iPAQ 310 won't shut down
Old June 30th 09, 03:13 AM posted to rec.aviation.soaring
Paul Remde
Default iPAQ 310 won't shut down
Hi,
I have been doing a lot of playing with my iPAQ 310 and SeeYou Mobile for
PNA. Somehow the unit is now in a mode in which I can't turn it off so that
it stays off while connected to the wall charger. Every time I turn it off
it turns itself right back on. If I disconnect it from the wall charger I
can turn it off and it stays off. I want to be able to charge the unit with
the unit turned off - to preserve the life of the backlight as much as
possible.
I don't think the unit did this when it was new. I have a customer's iPAQ
310 in hand and it will stay off while connected to a wall charger.
I must have adjusted some power setting, but I can't seem to figure it out.
The only thing I've installed is the screen rotate driver and SeeYou Mobile
on the SD card.
The issue occurs regardless of whether the unit is in SeeYou Mobile / WinCE
mode, or the street navigation mode.
I have rebooted the unit several times (soft reset) but I don't think there
is any way to do a hard reset. I tried removing the main battery for a few
seconds while the unit was turned on an that didn't help,.
Does anyone have any suggestions?
My next thing to try is to take the main battery out and leave it out
overnight.
Best Regards,
Paul Remde
Old June 30th 09, 03:31 AM posted to rec.aviation.soaring
sisu1a
On Jun 29, 7:13*pm, "Paul Remde" wrote:
Hi,
PNA. *Somehow the unit is now in a mode in which I can't turn it off so that
it stays off while connected to the wall charger. *Every time I turn it off
it turns itself right back on. *If I disconnect it from the wall charger I
can turn it off and it stays off. *I want to be able to charge the unit with
possible.
I don't think the unit did this when it was new. *I have a customer's iPAQ
Old June 30th 09, 04:35 AM posted to rec.aviation.soaring
brianDG303[_2_]
Hi Paul,
if you like, try the following:
Press the wheel , push the reset button, you will see the RUU MODE
screen but do not release the wheel, keep the wheel pressed for at
least ten seconds until the engineering mode comes up.
Use extreme caution, you can brick the device by selecting the wrong
entry.
Select menu item #10.
I don't know if this is a "hard reset" but it will rebuild the
registry which maybe is close enough.
By the way, I use a dedicated stand alone trickle charger that I think
gives me a longer battery life, HP part # HSTNH-F02G. I got it from
http://fixyourpda.com/ and an extra HP310 as well. One of the best
online transactions I have had.
Brian
Hi,
possible.
Old June 30th 09, 04:36 AM posted to rec.aviation.soaring
Mark628CA
Paul-
I have had geat success turning off almost all electronic devices
through the application of percussive maintenance. Simply accelerate
your electronic device towards a somewhat higher mass than the device
itself and allow deceleration to reset the aforesaid device to an
inert state.
Rebooting may be troublesome after the application of this method. Do
not neglect gathering all of the subsets of the device and
repositioning them properly before attempting a reboot.
Mark M.
Old June 30th 09, 05:52 AM posted to rec.aviation.soaring
Dave Nadler
Hi,
possible.
Old June 30th 09, 11:44 AM posted to rec.aviation.soaring
Chris Reed[_2_]
I recently had a problem with my IPAQ 3950 rebooting itself at random
intervals, and thus losing my XCSoar installation.
Online searches suggested this might be because of battery failure, so I
installed a new battery (equivalent of US$15 via eBay). It's working
fine now.
Worth trying?
Paul Remde wrote:
Hi,
for PNA. Somehow the unit is now in a mode in which I can't turn it off
so that it stays off while connected to the wall charger. Every time I
turn it off it turns itself right back on. If I disconnect it from the
wall charger I can turn it off and it stays off. I want to be able to
charge the unit with the unit turned off - to preserve the life of the
backlight as much as possible.
iPAQ 310 in hand and it will stay off while connected to a wall charger.
out. The only thing I've installed is the screen rotate driver and
SeeYou Mobile on the SD card.
WinCE mode, or the street navigation mode.
there is any way to do a hard reset. I tried removing the main battery
for a few seconds while the unit was turned on an that didn't help,.
overnight.
