OT WWII Memoirs (was SAFE Winch Launching ...)
Old July 27th 09, 07:15 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
Default SAFE Winch Launching - Constant Tension
At 17:23 27 July 2009, Peter Scholz wrote:
Don Johnstone wrote:
If you were to say that measuring the tension at the glider release
and
using telemetry to pass this information to the winch then that might
indeed work, however if you were going to the trouble of doing that
you
might as well send useful information, like the airspeed of the
glider,
so
the winch driver could maintain a constant speed.
Cable tension during a winch launch has sod all to do with anything
except
as an indicator to the winch driver of possible over or underspeed. It
is
the speed which is of relevance and importance.
We have recently tested the Launch Assistent that is sold by Skylaunch,
http://www.skylaunchuk.com/index.htm
and have found that is can be (as the name indicates) an *assistant* to
the winch driver to help him/her judge the speed of the plane. It helps
escpecially unexperienced winch drivers, or in adverse conditions like
shearing winds within the launch.
After 20 years of experience as a winch driver and winch instructor
(Tost winch) I still believe a well instructed and experienced winch
driver (and all winch drivers should have a certain minimum of launches
per year) is able to judge and control the launch as good (or even
better) than any automated (tension-controlled) system, that in the end
also relies on the correct behavior of the pilot instead of the winch
driver.
Peter Scholz
ASW 24 JEB
Well, there you have it, problem solved by superior and relevant British
engineering and at reasonable cost.
Tension controlled winches are obsolete already as we have jumped a
stage.
Any move to automatic winch driving would be a big big mistake, a good,
well trained winch driver is the best way of ensuring safety.
Automatic takeoff, automatic landing, automatic crash.
Old July 27th 09, 09:03 PM posted to rec.aviation.soaring
Peter Scholz[_2_]
If you were to say that measuring the tension at the glider release and
indeed work, however if you were going to the trouble of doing that you
glider, so
except
as an indicator to the winch driver of possible over or underspeed. It is
driver.
Peter Scholz
ASW 24 JEB
There has been some interesting scientific research beeing done on this
topic by the Akaflieg group of the University of Karlsruhe (Germany)
some years ago. It would go to far describing it in detail, but one
diagram where they measured a winch launch is quite interesting:
http://www.akaflieg.uni-karlsruhe.de...%20Schlepp.pdf
The parameters measured we
Height (blue)
Airspeed (magenta)
Torque at winch drum axle (dark blue)
elevator position (green)
Acceleration in x-direction (brown)
Acceleration in z-direction (yellow)
It shows that what appears to be a relative smooth winch launch, looking
at airspeed and height, has a quite significant variation in torque,
elevator position and acceleration.
The findings of this sientific work in one simple sentence: A simple
"constant tension" cannot cope with all the parameters that influence a
winch launch and that are dependent on eacht other.
So the (also economically) best approach would be to aid the winch
driver doing his job right instead of inventing a highly sophisticated
fuzzy logic system that may take into account all parameters to act as
well as a winch driver.
The goal is not to have winch launches that are all perfect and one as
optimal as the other, but the goal has to be to have safe winch launches
with an acceptable performance. And safety lies within a quite large
corridor.
Peter Scholz
ASW 24 JEB
Old July 27th 09, 09:06 PM posted to rec.aviation.soaring
Bruce
Back to metrics - if you are measuring the wrong thing, the best you can
hope for is that it is irrelevant...
So - for a "good" winch, there are a couple of things you may want to
measure.
How much does it cost?
- Capital to purchase (and how long it lasts)
- Operating cost to service and run
- Repair cost when something breaks (including damage to the gliding fleet)
- How fast can it launch relative to requirement
Is it safe?
- How easy is it to control the acceleration?
- How easy is it to achieve the correct speed in all phases of the launch?
- How well does the set up accommodate for unexpected events (big
thermal, windshear, pilot error)
So far my experience and inclination tend to support the theory that the
key requirements to satisfy the above favour simplicity and human
control. I am a computer / automation professional, but there are some
things I would prefer a human doing. Driving and controlling the winch
is one of those. There are too many variables to concern yourself with.
As an exercise - Let's test a theory. (in the empirical sciences the
difference between a theory and an idea being that a theory can be
disproved by observation and deduction).
Lets say that my theory is that relying on a single metric for control
of a winch - specifically cable tension as measured anywhere on the
cable or drum is safe.
OK - can we disprove that? -
Let's say for argument that the pilot fails to rotate appropriately. For
any number of reasons. Constant tension must be applied in this model,
so energy transfer continues to be done and the glider speed increases
as there is no increase in potential energy.
After a very short period the glider is past Vw and the pilot dare not
rotate. If the pilot is incapable of, or is slow at releasing (for
whatever reason) the speed will continue to increase, as the available
landing area is consumed at an ever increasing rate. Clearly this is
not a safe situation.
