#61
(Spectra/Dyneema rope generates a much more obvious thump than steel.)
Even when it breaks at the winch end? I wouldn't know - I've not yet flown on the stuff. It doesn't matter where it breaks - the whole rope weighs around 30 Lbs so the feel in the glider is the same. Assuming the pilot is monitoring airspeed, a power fade means the nose will coming down and be down to a normal glide attitude and airspeed as power is totally lost - just as at the top of a normal launch. If its a slow fade the airspeed may easily be lower than approach speed. IME a slow fade is harder to recognize and deal with than a sudden cut or a break. Not if the pilot is controlling, or just monitoring, the airspeed. The pilot will lower the nose appropriately to maintain the selected airspeed. When the power is all gone, the glider will be gliding at the selected speed - a perfect recovery even if the pilot didn't recognize the power failure. Lowering the nose is the signal for more speed so it works in all cases. |
#62
I managed to catch a wing drop on video a couple of years ago and have seen
several others. URL is: http://www.youtube.com/watch?v=Ls_VIfxOV8U Also look at: http://flightbox.net/galleries/wingdrop/wingdrop_1.htm Last year when instructing I had a student who for some reason, possibly as a reaction to a rather rapidly accelerated winch launch, pulled the stick hard back and to the left, putting the wing tip on the ground before I could take over. I had not had any problems with this student on previous flights with him. A wing drop is most likely to occur in a semi cross wind and in turbulent conditions. In the UK we have had a fatal accident, a serious injury accident and a very badly damaged glider as a result of wing drops in the last two years. These all happened to very experienced pilots, one of whom was a Nationals level competition pilot. IT CAN HAPPEN TO YOU!!! My view is that you should keep your hand on the release knob during a launch, so that you can release quickly if things go wrong without fumbling. After a winch launch cable break, the first priority is to get the nose down and regain flying speed. However the latter will take a few seconds, during which you can pull the knob. 99% of the time the cable will back release anyway, but it might not. We had a sort of reverse incident a couple of years ago, when an early solo pilot heard a bang, probably caused by a shackle or Tost link pulling straight, and assumed that he had suffered a cable break. He lowered the nose to the recovery attitude and then dived UNDER the cable which was still attached to the glider and in one piece! Fortunately he was able to land safely straight ahead, but the glider suffered some damage from hitting the cable and then having it drop on top of the glider. Derek Copeland At 23:42 23 June 2009, Andy wrote: Maybe not, but it's hard to believe the wing drop simulations are representative. What reasonably trained pilots would stuff the wing into the ground and then continue to hold full aileron into the low wing? It would be interesting to see the same scenario simulated with an external upset causing the wing drop and full recovery aileron being applied at and after wing tip contact. Throw in various amounts of drag on the low wing tip to simulate short grass, long grass, etc and then introduce pilot release before, at, and after wing tip contact, and I'd start to believe it was a useful training aid. Andy |
#63
On Jun 23, 12:58*pm, bildan wrote:
On Jun 23, 10:10*am, T8 wrote: On Jun 23, 11:14*am, Martin Gregorie wrote: Apart from anything else, your hand should be on the release knob during the launch This is surprising to me -- a non-winch-qualified pilot. *Do you do the same for aero tow? -T8 It's a good idea for aero tow. *We can all think of accidents where a life would have been saved if the pilot had pulled the release before becoming airborne. *It's not only where you put your hand, it's also a mindset to pull off if something doesn't feel right. For example, there are several accidents over the years where pilots took off with disconnected controls. *It's much easier to tow a glider back to the start line than sweep up the pieces. There is one less Discus in the world because the pilot had his hand on the release on a bumpy day. He "in-advertently" pulled the release at low altitude and crashed into the trees. The pilot was not injured, but the glider was totaled. If you want to keep your hand on the release, then hold it some way that prevents turbulence from releasing it for you. Todd 3S |
#64
Weird stuff seems to happen in Derek's vicinity.
