On May 26, 10:44*am,  wrote:
	- We've wrapped a wire behind the vertical bar that carries the attach pins and two other friends were pulling forward on the sides of the stab; I, in return, was pounding *with a hammer on the locking hex screw that normally locks down the stab. The stab had not even moved a millimeter... According to a Schleicher Engineer we can knock one of the pin out, from inside, if we remove the rudder... Maybe the electrical wire freeze will work, although from Physics it should shrink the subjected metal and heating should expand it. Thanks Gregg- Hide quoted text - - Show quoted text - Maybe I'm over conservative but I would never pound on that bolt with a hammer. I'd also be very careful about using any significant force on the end of the exposed pin. If that one moves and the other is stuck you will just make it bind up tighter. If it went together and it has not been together long enough to corrode it should come apart. Gettting the alignment just right to find the sweet spot will be the key. Brute force is very unlikely to help. Good luck Andy  |
It's been a week or so, has there been any resolution on this
	situation? Thanks, Bob K.  |
On Jun 3, 2:15*pm, Bob Kuykendall  wrote:
	It's been a week or so, has there been any resolution on this situation? Thanks, Bob K. Hi, It was removed by first removing the rudder, stripping off the elevator control seal and then knocking the upper pin from the back... Thanks, Gregg  |
On Jun 3, 4:35*pm,  wrote:
	Hi, * It was removed by first removing the rudder, stripping off the elevator control seal and then knocking the upper pin from the back... That sounds troublesome, but I'm glad you didn't have to do any major trauma to the aircraft. I hope you can clean things up so it works more smoothly in the future. Thanks, Bob K.  |
| Why I wont buy from Paul | diogenes | Soaring | 18 | October 21st 05 11:38 AM |
| Why I wont buy from Paul | Guy Acheson | Soaring | 1 | October 19th 05 03:51 PM |
| Navy pilots wont be coming to Las Cruces this year | Otis Willie | Naval Aviation | 0 | February 8th 05 04:09 AM |
| WTB: 1-34 Horizontal Stabilizer | Jeremy Zawodny | Soaring | 1 | October 15th 04 06:12 AM |
| FS2004 wont start ?? | nosna03 | Simulators | 7 | July 9th 04 04:25 PM |
