Could anyone solve this problem?
Old May 20th 09, 06:49 PM
pilot27usa pilot27usa is offline
Junior Member
First recorded activity by AviationBanter: May 2009
Default Could anyone solve this problem?
A plane flies 450 miles with the wind and 300 miles against the wind in the same length of time. If the speed of the wind is 20mph, what's the speed of the plane in still air?
a) 90mph
b) 105mph
c) 100mph
d) 125mph
Is there a formula to solve this? I am just a student pilot, but it seens to me like I would need the time and heading to solve this!? Am I wrong?
Thank you guys.
Old May 20th 09, 08:10 PM posted to rec.aviation.piloting
good grief
My stab at it.
100mph
t(x+20) = 450
t(x-20) = 300
450/(x+20) = 300/(x-20)
(x-20)/(x+20) = 300/450 = 2/3
3x-60 = 2x+40
x = 100
To check ----- 450 miles / 120 mph = 3.75 hours
300 miles / 80 mph = 3.75 hours
Old May 20th 09, 08:15 PM posted to rec.aviation.piloting
a) 90mph
b) 105mph
c) 100mph
d) 125mph
wrong?
Thank you guys.
Sounds more like a high school algebra problem, but...
distance = speed X time
D = S * t
Let:
Sp = plane speed
Sw = wind speed
therefo
450 = (Sp + Sw) * t
300 = (Sp - Sw) * t
rearranging:
t = 450 / (Sp + Sw)
t = 300 / (Sp - Sw)
eliminate t:
450 / (Sp + Sw) = 300 / (Sp - Sw)
Plug in Sw and solve for Sp.
Jim Pennino
Remove .spam.sux to reply.
Old May 20th 09, 08:28 PM posted to rec.aviation.piloting
Jim Logajan
a) 90mph
b) 105mph
c) 100mph
d) 125mph
Yes. You start by setting up two "distance = speed x time" formulas with
appropriate variables and then combine them to solve for the speed of
aircraft.
wrong?
Actually the time factor is the variable common to both distance/time
equations that you use to join the two - in the process the time variable
vanishes.
Not sure why you think you need heading for this problem.
I suppose if your algebra is really rusty you'd have problems composing a
solution.
Old May 20th 09, 08:41 PM posted to rec.aviation.piloting
C Gattman[_3_]
On May 20, 10:49*am, pilot27usa pilot27usa.
a) 90mph
b) 105mph
c) 100mph
d) 125mph
wrong?
Thank you guys.
Probably not the best forum, because a pilot's solution (especially
were this to pop up on a written exam) would probably be to run each
of the numbers through an E6B and eliminate each option, which is
quicker and easier to do on a mechanical E6B than it is to figure out
the formula on the fly, especially since it's not particularly
relevant to flight planning. This is a math question. :
Old May 20th 09, 09:03 PM posted to rec.aviation.piloting
Ron Garret
a) 90mph
b) 105mph
c) 100mph
d) 125mph
wrong?
Thank you guys.
Why do you think you need the heading? You're told that the plane is
going with/against the wind, i.e. the wind direction and the direction
of travel are the same/opposite. Why do you think you need to know what
that direction actually is?
rg
Old May 21st 09, 12:51 PM posted to rec.aviation.piloting
Brian Whatcott
a) 90mph
b) 105mph
c) 100mph
d) 125mph
wrong?
Thank you guys.
There is a formula. Here it is; speed times time = distance.
So use x for the unknown still-air speed, t for the time.
Then write out the info:
(x+20)t = 450
(x-20)t = 300
This is soluble using the method called "simultaneous equations".
Or enter it in a smart search engine like alpha, like this:
solve (x+20)t = 450, (x-20)t = 300
Answer: t = 15/4 x = 100
Here's the URL:
http://www98.wolframalpha.com/input/...x-20)t+%3D+300
or in tiny format:
http://tinyurl.com/rb3wno
Brian W
Visa resident aliens out here - how did you solve these problems? mike-the-bike General Aviation 0 June 12th 05 12:04 PM
Chaplains urge couples to attend retreat to solve problems, By Kent Harris, Stars and Stripes Otis Willie Military Aviation 0 May 31st 04 03:46 AM
ADF Problem tony roberts Instrument Flight Rules 14 May 12th 04 02:59 AM
Need Help with LS3 problem TJ Soaring 1 January 17th 04 05:13 AM
ILS problem Bernie Samms Simulators 2 September 17th 03 01:36 AM
