What do ATC, EXP mean?
Old June 20th 09, 08:45 PM posted to rec.aviation.soaring
Bret
Default What do ATC, EXP mean?
Hi, in http://www.sailplanedirectory.com/ndxtype.htm, I see the
notation "ATC" for some planes and some planes are described as EXP.
Help me out here
Thanks
Old June 20th 09, 08:51 PM posted to rec.aviation.soaring
sisu1a
On Jun 20, 12:45*pm, Bret wrote:
Hi, inhttp://www.sailplanedirectory.com/ndxtype.htm, I see the
notation *"ATC" for some planes and some planes are described as EXP.
Help me out here
Thanks
ATC- ?Type Certification (I presume the A was meant to be an S, for
Standard, and that is actually a typo...)
EXP- Experimental certification
-Paul
Old June 20th 09, 08:55 PM posted to rec.aviation.soaring
glidergeek
Help me out here
Thanks
ATC- *?Type Certification *(I presume the A was meant to be an S, for
Standard, *and that is actually a typo...)
-Paul
Maybe A for aircraft?
Old June 21st 09, 02:02 AM posted to rec.aviation.soaring
Bob Kuykendall
More likely A for Approved, as in "approved Type Certificate."
Thanks, Bob K.
Old June 21st 09, 02:05 AM posted to rec.aviation.soaring
Bob Kuykendall
STC is more commonly associated with Supplemental Type Certificate,
which approves the modification of an aircraft such that it no longer
conforms to the specifications of its original Type Certificate.
Thanks, Bob K.
