How long is the runway at Groom Lake?
Pete wrote:
"Ken Duffey" wrote The main runway (VPP-4) at Ramenskoye - now called Zhukovski - near Moscow, is 5403 m (17,726 ft) in length. Width is 84m (276 ft). Depth is 85cm (33.5 in) - another runway - VPP-1 - is 180cm (5ft 11in) thick!!! Is that the design thickness, or the actual, finished construction thickness... ![]() Pete Again, according to IAPR Vol 7.......... "In 1949 the thickness of concrete cover of some segments of the VPP-1 achieved 30-32 cm (11.8 - 12.6in)................ In 1986-1990 VPP-1 was rebuilt, changing its lateral section from concave to convex. After years of reconstruction and modernisation, Zhukovskiy's runways now boast an astonishing structure. For instance, 10 layers of concrete have been laid on VPP-1 and in its central parts it is 180cm (5ft 11in) thick. Today, two runways are used at Ramenskoye, VPP-1 and VPP-4. There are no weight limitations and they can easily accomodate any aircraft in the worls - including a space shuttle." there is lots more - in fact a whole article with photos - and a great satellite photos of the whole complex. ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++ Ken Duffey - Flanker Freak & Russian Aviation Enthusiast Flankers Website - http://www.flankers.co.uk/ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++ |
![]() "Air Force Jayhawk" wrote in message ... Not military (anymore), but Salina Kansas airport is 13337 ft long. Used to be Schilling AFB, rumor has it the runway was extended to support B-70 ops until the program was canceled and the base was closed and turned over to the city. I think you'll find the runway was lengthened to better accommodate the B-52 and KC-135 that were scheduled to replace the B-47 and KC-97 at Schilling. |
Used to be Schilling AFB, rumor has it the runway was extended to support B-70 ops until the program was canceled and the base was closed and turned over to the city. Ross "Roscoe" Dillon USAF Flight Tester (B-2, F-16, F-15, F-5, T-37, T-38, C-5, QF-106) Many old SAC B-52 runways are 13,000ish by 300' wide. Thats a lot of concrete. I have landed at Salina Kansas before, Flowers Aviation has some rather attractive females working there. I remember seeing a Connie there at the airport, couldnt tell if it was airworthy or not, also saw a Luftwaffe Tornado. Ron Pilot/Wildland Firefighter |
![]() Many old SAC B-52 runways are 13,000ish by 300' wide. Thats a lot of concrete. The former Pease AFB is a couple miles across Great Bay from my house. When SAC left many years ago, it became home to the NH Air Guard, but remained an Air Force Base. One summer they moved all the KC-135s to New York state and resurfaced the runway. What bliss for three months! Of course you know what happened next: Pease was closed down. All that concrete was sold to a "tradeport" authority for a dollar. The KC-135s are still there, however, and still noisy in the summer. So I guess the guvmint got something out of its investment. (And the air traffic controller still says: "Check landing gear down and locked.") all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
and locked.") You mean he says it to you? (Or are you NORDO?) vince |
In article .net,
"Steven P. McNicoll" writes: "Air Force Jayhawk" wrote in message ... Not military (anymore), but Salina Kansas airport is 13337 ft long. Used to be Schilling AFB, rumor has it the runway was extended to support B-70 ops until the program was canceled and the base was closed and turned over to the city. I think you'll find the runway was lengthened to better accommodate the B-52 and KC-135 that were scheduled to replace the B-47 and KC-97 at Schilling. Actually, that doesn't hold up, at least in the B-52/B-47 matchup. B-47s were horrendously underpowered. A heaviweight B-47, on a standard day, without JATO, would be using something on the order of 11,000' of runway. The equivalent B-52C/D (The worst for takeoff), would be off the ground in 8,000'. Hmm. At one point, for about 10 years, there were 90 B-47s at Pease. with about 12,000' or runway. It's rather amazing that Great Bay didn't get filled up with B-47s running off the runway during rejected takeoffs. Data from the Standard Aircraft Characteristics, B-47E-IV, and B-52C/D. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
![]() "Peter Stickney" wrote in message ... Actually, that doesn't hold up, at least in the B-52/B-47 matchup. B-47s were horrendously underpowered. A heaviweight B-47, on a standard day, without JATO, would be using something on the order of 11,000' of runway. The equivalent B-52C/D (The worst for takeoff), would be off the ground in 8,000'. Hmm. At one point, for about 10 years, there were 90 B-47s at Pease. with about 12,000' or runway. It's rather amazing that Great Bay didn't get filled up with B-47s running off the runway during rejected takeoffs. Data from the Standard Aircraft Characteristics, B-47E-IV, and B-52C/D. Nevertheless, the runway was lengthened in 1959-60, between B-47/KC-97 and B-52/KC-135 operations at Schilling, and long before the B-70 would have been operational. |
![]() "Steven P. McNicoll" wrote in message k.net... Nevertheless, the runway was lengthened in 1959-60, between B-47/KC-97 and B-52/KC-135 operations at Schilling, and long before the B-70 would have been operational. Even though the preparations were made for B-52 operations there it did not happen. See: http://www.globalsecurity.org/wmd/fa.../schilling.htm From which the following paragraph is quoted. On 19 November 1964, the Department of Defense announced that Schilling along with 574 other bases around the world would be closed. At this time the base was home to approximately 5,090 men. Within the next six months, all planes and men were relocated, including the Atlas F ICBM Squadron, and the base was closed on 30 June 1965. End quote. I was TDY to Schilling AFB in January 1965, visited the Command Post several times and watched an exercise, and I assure you the bombers in the unit were still B-47s. My home base at the time was a B-52 base and I assure you I knew the difference. They started the closing shortly after I left. Regards, Tex Houston |
Speech: World War II Military Pilots | Otis Willie | Military Aviation | 0 | December 31st 03 05:06 AM |
Updated List of Military Information-Exchange Forums | Otis Willie | Military Aviation | 0 | December 29th 03 02:20 AM |
List of News, Discussion and Info Exchange forums | Otis Willie | Military Aviation | 0 | November 14th 03 05:01 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
U.S. is losing the sympathy of the world | John Mullen | Military Aviation | 149 | September 22nd 03 03:42 PM |
