I'm curious. Can a Blackhawk, Chinook, or other large military
helicopter hover with one engine out? What is the procedure for one- engine-out operations for large helicopters? I assume no one auto rotates a 30,000 lbs helicopter??? The obvious internet searches didn't help. -Much Thanks -Charles Talleyrand |
Charles Talleyrand wrote:
I'm curious. Can a Blackhawk, Chinook, or other large military helicopter hover with one engine out? What is the procedure for one- engine-out operations for large helicopters? I assume no one auto rotates a 30,000 lbs helicopter??? The obvious internet searches didn't help. -Much Thanks -Charles Talleyrand H-3,H-53 and H-60 can auto rotate. Watching an H-53 recover from auto rotation is truly impressive. As far as I know all helicopters can auto rotate. Every helicopter crew I have been around trains to do so. As for single engine hovering they can do it depending on air density and load. Above a certain density altitude no helicopter can hover. An empty H-53 or H-60 can take off on a single engine at sea level. An H-3 can take off on a single engine, but given the choice I'd prefer number one engine since the other tends to run a tad weak due to the FOD shield. I can't provide citations for any of this since I am only going by experience. Dan, U.S. Air Force, retired |
![]() "Charles Talleyrand" wrote in message ... I'm curious. Can a Blackhawk, Chinook, or other large military helicopter hover with one engine out? Darn! I thought this was going to be a glider question. Vaughn |
![]() "vaughn" wrote in message ... "Charles Talleyrand" wrote in message ... I'm curious. Can a Blackhawk, Chinook, or other large military helicopter hover with one engine out? Darn! I thought this was going to be a glider question. Vaughn It is when you are in a full dead engine autorotation. The SSA doesn't really recognize them as such, but will accept your membership fee anyway. However the sink rate is more like 1800'/min @ 60mph. |
On Jul 16, 4:07*am, Dan wrote:
Charles Talleyrand wrote: I'm curious. *Can a Blackhawk, Chinook, or other large military helicopter hover with one engine out? *What is the procedure for one- engine-out operations for large helicopters? *I assume no one auto rotates a 30,000 lbs helicopter??? The obvious internet searches didn't help. -Much Thanks -Charles Talleyrand * *H-3,H-53 and H-60 can auto rotate. Watching an H-53 recover from auto rotation is truly impressive. As far as I know all helicopters can auto rotate. Every helicopter crew I have been around trains to do so. * *As for single engine hovering they can do it depending on air density and load. Above a certain density altitude no helicopter can hover. * *An empty H-53 or H-60 can take off on a single engine at sea level.. An H-3 can take off on a single engine, but given the choice I'd prefer number one engine since the other tends to run a tad weak due to the FOD shield. If the large helicopters can autorotate, and cannot hover with a reasonable load on just one engine, why do they have two engines? It would seem that you would have smaller odds of failure with one large engine rather than two smaller engines. If you have two engines, and failure of either leaves you kinda screwed, it is not better to just have one engine? Or am I missing something? -Curious -Charles Talleyrand |
In message
, Charles Talleyrand writes If the large helicopters can autorotate, and cannot hover with a reasonable load on just one engine, why do they have two engines? Because it's often cheaper & easier to use two engines rather than one for the power needed - you don't end up with an exaggerated hunchback from one big turbine & gearbox. (Or three engines, as some types - our Merlin, the US Sea Stallion - go for.) Even small helicopters often have two engines, such as our Lynx, especially if they expect to get shot at. It would seem that you would have smaller odds of failure with one large engine rather than two smaller engines. If you have two engines, and failure of either leaves you kinda screwed, it is not better to just have one engine? Or am I missing something? "It's better to lose *an* engine than *the* engine." Not being able to hover doesn't mean you can't sustain flight: if you're in cruise, you get a lot of lift from the rotor disc and can stay airborne on a lot less power than you need for a hover. (Landing may be interesting, but autorotating or a rolling landing are both options). On the other hand, with one engine, losing it means autorotating in *now*. -- He thinks too much, such men are dangerous. Paul J. Adam |
On Jul 17, 8:42*am, Charles Talleyrand wrote:
On Jul 16, 4:07*am, Dan wrote: Charles Talleyrand wrote: I'm curious. *Can a Blackhawk, Chinook, or other large military helicopter hover with one engine out? *What is the procedure for one- engine-out operations for large helicopters? *I assume no one auto rotates a 30,000 lbs helicopter??? The obvious internet searches didn't help. -Much Thanks -Charles Talleyrand * *H-3,H-53 and H-60 can auto rotate. Watching an H-53 recover from auto rotation is truly impressive. As far as I know all helicopters can auto rotate. Every helicopter crew I have been around trains to do so. * *As for single engine hovering they can do it depending on air density and load. Above a certain density altitude no helicopter can hover. * *An empty H-53 or H-60 can take off on a single engine at sea level. An H-3 can take off on a single engine, but given the choice I'd prefer number one engine since the other tends to run a tad weak due to the FOD shield. If the large helicopters can autorotate, and cannot hover with a reasonable load on just one engine, why do they have two engines? *It would seem that you would have smaller odds of failure with one large engine rather than two smaller engines. *If you have two engines, and failure of either leaves you kinda screwed, it is not better to just have one engine? Or am I missing something? -Curious -Charles Talleyrand- Hide quoted text - - Show quoted text - They might not be able to sustain a hover but they are likely to be able to maintain altitude in level flight. In other words, the remaining engine will allow them to fly to a more convenient crash site! |
On Jul 17, 8:54*am, "Paul J. Adam"
