Torque Wrench Calibration
Old June 25th 09, 07:39 PM posted to rec.aviation.homebuilt
Default Torque Wrench Calibration
I was getting ready to install a replacement manifold on the old Mercury
and it occurred to me I ought to be pretty sure my torque wrench didn't
strip the aluminum threads. The Snap On dial wrench hasn't been
recalibrated for 30 years and the Craftsman torsion bar wrench is too
clumsy to get to some of the bolts. I was kicking it around and I came
up with using the torsion bar wrench on a bicycle axle nut and then
putting the dial wrench on it to see if the reading matched. It did.
Then, I went ahead and checked the Craftsman clicker wrench of the same
vintage and recalibrating, and it came up with a match also. Then I did
the torquing with the dial wrench and cross checked it with the torsion
bar wrench, with all good readings. So, I'm just going to call them
calibrated.
Andy
Phoenix
Old June 29th 09, 05:53 AM posted to rec.aviation.homebuilt
Bill
Make it so that you can pull the torsion bar wrench with the snap on--
against each other. They should read the same.
How could the torsion wrench be off if it zeros properly and nothing
in the ponter binds?
Bill Hale Loveland CO
strip the aluminum threads. *The Snap On dial wrench hasn't been
clumsy to get to some of the bolts. *I was kicking it around and I came
putting the dial wrench on it to see if the reading matched. *It did.
vintage and recalibrating, and it came up with a match also. *Then I did
bar wrench, with all good readings. *So, I'm just going to call them
calibrated.
Andy
Phoenix
Old June 29th 09, 04:26 PM posted to rec.aviation.homebuilt
Tim[_8_]
calibrated.
Andy
Phoenix
You might check around for a lab. A phone call to these guys indicate rates
of $35 to $55.
http://www.teamtorque.com/index.html
Old June 29th 09, 05:20 PM posted to rec.aviation.homebuilt
Stu Fields
calibrated.
Andy
Phoenix
Calibration can be like measuring with a micrometer and cutting with an axe.
Unbrako says that torque wrench accuracy for generating the clamping force
is +/- 25%.
For a 100 in-# set click you could be providing 75 or 125in-# instead. How
close a calibration to "truth" is needed?
Stu
Old June 29th 09, 05:35 PM posted to rec.aviation.homebuilt
[email protected][_2_]
is +/- 25%.
Stu
True, clamping force and "torque" are not always a direct
relationship. Thus the use of Torque-n-Turn specs (and other methods
of overcoming thread friction). I've never seen any specs for AN
hardware other than simple torque values. Do Torque-n-Turn specs
exist for AN hardware? Yes, I know that AN hardware isn't "torque to
yield" but the method is still of value for reusable fasteners.
Leon McAtee
Old June 29th 09, 06:25 PM posted to rec.aviation.homebuilt
jerry wass
You are correct for a bending rod type wrench--but some torque wrenches
have a spring loaded(adjustable)hollow handle that allows a piece to pop
out of a Vee notch making an audible click that is also felt in the
handle--(very handy for torquing where you can't see the dial or
pointer. Jerry
calibrated.
Andy
Phoenix
Old June 29th 09, 11:12 PM posted to rec.aviation.homebuilt
Dan[_12_]
pointer. Jerry
In the Air Farce we were supposed to click the break type torque
wrench three times at the lowest setting before using it. This was
supposed to spread the lubrication inside.
I like the idea of taking the wrench to a shop to check calibration.
Having said that, in my first shop in the USAF we calibrated torque
wrenches so I may be a tad biased. The machine we used was huge and
probably weighed close to a ton. Torque wrenches in the USAF are
periodically calibrated, I forget the cycle, and taken in for
calibration if dropped or abused.
I wonder if the electronic torque wrenches are worth the money. Has
anyone in RAH tried them?
Dan, U.S. Air Force, retired
Old June 30th 09, 02:44 AM posted to rec.aviation.homebuilt
Peter Dohm
"Dan" wrote in message
handle--(very handy for torquing where you can't see the dial or pointer.
Jerry
In the Air Farce we were supposed to click the break type torque wrench
three times at the lowest setting before using it. This was supposed to
periodically calibrated, I forget the cycle, and taken in for calibration
I have not tried the electronic variety; but my recollection is that the
click type torque wrenches were supposed to be calibrated annualy--so long
as no incident occured, such as dropping or other abuse.
Peter
Old June 30th 09, 04:53 AM posted to rec.aviation.homebuilt
coffelt2
snip
snip
Heck, Dan, in the Air Force there was an alternate torque measuring
system that didn't even require a torque wrench. (PMEL calibrated, of
course)
Simply "strip" it and back off one half turn. Farm boys from Georgia taught
me that.
Old Chief Lynn
Thin 3/8" wrench RST Engineering Home Built 10 November 17th 06 12:52 PM
Flight wrench question R.H. Piloting 14 June 25th 06 03:48 PM
Ignition lead nut-wrench jerry wass Aviation Marketplace 0 April 8th 06 03:55 AM
Wrench size for KI214 & KI201 OBS knob Roy Page Owning 7 March 11th 05 10:07 PM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