Let's argue a different approach - Now let's say for argument that the
belief that the control over tension in the cable is so good that we
have disregarded the weak link specification and are relying on the
ability of the system to regulate tension. Now we follow a launch where
the cable predictably hooks on some grass causing a bow in the run. At
the all out the grass resists the considerable lateral pressure
momentarily, the winch achieves designed tension. Then the rope/wire
breaks free of the grass and the bow becomes slack cable. In attempting
to maintain tension the winch accelerates, removing the slack. At some
point in time the cable becomes straight, all slack has been absorbed
and the cable tension rapidly increases past the design tension.
Consider the reaction time of the system, given the rotational inertia
of the drum and transmission, to say nothing of the whip action on the
cable as the wave travels toward the aircraft. Once again I fail to see
how this is going to be safe.
In this case the judgement available in a manual control system
increases safety - you can't rely on automation to magically create
safety.
So what can we deduce?
Basically you are trying to measure how well a complex and potentially
dangerous operation is progressing. In a constantly changing medium,
with multiple sources of error and variance (not least caused by the
multiple human inputs) I know it is very tempting to believe that there
is one thing you have to worry about and it will all work out perfectly.
Regrettably this is a little like perfect landings. Rumour has it there
are only three things you have to get right. Problem is no-one can agree
on which three things...
In a winch launch one needs to decide on what to do based on aircraft
speed, height, position relative to the available runways, terrain and
traffic. Always considering the capabilities of the aircraft, pilot,
winch driver and not least the prevailing weather.
Clearly - Relying on one metric is dangerous oversimplification.
Now a tension limited winch may be a good thing, and a winch that can
smooth the tension in the cable to avoid spikes would be desirable.
And certainly I have seen some scary old manual winches. Funny thing is
- as long as you have people who communicate about what the performance
and experience is, and who learn and adapt to the vagaries of whatever
winch they are using. It tends to work. Usually surprisingly well.
So - in reality the technically complex winches use a lot of technology,
and then rely on the same judgement that a lot simpler and cheaper winch
uses.
To quote Hydrowinch
"The Hydrostart winch still runs on the original automatic force and
speed control software. A manual override is just one of the regulatory
safety features that have been there since the winch is in operation.
Because when it comes to safety, we can only rely on the winch driver's
judgement. The automatic control system is not running the winch. It's
there to assist the winch driver maintaining a constant quality and
launch performance."
Is this system better and safer - From an engineering perspective ,
definitely. Is is better value for money and safer than the person using
it? Unfortunately not.
Now - if people put as much effort into building and using the things as
is getting put into this debate - we would be doing well.
So far - lots of attempts to substitute technology have been
unsuccessful at displacing simple , robust semi manual systems with
proven reliability and controlability. There may be a prefect winch
design out there, and so far the evidence indicates that this is
something less than over engineered.
Again I submit - the metrics that matter are safety and economy.
For safety you need reliability, and controlability.
For economy you need simplicity, robustness and maximum use of "off the
shelf" components.
The only place I could possibly see justifying a technological super
winch, would be in a very high launch intensity 7 days a week operation.
If anyone can, and desires to make a better winch than any of the
commercial alternatives out there, profitably. Please do so - there are
customers who would love to make you commercially successful.
If you want to , and can afford to use/build something as far into the
overkill region as a Hydrostart, be grateful and enjoy the toys. Just
don't expect great economy/commercial success. As a technocrat - I would
love one. As a club member it would be a financial, maintenance and
operational disaster. Our best winch driver loves spending hours a day
getting the best out of our ancient single drum - but he can't use a
computer... Personally, I would love to be able to put a new "Skylaunch"
style winch at his disposal. It's the same reason the much maligned
Windows OS dominates desktops. It is not the "best" but it works for
most...
Bruce
Damn - I'm feeding trolls....
As I see it the "constant tension" theory relies on being able to measure
the tension being exerted on the glider release at the winch drum. Quite
how this might be achieved is very puzzling and has no relevance to the
information required to give a safe and effective launch.
might as well send useful information, like the airspeed of the glider, so
Cable tension during a winch launch has sod all to do with anything except
At 13:15 27 July 2009, Del C wrote:
The 'constant tension' theory of winch launching was dreamed up by
someone in the US who has no practical experience of winch launching
whatsoever!
So far nobody has managed to built a true tension winch (which would
measure actual cable tension), so we don't know if the theory would
work
or not. The concept seems to have become a bit of a Holy Grail in the
US,
which is probably inhibiting the design and building of more
conventional
winches that would work just fine.
On the Yahoo Winch Design site I have suggested carrying out some
autotowing experiments, where it would fairly easy to mount an in-line
load cell to find out if CT would work, but this suggestion was rejected
by the above person and his followers as not being relevant due to the
mass and inertia of the towcar. Such an experiment would work in calm
conditions.
There are a number of constraints in real life winch launching.
