ENGINE BASICS
Old June 11th 09, 05:36 PM posted to rec.aviation.homebuilt
Tim[_8_]
Default ENGINE BASICS
"cmyr" wrote in message
On Jun 11, 11:32?am, George wrote:
I believe that Ballenger Headers had the "pickle" located in the
collector of 4 tube equal length headers and there was also the
"coanda" effect which is specifically what I think you were speaking of.
? It was used experimentally in a truly weird exhaust setup in the early
days by of one of the major racing teams back in the mid 60s, but my
memory is a bit foggy for specifics that far back, such as who or on
what car, sorry.
cmyr wrote:
? ?Going back to some hot rodding roots,I believe V.E. was increased
in the late '60's-70's thru the use of a specially designed double
cone affair placed in the collector pipe of a tuned exhaust
system,which created a stronger vacuum effect , creating stronger
scavenging of exhaust, and to some extent , helping draw more fuel/air
mix into the cylinder.- Hide quoted text -
- Show quoted text -
You remembered the word I couldn't put my finger on........coanda
Back in the 70s or so, there was a three cylinder two stroke radial, with
all three cylinders in a common crank case - that used the exhaust system
exclusively for scavenging the engine. There was no intake draft without it.
It was featured on an ultralight one year at OSH.
Old June 11th 09, 08:41 PM posted to rec.aviation.homebuilt
Peter Dohm
There have been a number of things that improved VE: Generally, higher
compression ratios help especially at higher RPM, roller tappets seem to
withstand much faster ramp angles and can stay open further during the open
part of the valve cycles, and anti-reversion cones in the exhaust are said
to work very well in the mid-range of RPM for any given four cycle engine.
In addition, intake and exhaust port shapes play a major role; as do other
aspects of head ad piston crown design.
In a nut-shell, there has been a lot of progress over the past three
quarters of a century, and the only place that I can think of in which
aircraft engines have led the way has been in the area that we used to call
"blue printing" in which the ports are more carefully caste, machined, and
finished to closely match the design drawings for the engine. Today, every
late model engine that I have seen is done that way at the factory; but
forty years ago, automotive engines were really crude.
Peter
Old June 12th 09, 01:06 AM posted to rec.aviation.homebuilt
On Thu, 11 Jun 2009 07:40:10 -0700 (PDT), cmyr
The anti reversion cone was a dirty fix for a crappy header design.
Better than a manifold, but not as good as a proper "tuned" header.
Old June 12th 09, 02:05 PM posted to rec.aviation.homebuilt
cmyr
� Going back to some hot rodding roots,I believe V.E. was increased
As I recall, this system was on the cover of Hot Rod magazine, on a
high end test vehicle,and was "scientifically" researched. In this
instance the reference to a crappy header design would be wrong.
Old June 12th 09, 07:12 PM posted to rec.aviation.homebuilt
Tom Wait
? Going back to some hot rodding roots,I believe V.E. was increased
All the previous 6 or7 posters have come up with methods of increasing VE
w/o superchargers. I want to add 4 or more valves per cylinder which would
probably increase the mass of the valve train. Certainly the complexity. I
don't see how a massive rocker arm or longer fatter pushrod could decrease
VE. Certainly a larger valve head would increase mass but would also
increase VE. A thicker valve stem would increase mass and decrease VE but I
think only marginally. I think the only way more mass would decrease VE
would be if the push rods were rubber.
Tom
Old June 12th 09, 10:55 PM posted to rec.aviation.homebuilt
Torn Lawence
Tom
The British made some WWII engines with rotating cylinder sleeves that
had in and out ports cut into them - rotary valves! No poppets. Good
performance, but burned oil and left conspicuous smoke trails, not a
good thing for a warbird to do.
That's what I remember from an engine class, unless I'm hallucinating again.
Old June 12th 09, 11:27 PM posted to rec.aviation.homebuilt
Gerry van Dyk
Ah yes the "sleeve valve" engine
Bristol's Hercules in the radial engined Halifax and Lancaster
bombers, and Centaurus in the Sea Fury and several transports. Also
the Napier Sabre in the Hawker Typhoon and early Tempest.
The Centaurus turned into a real workhorse, but the Sabre died out
quickly. The Brits seem to keep the Bristols in service in warbirds
but American's tend to replace them with R-3350s, presumably for
spares availability this side of the pond.
Gerry
probably increase the mass of the valve train. Certainly the complexity.. I
Tom
That's what I remember from an engine class, unless I'm hallucinating again.- Hide quoted text -
Old June 12th 09, 11:32 PM posted to rec.aviation.homebuilt
Charles Vincent
again.
That was a sleeve valve engine, Harry Ricardo's magnum opus. The
Bristol Hercules and Centaurus. Wear was an issue they never did tackle.
Charles
Old June 12th 09, 11:42 PM posted to rec.aviation.homebuilt
bildan
bombers, and Centaurus in the Sea Fury and several transports. *Also
quickly. *The Brits seem to keep the Bristols in service in warbirds
Gerry
Tom
If you ignore oil consumption, (No one succeeded in fixing that
problem.) Bristol sleeve valve radials had a lot to recommend
them. Maybe today with modern metallurgy and high temperature
elastomers someone could.
However, without poppet valves and rocker towers in the heads, the
engine diameter was much smaller. Without a hot exhaust valve in the
combustion chamber, the compression ratio could be a point or two
higher with the same octane fuel and the same detonation margins - and
the engine tended to last longer. At the time, and maybe still,
poppet exhaust valves were the weak point.
They have Sir Harry Ricardo to thank for the sleeve valve design.
Old June 13th 09, 12:53 AM posted to rec.aviation.homebuilt
Morgans[_2_]
"Charles Vincent" wrote in message
news
performance, but burned oil and left conspicuous smoke trails, not a good
That was a sleeve valve engine, Harry Ricardo's magnum opus. The Bristol
When engines were changed as often as shirts, and as easily as shoes, that isn't
a big issue either, IMHO.
You have always got spares sitting around wherever you stop frequently, and in
an hour or so, you put in a new engine and are on your way.
Jim in NC
Back to basics? Ol Shy & Bashful Piloting 3 September 2nd 08 09:45 PM
airframe basics Mike Piloting 6 June 7th 06 04:37 PM
Scratch Building Basics for Metal Aircraft DVD jon Home Built 1 March 28th 06 11:51 PM
Learning piston engine basics [email protected] Owning 9 December 24th 05 09:19 PM
Tent basics // Oshkosh prep Mike Z. Piloting 35 December 31st 03 10:54 PM
