SeeYou run on Apple
Old June 24th 09, 06:37 PM posted to rec.aviation.soaring
John Smith
Default SeeYou run on Apple
Andy wrote:
the OpenGL acceleration support in Parallels
generates 3D graphics performance that is noticeably faster and
smoother than Fusion.
What does this mean, is it standable or not? What hardware was used?
I can speak to support of USB serial dongles,
but will give this a try in the coming week.
This would be interesting indeed.
Old June 24th 09, 07:09 PM posted to rec.aviation.soaring
Darryl Ramm
Standable? You mean tolerable? I think on any current Mac or MacBook
you can use SeeYou under VMware Fusion or Parallels. For 3D there is
no comparison Parallels is much faster. And had it running on a modern
13" MacBook (the aluminum one just prior to the current 13" MacBook
Pro). It seems very usable and smooth. However I won't be switching
any time soon for reasons (and biases) previously mentioned. And again
this issue is one of accelerating OpenGL graphics that SeeYou uses.
Fusion and Parallels will hardware accelerate some DirectX graphics,
only Parallels hardware accelerates some OpenGL graphics - enough to
make a significant difference for SeeYou 3D. SeeYou is one of the rare
Windows apps that uses OpenGL.
For me, the more impressive thing than either Fusion or Parallels was
how dramatically better the Wine support on Mac has gotten since I
last looked. Andy had a copy of CodeWeaver CrossOver on an modern iMac
and it seemed to run quite well except There is no 3D support at all.
You just get a message in SeeYou that 3D is not available. Personally
if I did not have lots of other uses for real Windows on a Mac I would
abandon all that complexity, and the need for a Windows license and
start with CodeWeaver CrossOver. (Yes a 180 degree turn from the
earlier post). But then I just don't use the 3D graphics in SeeYou
much at all. The other think you need to do in SeeYou is write data
out for PDAs or other devices. With the ability to write SD cards and
not need to use Microsoft ActiveSync things start to get interesting
as well for not needing a copy of Windows. I am not sure if Andy has
checked this out but I'd be pretty surprised if SeeYou running under
CrossOver has any problems writing out data files etc. to an SD card
(or at least to disk so you can just drag them over). BTW ActiveSync
is broken at the best of times, and does not run on CrossOver AFAIK,
but the good thing nowadays is you often can get away without it. But
you may need to find a real Windows PC to do things like software
updates on the PDA etc.
Darryl
Old June 24th 09, 08:23 PM posted to rec.aviation.soaring
kimobear
I tried SeeYou with codeweavers basic and it works fine.
The only thing it does not do is 3D which I never use anyway.
Having made the switch to Apple MAC SeeYou was the only thing I
missed.
Thanks everybody.
Next problem to solve is finding a FAA airport data base sorted by
states to use in ClearNav.
Kimobear
Old July 19th 09, 04:27 PM posted to rec.aviation.soaring
Andy[_10_]
On Jun 24, 10:22*am, Andy wrote:
On Jun 13, 9:41*am, kimobear wrote:
Anybody have a good way to run SeeYou on a Apple Mac without
partioning the hard drive ?
In a soaring-computing geek-fest, Darryl and I compared VMware Fusion
to Parallels. Both seem now to be pretty stable products so the main
difference is that the OpenGL acceleration support in Parallels
smoother than Fusion. *I can speak to support of USB serial dongles,
9B
I was able to install the Keyspan USB-Serial adapter driver and It
runs all the diagnostics fine, but I can't seem to get it to work such
that SeeYou will talk to my LX-7000. It may be a configuration issue
or a basic compatibility problem with Parallels.
I'll keep trying as this is a fairly important need...
9B
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 11:38 AM
FS New Apple IPODS Forsale ! IN Stock ! Walmart Aviation Marketplace 0 December 19th 04 07:42 PM
