AM posted to rec.aviation.soaring
Phil Jeffery
John
There are some for sale on the UK eBay web-site at item #150340764737. It
ends soon but I am sure they will be re-listed as there are still 10
available. This link should find it for you
http://cgi.ebay.co.uk/Water-flow-met...1%7C29 4%3A50
I bought one last year that looks exactly the same and it works really well
for watering my Ventus.
Phil
"John Bojack" wrote in message
Thanks,
J4
Old May 1st 09, 01:33 PM posted to rec.aviation.soaring
Charlie Papa
I bought a terrific unit from Wings and Wheels. It is avaialble in
liters, resettable and compact. The addition of some PVC fittings
gave me a garden hose connection with a shut off, and on the outgoing
side a 'T' fitting provides a standpipe to prevent overfilling
damage. Yo0u can see it midway down the page at http://www.wingsandwheels.com/page45.htm
Old May 1st 09, 04:09 PM posted to rec.aviation.soaring
Andy[_1_]
On May 1, 5:33*am, Charlie Papa wrote:
I bought a terrific unit from Wings and Wheels. *It is avaialble in
liters, resettable and compact. *The addition of some PVC fittings
damage. *Yo0u can see it midway down the page athttp://www.wingsandwheels.com/page45.htm
I have the same electronic meter. I find it to be very repeatable but
not very accurate at the flow rates typically used to fill wings. If
you want to measure the same quantity into each wing it works very
well. If you want to meter a known quantity into each wing you should
probably do a calibration at the flow rate that will be used to fill
the glider.
The flow rate I achieve when filling with a bilge pump (approx 16 gals
in 9 minutes) is well below the calibrated range of the meter.
My weight and balance spread sheet includes the meter calibration. I
keep a graph of metered volume vs wing loading in the glider and use
that to set the glide computer.
Andy
Old May 1st 09, 04:17 PM posted to rec.aviation.soaring
Tim Mara[_2_]
I have them here in stock
see : http://www.wingsandwheels.com/page45.htm
tim
Thanks,
J4
Old May 1st 09, 04:22 PM posted to rec.aviation.soaring
Tim Mara[_2_]
you can get meter that will be accurate at these very low flow rates but
you'll find they are very expensive, typically $500-$600
the Electronic water meters I sell are designed to operate accurately at
rates of 3 GPM which should be acceptable for most glider filling
applications...but at less than 1/2 GPM I think you are going to need the
expensive water meter to be accurate there
tim
"Andy" wrote in message
the glider.
Andy
For sale: DG-600 17-meter and 15-meter wingtips Lars Peder Hansen Soaring 0 January 21st 07 06:18 PM
Water Meter in Liters Mal Soaring 2 October 26th 05 05:44 AM
Water Meter in Litres Mal Soaring 9 September 24th 05 07:45 PM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 03:14 PM
Metric measuring tool source? DL152279546231 Home Built 12 April 29th 04 02:13 AM
