#51
On Tue, 23 Jun 2009 09:10:28 -0700, T8 wrote:
On Jun 23, 11:14Â*am, Martin Gregorie wrote: Apart from anything else, your hand should be on the release knob during the launch This is surprising to me -- a non-winch-qualified pilot. Do you do the same for aero tow? Don't forget we're talking 30 seconds or so from when the glider first moves until you're off the top of the cable, not several minutes, and no trim changes should be needed during the launch. And yes, because I learned to fly on the winch, I generally do keep my hand on the release during an aero-tow. I leave the wheel down while on tow, so in my Libelle there's never a need to take my left hand off the release. If I'm flying anything else (e.g., a Puchacz for annual checks) and need to re-trim, etc. I'll do that and then put my hand back on the release. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#52
On Tue, 23 Jun 2009 09:03:01 -0700, T8 wrote:
On Jun 23, 11:14Â*am, Martin Gregorie wrote: Apart from anything else, your hand should be on the release knob during the launch, so pulling it a couple of times immediately after pushing over and just before letting go of it is an obvious move. That is taught as SOP in my club. That's surprising to me... a non-winch qualified guy. On an aero tow, I would call that very risky business indeed. On the winch there is a cable under tension connecting the glider's CG to a few tonnes of winch. A consequence of this is that the glider is unlikely to make sudden vertical movements before release - the main effect of turbulence, thermals or gradient is to affect airspeed rather than cause sudden vertical movements. This is quite unlike aero-tows. Apart from that, exactly what you do with your release hand depends on the cockpit arrangement in the glider: - in the SZD Junior, where the T-shaped release grows out of the top left of the panel on a stiff cable, you can put your left arm on the canopy tail, straight fingers resting on the release. Closing the hand and pulling is one fast, simple action. - in a Libelle, where the release is on a relatively long cable between your legs, your left arm is on your leg with fingers resting on the T- shaped release. Again its simply a matter of close fingers and pull. In both gliders rough ground or turbulence is unlikely to cause an inadvertent release because (1) your hand isn't wrapped round the release, (2) the cable isn't tight and (3) your arm ands hand is supported. The situation isn't as clear-cut in, say, an ASK-21 with its yellow ball dangling in mid-air, but you still want your hand very close to it - touching but not grasping is good. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#53
On Tue, 23 Jun 2009 09:00:06 -0700, bildan wrote:
I don't think you made your case. I have seen LOTS of wire/rope breaks, including weak link breaks, and nothing has ever stayed on the hook - even with Schweizers. I've seen several strops dropped when the pilot pulled the release after a weak link broke. During a practice power fade the cable often stays on through the push-over, so it follows that this is also likely if the winch fails for real due to engine trouble or a fuel blockage. The reason I brought this up is that I have seen many pilots nearly bungle a recovery while pulling the release. Even with a hand on the release, there's no guarantee a pilot will pull it - I've seen pilots take their hand off the release and pull the spoilers. A launch failure is no time to be multi-tasking. I've never seen this. An ASW-19 or Pegase on finals with the wheel going up and down, yes, but brakes opening after a cable break, never. I want to see this priority list in order of decreasing urgency: 1. Nose way down NOW! 2. Get a safe airspeed ASAP! 3. Decide on the landing option (Straight or circle.) 4. Execute landing option - concentrate on airspeed and coordination. 5. Pull the release - maybe. Move 5 up to 2 and I'll agree with your sequence. Three reasons: (a) you're going to wait some seconds for the airspeed to build so pulling it at this point doesn't delay any other actions. (b) Your hand is on or very near the release, so just do it. (c) As I said above, you may be faced with a power fade rather than a cable break and the cable may still be on. Now, we know that back-release works for a straight backward pull, but what if its a high power fade and you get airspeed and turn. Would you still expect the cable to back release at an angle to the flight path? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#54
![]() 1. Nose way down NOW! 2. Get a safe airspeed ASAP! 3. Decide on the landing option (Straight or circle.) 4. Execute landing option - concentrate on airspeed and coordination. 5. Pull the release - maybe. Move 5 up to 2 and I'll agree with your sequence. Three reasons: (a) you're going to wait some seconds for the airspeed to build so * * pulling it at this point doesn't delay any other actions. (b) Your hand is on or very near the release, so just do it. (c) As I said above, you may be faced with a power fade rather than * * a cable break and the cable may still be on. Now, we know that * * back-release works for a straight backward pull, but what if * * its a high power fade and you get airspeed and turn. Would you * * still expect the cable to back release at an angle to the flight * * path? -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | OK, maybe, as long as it isn't priority 1 - but now you are introducing a power fade which is a different animal. Power fades are demonstrated and practiced along with simulated rope breaks just so pilots know the difference. No one has ever said, "Wow, that's confusing - how do you tell the difference?" (C.) However, this