Help needed understanding turbojets
Old June 20th 09, 02:13 PM posted to rec.aviation.homebuilt
Hul Tytus
Default Help needed understanding turbojets
Horsepower is defined/measured as 550 foot pounds per second. ie,
lifting 1 pound 550 feet every second is 1 hp. If you lift 550 pounds one foot
every second and keep that going for 12 hours or so every day, you are a
horse.
Similarly, an airplane with a one horsepower engine that travels at
550 feet per second at full power is pushing with the force of one pound.
Conversally, as above, if the plane's max speed is 1 foot per second the
thrust is 550 pounds.
Handy for gauging such questions.
Hul
Old June 21st 09, 03:59 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sat, 20 Jun 2009 13:13:43 +0000 (UTC), Hul Tytus
horse.
Hul
I thought it was originally defined as lifting a Ton a Foot a Minute.
ie what a shire horse could achieve lifting stuff out of a mine on a
windlass.
Old June 21st 09, 04:07 PM posted to rec.aviation.homebuilt
Brian Whatcott
horse.
Hul
windlass.
I think you dropped a zero.
1 HP = 33000 ft.lb/min or about 15 ft.tons/min
But a shire horse can really manage about 10 ft.tons/minute,
without Watt's fudge factor.
Brian W
Help needed understanding turbojets Hul Tytus Home Built 2 June 20th 09 11:15 PM
Help needed understanding turbojets and airplanes es330td Home Built 8 June 20th 09 06:41 PM
Attorney Needed with Aviation Understanding Tim Hanke Soaring 1 August 31st 07 02:22 PM
Need help understanding KFC-200 operation Roy Smith Instrument Flight Rules 11 July 1st 06 12:22 AM
Turbojets again tango4 Soaring 3 November 27th 03 03:49 PM
