I am planning on building a plane that is towed behind a boat. Because
of the low speed (25mph stall) I am planning on using a high lift airfoil. Some airfoils with high coefficients of lift a FX72150B (2.0), FX73CL3(2.25), GOE225(1.9), GOE226(1.9), GOE234(2.0), GOE243 (2.0), GOE244(2.0), S1210(2.25), S1221(2.2), S1223(2.3), S1223RTL (2.5). This is a link to the airfoils and polars: http://www.kaiyipboxing.com/WIG/INDEX.HTM I know some of these airfoils are for model airplanes and might not be suitable. Some also have very thin trailing edges which may be hard to build. I don't know very much about aerodynamics so I was wondering if anyone has any opinions. Brock |
On Jun 20, 5:05*pm, durabol wrote:
I am planning on building a plane that is towed behind a boat... Were it I, I'd go with an NACA 23000-series (23012 for 12% t/c or whatever) and be done with it. Good enough for the 1-26 and 1-23 sailplanes, good enough for the Bonanza and the early Citation business jet, probably fine for a boat-towed glider toy. |
durabol wrote:
I am planning on building a plane that is towed behind a boat. Because of the low speed (25mph stall) I am planning on using a high lift airfoil. Some airfoils with high coefficients of lift a FX72150B (2.0), FX73CL3(2.25), GOE225(1.9), GOE226(1.9), GOE234(2.0), GOE243 (2.0), GOE244(2.0), S1210(2.25), S1221(2.2), S1223(2.3), S1223RTL (2.5). This is a link to the airfoils and polars: http://www.kaiyipboxing.com/WIG/INDEX.HTM I know some of these airfoils are for model airplanes and might not be suitable. Some also have very thin trailing edges which may be hard to build. I don't know very much about aerodynamics so I was wondering if anyone has any opinions. Brock The old saying goes, "You don't get nothin' for nothin'", and I guess this applies to hi lift airfoils too. Need to take care of surface and profile etc. Low speed application means less sensitive to (speed related) drag effects, but more wing area required. If it needs to be compact, you could even consider a biplane approach - they are helluva strong, but a little draggy - and here that's not too worrying. Brian W |
I don't know very much about aerodynamics so I was wondering if anyone has any opinions. ---------------------------------------------------------------------------- Dear Brock, The best answer depends on the speed of the boat; if the airfoil is subject to spray, how long the wing can be and so forth. -R.S.Hoover |
S1210(2.25), S1223(2.3), S1223RTL (2.5).
This is a link to the airfoils and polars:http://www.kaiyipboxing.com/WIG/INDEX.HTM Yes. But those polars were calculated for a Reynolds number of 2.5 10^6, which is way too high for your application. I did a run with XFOIL on the S1210 and the S1223RTL with Re=1 10^6, which is closer to your application. With a 1 m chord, you will get Re=7.5 10^5 at 25 mph (around 11 m/s). The max c_L is still close, but from comparing XFOIL results to wind tunnel tests on other profiles I know that XFOIL is too optimistic. Usually even flapped airfoils don't go beyond a c_L of about 2. But a normal flap on any of the airfoils you mentioned won't give you more lift as you would have immediate flow separation on the flaps upper surface at high angles of attack. I would look for wind tunnel test data on flapped or other high-lift airfoils and go from there. If the weight of your airplane and the intended wing surface don't allow for a normal airfoil, try: Investigation into high-lift systems such as fixed slats (such as used on the Fieseler Fi 156 "Storch"), slotted flaps, or, maybe the best option as a compromise between efficacy and simplicity is a Junkers flap, which is just another small "wing" installed at a small distance behind the main wing (Wikipedia and Google should give you some insight on how this system is laid out and on which airplanes it was used). HTH, Oliver |
"durabol" wrote in message
... I am planning on building a plane that is towed behind a boat. Because of the low speed (25mph stall) I am planning on using a high lift airfoil. Some airfoils with high coefficients of lift a FX72150B (2.0), FX73CL3(2.25), GOE225(1.9), GOE226(1.9), GOE234(2.0), GOE243 (2.0), GOE244(2.0), S1210(2.25), S1221(2.2), S1223(2.3), S1223RTL (2.5). This is a link to the airfoils and polars: http://www.kaiyipboxing.com/WIG/INDEX.HTM I know some of these airfoils are for model airplanes and might not be suitable. Some also have very thin trailing edges which may be hard to build. I don't know very much about aerodynamics so I was wondering if anyone has any opinions. Popular Mechanics had plans for a tow behind biplane in the early 70's late 60's - fwiw... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