On Jun 24, 12:45*am, Derek Copeland wrote: I managed to catch a wing drop on video a couple of years ago and have seen several others. URL is: http://www.youtube.com/watch?v=Ls_VIfxOV8U Also look at: http://flightbox.net/galleries/wingdrop/wingdrop_1.htm Last year when instructing I had a student who for some reason, possibly as a reaction to a rather rapidly accelerated winch launch, pulled the stick hard back and to the left, putting the wing tip on the ground before I could take over. I had not had any problems with this student on previous flights with him. A wing drop is most likely to occur in a semi cross wind and in turbulent conditions. In the UK we have had a fatal accident, a serious injury accident and a very badly damaged glider as a result of wing drops in the last two years. These all happened to very experienced pilots, one of whom was a Nationals level competition pilot. IT CAN HAPPEN TO YOU!!! My view is that you should keep your hand on the release knob during a launch, so that you can release quickly if things go wrong without fumbling. After a winch launch cable break, the first priority is to get the nose down and regain flying speed. However the latter will take a few seconds, during which you can pull the knob. 99% of the time the cable will back release anyway, but it might not. We had a sort of reverse incident a couple of years ago, when an early solo pilot heard a bang, probably caused by a shackle or Tost link pulling straight, and assumed that he had suffered a cable break. He lowered the nose to the recovery attitude and then dived UNDER the cable which was still attached to the glider and in one piece! Fortunately he was able to land safely straight ahead, but the glider suffered some damage from hitting the cable and then having it drop on top of the glider. * Derek Copeland At 23:42 23 June 2009, Andy wrote: Maybe not, but it's hard to believe the wing drop simulations are representative. *What reasonably trained pilots would stuff the wing into the ground and then continue to hold full aileron into the low wing? *It would be interesting to see the same scenario simulated with an external upset causing the wing drop and full recovery aileron being applied at and after wing tip contact. *Throw in various amounts of drag on the low wing tip to simulate short grass, long grass, etc and then introduce pilot release before, at, and after wing tip contact, and I'd start to believe it was a useful training aid. Andy |
#65
On Jun 24, 8:23*am, toad wrote:
On Jun 23, 12:58*pm, bildan wrote: On Jun 23, 10:10*am, T8 wrote: On Jun 23, 11:14*am, Martin Gregorie wrote: Apart from anything else, your hand should be on the release knob during the launch This is surprising to me -- a non-winch-qualified pilot. *Do you do the same for aero tow? -T8 It's a good idea for aero tow. *We can all think of accidents where a life would have been saved if the pilot had pulled the release before becoming airborne. *It's not only where you put your hand, it's also a mindset to pull off if something doesn't feel right. For example, there are several accidents over the years where pilots took off with disconnected controls. *It's much easier to tow a glider back to the start line than sweep up the pieces. There is one less Discus in the world because the pilot had his hand on the release on a bumpy day. *He "in-advertently" pulled the release at low altitude and crashed into the trees. * The pilot was not injured, but the glider was totaled. *If you want to keep your hand on the release, then hold it some way that prevents turbulence from releasing it for you. Todd 3S First, we're really only talking about an aero tow ground roll. Once airborne in turbulent air, keeping a death grip on the release isn't a good idea. Even this isn't always possible with gliders that need spoilers retracted or flaps moved from negative during the ground roll. Still, it's a good idea to have "muscle memory" in your left hand so it can find the release in a hurry. More important is to have a mindset to pull off if you sense a problem during the ground roll. Even on a winch ground roll, I don't like a full grip on the release, just hand contact with it. That way the pilot is unlikely to pull it inadvertently but can pull it intentionally if needed. |
#66
On Jun 23, 5:42*pm, Andy wrote:
On Jun 23, 4:18*pm, ucsdcpc wrote: have a look at the simulation videos on the BGA website http://www.gliding.co.uk/bgainfo/saf...nch-safety.htm you don't have a lot of time to find the release knob if a wing drops Maybe not, but it's hard to believe the wing drop simulations are representative. *What reasonably trained pilots would stuff the wing into the ground and then continue to hold full aileron into the low wing? *It would be interesting to see the same scenario simulated with an external upset causing the wing drop and full recovery aileron being applied at and after wing tip contact. *Throw in various amounts of drag on the low wing tip to simulate short grass, long grass, etc and then introduce pilot release before, at, and after wing tip contact, and I'd start to believe it was a useful training aid. Andy It's realistic in the sense that the most likely way a wing would go down is if the pilot does, in fact, "stuff it down". Unfortunately, you just have to watch a few takeoffs to see it happen. One of my frustrations is pilots who seem to have no idea where their ailerons are until a wingtip hits the ground. If the pilot consciously centers the ailerons as part of the pre- takeoff checks and lets the wing runner balance the glider, the glider will just stay balanced on its own for several seconds after the wing runner lets go - long enough to get aileron control on either aero tow or winch. That's good practice with any launch method. |
