Ross, reading your post reminded me of another aspect of ground leaning. I
also start the engine with the mixture in the ground lean position, which is maybe at most 1/2 inch forward of idle cut-off. Starting has always been easy with just a single pump of the throttle both hot and cold. -- Best Regards, Mike. http://flickr.com/photos/mikenoel/ "Ross" wrote in message ... texas slacker wrote: Went out this morning and rolled the Warrior out for a little soul restoring and piston oiling. It totally fulunked the run-up, tried to burn the crud off the offending plug, no joy. Took it back to the hanger and started pulling plugs. They all felt hot so I pulled them in order. The crudded up plug was the last one. Didn't have anything small enough to get in the massive type gap. Finally took the plug to the mechanic and he dug out a special tool to gouge out the offending material. Put the plug back in and Warrior passed the run-up. Flew for a half hour just to be sure and made a good cross wind landing. Life is good. Now - I need to buy or fabricate some sort of gadget to do a decent job of cleaning the plugs. In looking around I see that Chief Aircraft has a sand blaster type for about $23. This looks possibly, has anyone ever used this particular gadget and did it do the job? Anyone have a better suggestion? Thanks. Leo I have cleaned lot of plugs and generally you will always find some material. That was one reason that I aggressively lean while on the ground. I noticed the little lead deposits were not there or smaller. My mechanic had the "special" tool to first dig out the little nodules, then I took it to his plug sandblaster to finally clean them out. It looked like he had a awl that was filed and bent to get into all of the areas of the plug. I have some old dental picks that my dentist gave me that seem to work also. BTW, his sandblaster was a professional kind and much more that $25.00. We also took a wire wheel and carefully cleaned the threads before applying the antisiezing compound to the first two threads. Oh, and blow out the plug with a air gun to get any grit out. -- Regards, Ross C-172F 180HP Sold ![]() KSWI |
On Thu, 21 May 2009 11:37:25 -0500, Ross wrote:
that seem to work also. BTW, his sandblaster was a professional kind and much more that $25.00. We also took a wire wheel and carefully cleaned the threads before applying the antisiezing compound to the first two threads. Oh, and blow out the plug with a air gun to get any grit out. I should have read more posts before I responded. I seemed to have said the same thing that everyone else said. One thing about the aggressive lean on the ground is that if you try to take off and forget to push the mixture in, the engine quits or sputters as a good reminder. Ask my how I know ![]() but if you are fast you can roll almost to the yellow line clear of the active area of the runway. no amount of being fast will get the mixture back full rich in time though. I'll bet you know the same way I do :-) jetlube coppercoat grease is my antisieze. Stealth Pilot |
On Thu, 21 May 2009 14:42:05 -0700, "Mike Noel"
wrote: Ross, reading your post reminded me of another aspect of ground leaning. I also start the engine with the mixture in the ground lean position, which is maybe at most 1/2 inch forward of idle cut-off. Starting has always been easy with just a single pump of the throttle both hot and cold. yeah but that depends entirely on how the throttle pump on your carby is set up. (there are 3 settings on the schebler) mine would behave like that but would die on throttle increases at altitude. it is now changed to give correct prime with 3 pumps and doesnt die when throttle is increased at altitude. there is a little plate that drives the actual pump plunger that has 3 holes in it. Stealth Pilot |
Mike Noel wrote:
Ross, reading your post reminded me of another aspect of ground leaning. I also start the engine with the mixture in the ground lean position, which is maybe at most 1/2 inch forward of idle cut-off. Starting has always been easy with just a single pump of the throttle both hot and cold. When I had the plane (and had the opportunity to fly it Wednesday for the new owner) my starting procedure for the Lyc O-360 was three primes, turn the key and one pump on the throttle and it always started on two blades. That was for first start. Any other start that day was usually just turn the key and maybe one pump on the throttle. I never did the lean during start. Now I understand fuel injected hot starts are another issue. -- Regards, Ross C-172F 180HP Sold ![]() KSWI |
Best spark plug cleaning tool? | Dan Luke | Owning | 5 | August 10th 05 07:08 AM |
Spark plug question for Archie | John S | Home Built | 0 | February 17th 05 06:56 PM |
Vintage spark plug | Robert Eagle | Restoration | 0 | November 30th 04 08:57 PM |
Q: Spark Plug Life | john smith | Owning | 7 | August 15th 03 05:11 PM |
spark plug question | Bill T. | Owning | 0 | July 3rd 03 07:08 PM |