durabol wrote:
I am planning on building a plane that is towed behind a boat. Because of the low speed (25mph stall) I am planning on using a high lift airfoil. Some airfoils with high coefficients of lift a FX72150B (2.0), FX73CL3(2.25), GOE225(1.9), GOE226(1.9), GOE234(2.0), GOE243 (2.0), GOE244(2.0), S1210(2.25), S1221(2.2), S1223(2.3), S1223RTL (2.5). This is a link to the airfoils and polars: http://www.kaiyipboxing.com/WIG/INDEX.HTM I know some of these airfoils are for model airplanes and might not be suitable. Some also have very thin trailing edges which may be hard to build. I don't know very much about aerodynamics so I was wondering if anyone has any opinions. Brock Before I'd consider any particular airfoil, what's your Reynolds Number range? |
![]() Before I'd consider any particular airfoil, what's your Reynolds Number range? -------------------------------------------------------------------------------------------- "Towed by a boat" and "..stall speed of 25mph" pretty well defines the lower end of the envelop. Since the thing is a water craft, apparently meant for recreational purposes we can assume two-place, side-by-side for the load and a stepped hull, probably with a T-tail. As with most water craft it probably needs to be designed to allow it to be taken to where the water is. The need for portability tends to suggest a wide-chord, low- aspect wing, probably strut-braced to improve it's portability and ease of set-up, which points us toward one of the low-speed airfoils developed at Gottingen University during the 1920's... or an RAF- series airfoil from the same era... or something from the fat end of the 23000 series...23021 or whatever... but that would probably want a full-span, all-flying Junkers 'aileron' for control, as mentioned by Oliver. Brian's mention of biplane wings is a hands-down winner for strength but becomes a mare's nest when it comes to portability and ease of erection. As for getting off of the water and into the air I think the real problem is getting free of the water without the characteristic 'pop- up.' In any case, the fact you want it to take-off and land on water,, plus the fact it is a flying boat rather than an airplane on floats, means it's going to have to be hell for stout if you want it to last more than one season. ---------------------------------------------------------------------------------- As always, this Group can over-engineer the thing for you :-) Or you could just jump right in, whip something out and play with it until it breaks. -R.S.Hoover |
Bob wrote:
As always, this Group can over-engineer the thing for you :-) Or you could just jump right in, whip something out and play with it until it breaks. An old contrarian saying comes to mind: "A month in the lab can save you an hour in the library." In this case I say it never hurts to try to sit down and try to make some estimates, however rough. Otherwise yes, one can always start building something and after enough trial and error construction and testing eventually come up with something. |
"Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote in message
... "durabol" wrote in message ... I am planning on building a plane that is towed behind a boat. Because of the low speed (25mph stall) I am planning on using a high lift airfoil. Some airfoils with high coefficients of lift a FX72150B (2.0), FX73CL3(2.25), GOE225(1.9), GOE226(1.9), GOE234(2.0), GOE243 (2.0), GOE244(2.0), S1210(2.25), S1221(2.2), S1223(2.3), S1223RTL (2.5). This is a link to the airfoils and polars: http://www.kaiyipboxing.com/WIG/INDEX.HTM I know some of these airfoils are for model airplanes and might not be suitable. Some also have very thin trailing edges which may be hard to build. I don't know very much about aerodynamics so I was wondering if anyone has any opinions. Popular Mechanics had plans for a tow behind biplane in the early 70's late 60's - fwiw... Close, but not quite right. August 1967 Popular Science: "Aqua Glider: A great new sportscraft you can build" NACA 4412 airfoil Stall speed 35 mph Weighs 180 pounds Designer Bill Skliar N6498D Currently in the EAA museum: http://www.airventuremuseum.org/coll...a%20Glider.asp -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
airfoil | [email protected] | Soaring | 0 | July 2nd 07 11:57 PM |
Jantar Std Airfoil | [email protected] | Soaring | 4 | May 8th 06 10:41 PM |
GA 35-A-415 airfoil | [email protected] | Home Built | 0 | November 1st 05 02:56 AM |
S-18 airfoil | JDKAHN | Home Built | 0 | October 30th 04 04:35 AM |
Best airfoil? | Scott | Soaring | 5 | January 27th 04 06:30 PM |