Best Regards,
Paul Remde
Old June 30th 09, 04:30 PM posted to rec.aviation.soaring
Paul Remde
Hi,
Thanks for the tips everyone.
It is working fine now. I'm not sure if the fix was from leaving the
battery out of the unit overnight, or from selecting "Suspend" from the
start menu. I can now turn it on and off using the on/off button and it
stays off even while connected to the wall charger.
Best Regards,
Paul Remde
"Paul Remde" wrote in message
Hi,
that it stays off while connected to the wall charger. Every time I turn
it off it turns itself right back on. If I disconnect it from the wall
charger I can turn it off and it stays off. I want to be able to charge
the unit with the unit turned off - to preserve the life of the backlight
out. The only thing I've installed is the screen rotate driver and SeeYou
overnight.
Best Regards,
Paul Remde
Old July 4th 09, 06:08 PM posted to rec.aviation.soaring
Paul Remde
Hi,
This is the most strange thing I've seen with a PDA or PNA. The unit is
again in the mode where it can't be shut off. It does shut off, but turns
back on all by itself about 3 seconds after it is turned off. This occurs
only when connected to the unit's wall charger. In my note below I stated
that the solution to the problem could have been using the "Suspend" option
from the start menu. That does not work, so I must assume that the solution
was leaving the battery out of the unit overnight without it being connected
to external power. I'll try that again after I go soaring tomorrow.
Has anyone else seen this?
Best Regards,
Paul Remde
Hi,
Best Regards,
Paul Remde
Hi,
overnight.
Best Regards,
Paul Remde
Old July 4th 09, 08:16 PM posted to rec.aviation.soaring
Dave Nadler
On Jul 4, 10:08*am, "Paul Remde" wrote:
Hi,
This is the most strange thing I've seen with a PDA or PNA. *The unit is
again in the mode where it can't be shut off. *It does shut off, but turns
back on all by itself about 3 seconds after it is turned off. *This occurs
only when connected to the unit's wall charger. *In my note below I stated
from the start menu. *That does not work, so I must assume that the solution
to external power. *I'll try that again after I go soaring tomorrow.
Best Regards,
Paul Remde
Hi,
It is working fine now. *I'm not sure if the fix was from leaving the
start menu. *I can now turn it on and off using the on/off button and it
Best Regards,
Paul Remde
Hi,
that it stays off while connected to the wall charger. *Every time I turn
it off it turns itself right back on. *If I disconnect it from the wall
charger I can turn it off and it stays off. *I want to be able to charge
Old July 7th 09, 06:30 PM posted to rec.aviation.soaring
PCool
I have reprogrammed the backlight system for HP310/2/4/6 in the XCSoar
package I am supporting.
So I know how it works, since I can control the beast automatically.
I think that for some reason you have spoiled the registry of Windows CE.
The question is: does the automatic switch on occurs also when you are
running the native Oasis car navigation software?
I mean you start the device in car navigation mode, plug it in for charging,
and then press the key to switch it off.
What software have you run that potentially could have caused this problem?
Do you have any software for flying that attempts to set backlight or power
system?
I warn people: there is NO standard way of managing backlight on windows ce,
so either the programmers have done it correctly for the 310 PNA or they may
have simply spoiled your registry and results are unpredictable.
paolo
"Paul Remde" ha scritto nel messaggio
Hi,
option from the start menu. That does not work, so I must assume that the
solution was leaving the battery out of the unit overnight without it
being connected to external power. I'll try that again after I go soaring
tomorrow.
Best Regards,
Paul Remde
Hi,
Best Regards,
Paul Remde
Hi,
overnight.
Best Regards,
Paul Remde
'twas a day when the world was shut.... Stealth Pilot[_2_] Piloting 16 June 20th 08 05:45 PM
It's put up or shut up time. Simon Robbins Rotorcraft 3 March 15th 05 11:04 PM
How to shut down a news group Lou Home Built 2 December 7th 04 06:51 PM
SHUT UP !!! YOU'LL JINX THE MISSION !!!! Ragnar Military Aviation 25 August 10th 04 09:02 AM
Volkslogger - Shut off the memory warning buzzer? BJen Soaring 16 July 29th 03 01:12 AM