#67
On Jun 24, 11:05*am, bildan wrote:
On Jun 24, 8:23*am, toad wrote: On Jun 23, 12:58*pm, bildan wrote: On Jun 23, 10:10*am, T8 wrote: On Jun 23, 11:14*am, Martin Gregorie wrote: Apart from anything else, your hand should be on the release knob during the launch This is surprising to me -- a non-winch-qualified pilot. *Do you do the same for aero tow? -T8 It's a good idea for aero tow. *We can all think of accidents where a life would have been saved if the pilot had pulled the release before becoming airborne. *It's not only where you put your hand, it's also a mindset to pull off if something doesn't feel right. For example, there are several accidents over the years where pilots took off with disconnected controls. *It's much easier to tow a glider back to the start line than sweep up the pieces. There is one less Discus in the world because the pilot had his hand on the release on a bumpy day. *He "in-advertently" pulled the release at low altitude and crashed into the trees. * The pilot was not injured, but the glider was totaled. *If you want to keep your hand on the release, then hold it some way that prevents turbulence from releasing it for you. Todd 3S First, we're really only talking about an aero tow ground roll. *Once airborne in turbulent air, keeping a death grip on the release isn't a good idea. *Even this isn't always possible with gliders that need spoilers retracted or flaps moved from negative during the ground roll. *Still, it's a good idea to have "muscle memory" in your left hand so it can find the release in a hurry. *More important is to have a mindset to pull off if you sense a problem during the ground roll. Even on a winch ground roll, I don't like a full grip on the release, just hand contact with it. *That way *the pilot is unlikely to pull it inadvertently but can pull it intentionally if needed.- Hide quoted text - - Show quoted text - Just remember to give these cautions to any pilot that you tell "keep your hand on the release" during takeoff. Todd 3S |
#68
I knew that agreeing with Bill Daniels was too good to last!
Given a vaguely competent pilot, the most likely cause of a wing drop is a gust, especially if there is a cross-wind component. That is what happened in the series of photos that show a K13 standing on it's starboard wingtip. I put a link into this in an earlier posting. Please note that full opposite aileron and rudder is being applied throughout this incident! On the subject of not accidentally pulling the release knob as a result of holding it, you need to arrange the cockpit so you are not holding the release at full stretch. Some glass single seaters are very good at hiding the release knob almost out of reach somewhere below your crutch and behind the stick. On my own glider I have extended the cable so it is easier to reach the knob (with the approval of a BGA Inspector I hasten to add). The last fatal cartwheel accident in the UK involved an ASW20L glider. If you read the aaib report, they concluded that once the stick was hard over to the left, which it would have been as it was the right wing that dropped, it would have been almost impossible to get to the release knob if you weren't holding it already! Derek Copeland At 15:29 24 June 2009, bildan wrote: On Jun 23, 5:42=A0pm, Andy wrote: On Jun 23, 4:18=A0pm, ucsdcpc wrote: have a look at the simulation videos on the BGA website http://www.gliding.co.uk/bgainfo/saf...nch-safety.htm you don't have a lot of time to find the release knob if a wing drops Maybe not, but it's hard to believe the wing drop simulations are representative. =A0What reasonably trained pilots would stuff the wing into the ground and then continue to hold full aileron into the low wing? =A0It would be interesting to see the same scenario simulated with an external upset causing the wing drop and full recovery aileron being applied at and after wing tip contact. =A0Throw in various amounts of drag on the low wing tip to simulate short grass, long grass, etc and then introduce pilot release before, at, and after wing tip contact, and I'd start to believe it was a useful training aid. Andy It's realistic in the sense that the most likely way a wing would go down is if the pilot does, in fact, "stuff it down". Unfortunately, you just have to watch a few takeoffs to see it happen. One of my frustrations is pilots who seem to have no idea where their ailerons are until a wingtip hits the ground. If the pilot consciously centers the ailerons as part of the pre- takeoff checks and lets the wing runner balance the glider, the glider will just stay balanced on its own for several seconds after the wing runner lets go - long enough to get aileron control on either aero tow or winch. That's good practice with any launch method. |
#69
On Jun 24, 10:45*am, Del C wrote:
I knew that agreeing with Bill Daniels was too good to last! Given a vaguely competent pilot, the most likely cause of a wing drop is a gust, especially if there is a cross-wind component. That is what happened in the series of photos that show a K13 standing on it's starboard wingtip. I put a link into this in an earlier posting. Please note that full opposite aileron and rudder is being applied throughout this incident! On the subject of not accidentally pulling the release knob as a result of holding it, you need to arrange the cockpit so you are not holding the release at full stretch. Some glass single seaters are very good at hiding the release knob almost out of reach somewhere below your crutch and behind the stick. On my own glider I have extended the cable so it is easier to reach the knob (with the approval of a BGA Inspector I hasten to add). The last fatal