rec.aviation.homebuilt
Help needed understanding turbojets Horsepower is defined/measured as 550 foot pounds per second. ie, lifting 1 pound 550 feet every second is 1 hp. If you lift 550 pounds one foot every second and keep that going for 12 hours or so every day, you are a horse. Similarly, an airplane with a one horsepower engine that travels at 550 feet per second at full power is pushing with the force of one pound. Conversally, as above, if the plane's max speed is 1 foot per second the thrust is 550 pounds. Handy for gauging such questions. Hul |
On Sat, 20 Jun 2009 13:13:43 +0000 (UTC), Hul Tytus
wrote: rec.aviation.homebuilt Help needed understanding turbojets Horsepower is defined/measured as 550 foot pounds per second. ie, lifting 1 pound 550 feet every second is 1 hp. If you lift 550 pounds one foot every second and keep that going for 12 hours or so every day, you are a horse. Similarly, an airplane with a one horsepower engine that travels at 550 feet per second at full power is pushing with the force of one pound. Conversally, as above, if the plane's max speed is 1 foot per second the thrust is 550 pounds. Handy for gauging such questions. Hul I thought it was originally defined as lifting a Ton a Foot a Minute. ie what a shire horse could achieve lifting stuff out of a mine on a windlass. |
Stealth Pilot wrote:
On Sat, 20 Jun 2009 13:13:43 +0000 (UTC), Hul Tytus wrote: rec.aviation.homebuilt Help needed understanding turbojets Horsepower is defined/measured as 550 foot pounds per second. ie, lifting 1 pound 550 feet every second is 1 hp. If you lift 550 pounds one foot every second and keep that going for 12 hours or so every day, you are a horse. Similarly, an airplane with a one horsepower engine that travels at 550 feet per second at full power is pushing with the force of one pound. Conversally, as above, if the plane's max speed is 1 foot per second the thrust is 550 pounds. Handy for gauging such questions. Hul I thought it was originally defined as lifting a Ton a Foot a Minute. ie what a shire horse could achieve lifting stuff out of a mine on a windlass. I think you dropped a zero. 1 HP = 33000 ft.lb/min or about 15 ft.tons/min But a shire horse can really manage about 10 ft.tons/minute, without Watt's fudge factor. Brian W |
Help needed understanding turbojets | Hul Tytus | Home Built | 2 | June 20th 09 11:15 PM |
Help needed understanding turbojets and airplanes | es330td | Home Built | 8 | June 20th 09 06:41 PM |
Attorney Needed with Aviation Understanding | Tim Hanke | Soaring | 1 | August 31st 07 02:22 PM |
Need help understanding KFC-200 operation | Roy Smith | Instrument Flight Rules | 11 | July 1st 06 12:22 AM |
Turbojets again | tango4 | Soaring | 3 | November 27th 03 03:49 PM |