one deserves serious consideration. A break is an obvious "thump" and an upward surge. (Spectra/Dyneema rope generates a much more obvious thump than steel.) Assuming the pilot is monitoring airspeed, a power fade means the nose will coming down and be down to a normal glide attitude and airspeed as power is totally lost - just as at the top of a normal launch. It will be managed as if it were a normal launch with a normal release pull - just at a lower height. Just as with a normal launch, the winch driver will be alert to the rope not detaching from the glider and fire the guillotine For a winch power loss to be confused with a rope break, the power failure would need to be a rare kind - some sort of explosive loss of mechanical integrity or seizing up of the winch. But, if the rope is still attached at the winch, there won't be the upward surge. |
#55
#56
On Tue, 23 Jun 2009 14:42:24 -0700, bildan wrote:
OK, maybe, as long as it isn't priority 1 - but now you are introducing a power fade which is a different animal. They aren't taught as distinct happenings here - just as winch launch failures. I agree that they are seldom confused, but the actions to be taken after a cable break or after a power fade is recognised are the same: (1) nose down to establish approach speed, (2) make sure cable is off (3)..... No one has ever said, "Wow, that's confusing - how do you tell the difference?" ....and I didn't say or imply that anybody confuses the two. (C.) However, this one deserves serious consideration. A break is an obvious "thump" and an upward surge. (Spectra/Dyneema rope generates a much more obvious thump than steel.) Even when it breaks at the winch end? I wouldn't know - I've not yet flown on the stuff. Assuming the pilot is monitoring airspeed, a power fade means the nose will coming down and be down to a normal glide attitude and airspeed as power is totally lost - just as at the top of a normal launch. If its a slow fade the airspeed may easily be lower than approach speed. IME a slow fade is harder to recognize and deal with than a sudden cut or a break. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#57
have a look at the simulation videos on the BGA website
http://www.gliding.co.uk/bgainfo/saf...nch-safety.htm you don't have a lot of time to find the release knob if a wing drops T8 wrote: On Jun 23, 11:14 am, Martin Gregorie wrote: Apart from anything else, your hand should be on the release knob during the launch This is surprising to me -- a non-winch-qualified pilot. Do you do the same for aero tow? -T8 |
#58
On Jun 23, 4:18*pm, ucsdcpc wrote:
have a look at the simulation videos on the BGA website http://www.gliding.co.uk/bgainfo/saf...nch-safety.htm you don't have a lot of time to find the release knob if a wing drops Maybe not, but it's hard to believe the wing drop simulations are representative. What reasonably trained pilots would stuff the wing into the ground and then continue to hold full aileron into the low wing? It would be interesting to see the same scenario simulated with an external upset causing the wing drop and full recovery aileron being applied at and after wing tip contact. Throw in various amounts of drag on the low wing tip to simulate short grass, long grass, etc and then introduce pilot release before, at, and after wing tip contact, and I'd start to believe it was a useful training aid. Andy |
#59
Subject changed. As J.May wrote: "We are speculating which is wrong.
Lets not insult the guys that paid a terrible price in the name of a sport we all love". That said, don't let me stop you guys from debating the cable break procedure.... |
#60
![]() At 02:41 23 June 2009, bildan wrote: Might I ask that you actually read what I wrote before correcting me. What I said is exactly what you have said but in two or three lines. On Jun 22, 6:15=A0pm, Don Johnstone wrote: Much has been said and written about winch launch failures and here is my "Guide to Surviving a launch failure" Launch fails 1 Pitch the nose down, at least approach attitude - snip I have to take issue since anyone following this advice might/will get hurt. Rubbish If you stop the pitch down at 'approach attitude' from an initial attitude of 30 - 45 degrees nose up, you will be stalled - the nose must be pushed far below 'approach attitude" to achieve prompt airspeed recovery. I said at least approach attitude, not stop at. "at least" means more may be needed but it should never be less. This is easy to demonstrate without a winch. At an altitude that allows safe spin recovery, zoom up at a 45 degree nose-up attitude. When the airspeed drops to 65 knots, pretend you have a rope break and push over to 'approach attitude' and stop the pitch down there. Note the airspeed - it will be around 20 knots. If you turn you will spin. This is a classic killer on a winch. I then said, ask the question is the speed at least approach speed only if the answer to this is yes do you go to stage two which considers turning only after considering a landing ahead. There is no counting involved, no waiting, just checking to see if the relevant conditions apply to allow the procedure to move on. It is even better to demonstrate off a simulated launch failure and the more you do the better. I agree that starting a turn before the airspeed has increased is very bad news which is why I emphasised that you do not even make the decision between landing ahead and turning, let alone doing it until the airspeed is up. |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Electric winch fatality story in August Soaring | Bill Daniels | Soaring | 0 | August 14th 04 02:37 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