cartwheel accident in the UK involved an ASW20L glider. If you read the aaib report, they concluded that once the stick was hard over to the left, which it would have been as it was the right wing that dropped, it would have been almost impossible to get to the release knob if you weren't holding it already! Derek Copeland At 15:29 24 June 2009, bildan wrote: On Jun 23, 5:42=A0pm, Andy *wrote: On Jun 23, 4:18=A0pm, ucsdcpc *wrote: have a look at the simulation videos on the BGA website http://www.gliding.co.uk/bgainfo/saf...nch-safety.htm you don't have a lot of time to find the release knob if a wing drops Maybe not, but it's hard to believe the wing drop simulations are representative. =A0What reasonably trained pilots would stuff the wing into the ground and then continue to hold full aileron into the low wing? =A0It would be interesting to see the same scenario simulated with an external upset causing the wing drop and full recovery aileron being applied at and after wing tip contact. =A0Throw in various amounts of drag on the low wing tip to simulate short grass, long grass, etc and then introduce pilot release before, at, and after wing tip contact, and I'd start to believe it was a useful training aid. Andy It's realistic in the sense that the most likely way a wing would go down is if the pilot does, in fact, "stuff it down". *Unfortunately, you just have to watch a few takeoffs to see it happen. *One of my frustrations is pilots who seem to have no idea where their ailerons are until a wingtip hits the ground. If the pilot consciously centers the ailerons as part of the pre- takeoff checks and lets the wing runner balance the glider, the glider will just stay balanced on its own for several seconds after the wing runner lets go *- long enough to get aileron control on either aero tow or winch. *That's good practice with any launch method. What I see in that K-13 sequence is the parachute disappearing off the left side of the frame after it was released. It gives the appearance the glider was staged at least 30 degrees off the line of sight to the winch. I also don't see any aileron or rudder applied in the first frame with the wing on the ground indicating the pilot was WAAY behind the glider. Blaming this 100% on a gust seems a reach. |
#70
Fully agree with Derek, it stands to reason that an inadvertant cable
release at any moment in the launch is less risky that failure to release instantly if things start to go wrong. Its doesn't have to be white nuckle grip, but hlold it you must! Eventualities before launch will cover the recovery scenario for the launch ahead no matter it is a cable break or accidental/deliberate cable release. Even well away from the ground, the relative merit seems to remain. David. At 16:45 24 June 2009, Del C wrote: I knew that agreeing with Bill Daniels was too good to last! Given a vaguely competent pilot, the most likely cause of a wing drop is a gust, especially if there is a cross-wind component. That is what happened in the series of photos that show a K13 standing on it's starboard wingtip. I put a link into this in an earlier posting. Please note that full opposite aileron and rudder is being applied throughout this incident! On the subject of not accidentally pulling the release knob as a result of holding it, you need to arrange the cockpit so you are not holding the release at full stretch. Some glass single seaters are very good at hiding the release knob almost out of reach somewhere below your crutch and behind the stick. On my own glider I have extended the cable so it is easier to reach the knob (with the approval of a BGA Inspector I hasten to add). The last fatal cartwheel accident in the UK involved an ASW20L glider. If you read the aaib report, they concluded that once the stick was hard over to the left, which it would have been as it was the right wing that dropped, it would have been almost impossible to get to the release knob if you weren't holding it already! Derek Copeland At 15:29 24 June 2009, bildan wrote: On Jun 23, 5:42=A0pm, Andy wrote: On Jun 23, 4:18=A0pm, ucsdcpc wrote: have a look at the simulation videos on the BGA website http://www.gliding.co.uk/bgainfo/saf...nch-safety.htm you don't have a lot of time to find the release knob if a wing drops Maybe not, but it's hard to believe the wing drop simulations are representative. =A0What reasonably trained pilots would stuff the wing into the ground and then continue to hold full aileron into the low wing? =A0It would be interesting to see the same scenario simulated with an external upset causing the wing drop and full recovery aileron being applied at and after wing tip contact. =A0Throw in various amounts of drag on the low wing tip to simulate short grass, long grass, etc and then introduce pilot release before, at, and after wing tip contact, and I'd start to believe it was a useful training aid. Andy It's realistic in the sense that the most likely way a wing would go down is if the pilot does, in fact, "stuff it down". Unfortunately, you just have to watch a few takeoffs to see it happen. One of my frustrations is pilots who seem to have no idea where their ailerons are until a wingtip hits the ground. If the pilot consciously centers the ailerons as part of the pre- takeoff checks and lets the wing runner balance the glider, the glider will just stay balanced on its own for several seconds after the wing runner lets go - long enough to get aileron control on either aero tow or winch. That's good practice with any launch method. |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Electric winch fatality story in August Soaring | Bill Daniels | Soaring | 0 | August 14th 04 02:37 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