wrote: In message , Charles Talleyrand writes If the large helicopters can autorotate, and cannot hover with a reasonable load on just one engine, why do they have two engines? Because it's often cheaper Really? & easier Really? to use two engines rather than one for the power needed - you don't end up with an exaggerated hunchback from one big turbine & gearbox. (Or three engines, as some types - our Really? A bit different for the heavies, but light twins such as A109 and AS355 cost more to purchase, fly and maintain than their single siblings A119 and AS350, and offer little or no performance benefit (in fact AS355 has less performance than AS350B3). In addition to double the engine maintenance, twins have an additional gearbox element to maintain. Merlin, the US Sea Stallion - go for.) Even small helicopters often have two engines, such as our Lynx, especially if they expect to get shot at. Now you are talking. It would seem that you would have smaller odds of failure with one large engine rather than two smaller engines. *If you have two engines, and failure of either leaves you kinda screwed, it is not better to just have one engine? Or am I missing something? "It's better to lose *an* engine than *the* engine." Not being able to hover doesn't mean you can't sustain flight: if you're in cruise, you get a lot of lift from the rotor disc and can stay airborne on a lot less power than you need for a hover. (Landing may be interesting, but autorotating or a rolling landing are both options). On the other hand, with one engine, losing it means autorotating in *now*. Yep. That second engine will get you out of enemy territory to a friendly crash location. -- He thinks too much, such men are dangerous. Paul J. Adam |
In message
, JohnO writes On Jul 17, 8:54*am, "Paul J. Adam" If the large helicopters can autorotate, and cannot hover with a reasonable load on just one engine, why do they have two engines? Because it's often cheaper Really? Yes, if you have two engines each providing half the horsepower compared to having to develop a new engine. (Changes if there's an off-the-shelf turbine that puts out the required power, of course) & easier Really? Yes, depending on dimensions and gearing. to use two engines rather than one for the power needed - you don't end up with an exaggerated hunchback from one big turbine & gearbox. (Or three engines, as some types - our Really? Yes, really. A bit different for the heavies, but light twins such as A109 and AS355 cost more to purchase, fly and maintain than their single siblings A119 and AS350, and offer little or no performance benefit (in fact AS355 has less performance than AS350B3). Absolutely so. Now, how often do they get shot at, flown through brownouts, and so forth? The flipside argument - why do light twins like the A109 and AS335 ever sell, if they're so much more expensive for no apparent benefit? "It's better to lose *an* engine than *the* engine." Not being able to hover doesn't mean you can't sustain flight: if you're in cruise, you get a lot of lift from the rotor disc and can stay airborne on a lot less power than you need for a hover. (Landing may be interesting, but autorotating or a rolling landing are both options). On the other hand, with one engine, losing it means autorotating in *now*. Yep. That second engine will get you out of enemy territory to a friendly crash location. Which is why many of the later UH-1s went twin-engine and so many military helos like to have more than one powerplant, even if it's less strictly efficient than a single engine. Being able to jettison payload and limp home, or at least to pick a safer spot to come down, can be quite important to the aircrew. -- He thinks too much, such men are dangerous. Paul J. Adam |
On Jul 17, 10:32*am, "Paul J. Adam"
wrote: In message , JohnO writes On Jul 17, 8:54*am, "Paul J. Adam" If the large helicopters can autorotate, and cannot hover with a reasonable load on just one engine, why do they have two engines? Because it's often cheaper Really? Yes, if you have two engines each providing half the horsepower compared to having to develop a new engine. (Changes if there's an off-the-shelf turbine that puts out the required power, of course) No need to develop a new engine. Just use an existing one. *& easier Really? Yes, depending on dimensions and gearing. to use two engines rather than one for the power needed - you don't end up with an exaggerated hunchback from one big turbine & gearbox. (Or three engines, as some types - our Really? Yes, really. Again, I restrict myself to light twins, and if you look at the examples I gave the bulgy profiles are always on the twins not the singles. Two small engines always take more space than one large one. The gearbox for twins is always bigger than for singles due to the requirement to combine them. A bit different for the heavies, but light twins such as A109 and AS355 cost more to purchase, fly and maintain than their single siblings A119 and AS350, and offer little or no performance benefit (in fact AS355 has less performance than AS350B3). Absolutely so. Now, how often do they get shot at, flown through brownouts, and so forth? Well it would be very difficult to find any helicopter with a track record for surviving battle damage than a single engined Huey. The flipside argument - why do light twins like the A109 and AS335 ever sell, if they're so much more expensive for no apparent benefit? In large part it's due to regulations mandating their use. I would like to see statistics showing they are any safer than singles. "It's better to lose *an* engine than *the* engine." Not being able to hover doesn't mean you can't sustain flight: if you're in cruise, you get a lot of lift from the rotor disc and can stay airborne on a lot less power than you need for a hover. (Landing may be interesting, but autorotating or a rolling landing are both options). On the other hand, with one engine, losing it means autorotating in *now*. Yep. That second engine will get you out of enemy territory to a friendly crash location. Which is why many of the later UH-1s went twin-engine and so many military helos like to have more than one powerplant, even if it's less strictly efficient than a single engine. Being able to jettison payload and limp home, or at least to pick a safer spot to come down, can be quite important to the aircrew. Which is exacly what I said. -- He thinks too much, such men are dangerous. Paul J. Adam |
Operation Chastise - Lancaster B1 engine servicing | Dave Kearton[_3_] | Aviation Photos | 14 | May 28th 09 02:03 PM |
Engine-out procedures and eccentric forces on engine pylons | Mxsmanic | Piloting | 18 | May 26th 07 01:03 AM |
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg | J3mia03@yahoo.com | Aviation Photos | 1 | April 11th 07 04:48 PM |
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg | J3mia03@yahoo.com | Aviation Photos | 0 | April 9th 07 01:38 PM |
1710 allison v-12 engine WWII p 38 engine | Holger Stephan | Home Built | 9 | August 21st 03 08:53 AM |