1) The minimum airspeed has to be at least 1.3 x the normal stalling
speed
(Vs), to avoid the risk of stalling or spinning at the increased wing
loading due to the cable pull. At the high levels of pull suggested this
might increase to 1.4 Vs.
2) The optimum climbing airspeed for best gain of height seems from
practical experience to be in the range 1.5-1.6Vs.
3) Most gliders have a fairly low maximum winch launching speed (Vw),
which is set for structural reasons. There should also be a weak link
(fuse) included in the cable line which will break before the glider
does.
4) Many gliders, particularly older ones such as the K13, only have a
very
limited speed range in which they will climb safely and well without
exceeding Vw. The stalling speed of a K13 can increase to over 50knots
near the top of the launch, its optimum climb speed is about 56knots and
its Vw is 58knots. Some more modern types such as the K21 are a bit more
speed tolerant.
5) You have to fly the glider in such a manner that you can always
recover from a cable break or winch power failure, and not risk a stall
or
flick spin. This entails a fairly shallow initial climb followed by a
controlled rotation rate of not more than 10 degrees per second. I
believe
the Germans once managed to kill 12 pilots in one year (1995) by
carrying
out what are known as 'kavalier starts' where the glider climbs very
steeply straight off the ground to maximise height. We have also had a
few
such accidents in the UK, always on very powerful winches so rapid
acceleration doesn't make them safe.
The theory behind constant tension is you provide a pull or tension that
is close to the breaking strain of the weak link. Thus you maximise the
pull and the height gain in accordance with the Goulthorpe formula:
h = P/W/(1+P/W) x l
where h = height, P= Pull, W = glider weight and l = notional cable run
from the point of rotation.
Thus for a Pull equal to the weight of the glider you would expect to
get
a height of 50% of the effective cable length.
However, the above equation is idealised and assumes zero cable weight
and
zero drag, and is based on 100% transfer of energy.
For many years I launched on very powerful manually driven Tost winches.
Many of the launches were way over Vw until you signalled too fast, but
it
was quite rare to break a weak link in the early part of the climb. I
therefore suspect that the constant tension as a large fraction of the
weak link strength idea would just vastly overspeed the launches. In
order
to contain the speed according to the theory, you would have to climb at
an
achieved climb angle of about 60 degrees. Most gliders run out of up
elevator well below this angle. Such an angle would also represent more
than a 'kavalier start' as described above!
The other idea in the 'constant tension' theory is that the glider
pilot
would control the speed by pulling back harder to slow the launch down
and
easing forward to speed up. However I worry that a pilot trying to
control
the speed at the same time as the winch is trying to sense and control
tension would just lead to an oscillating or hunting situation. As a
winch
driver myself, I always try to avoid 'chasing the glider pilot' as
this
generally makes things worse. If I have to make a speed adjustment I
just
move the throttle to a slightly different setting and then hold it still
again. The technique for controlling the airspeed from the glider end
does
work on a Skylaunch winch where you are giving a constant power setting
and
also works on constant torque Supacat (diesel + fluid flywheel))
winches.
With either type of winch you have to start backing off the throttle
setting near the top of the launch to avoid overspeeding the glider.
We don't know if constant tension would give a constant and appropriate
airspeed, or whether it would need to be varied for different stages of
the launch to achieve this.
Derek Copeland
At 19:45 26 July 2009, Don Johnstone wrote:
As interesting as it is the discussion about who did what in the last
war
has about as much relevance to gliding and safe winching as a tesion
controlled winch.
The differences are too numerous to mention except that a Spitfire,
Hurricane and Mustang all worked and did a useful job, unlike the
mythical
tension controlled winch.
Old July 27th 09, 09:39 PM posted to rec.aviation.soaring
Bruce
Look at what MEL does -
http://www.machinefabriek-el.nl/content_16.asp
This is the manufacturer to the reasonably conventional "Leopard" winch
and of the "van Gelder" - probably the most sophisticated winch actually
working.
I wonder what proportion they are made in.
But anyway - as examples.
Note the engines are Volvo Penta diesel...
And they measure lots of things, and still get manually driven - albeit
with exquisite control.
Interestingly there are reports of clubs reverting from van Gelder to
Skylaunch (or equivalent) with retrieve setups with better launch rates.
Something to do with complexity and maintainability and cost. Any one
with actual experience?
Bruce
measure.
Is it safe?
increases safety - you can't rely on automation to magically create safety.
uses.
To quote Hydrowinch
shelf" components.
most...
Bruce
glider, so
except
whatsoever!
work
US,
conventional
conditions.
speed
does.
very
speed tolerant.
or
believe
carrying
few
h = P/W/(1+P/W) x l where h = height, P= Pull, W = glider weight and
get
and
it
order
an
pilot
and
control
winch
this
just
does
and
winches.
Derek Copeland
war
controlled winch.
mythical
Old July 27th 09, 11:45 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
actually
working.
Bruce
I flew off a Munster Van Gelder winch for 10 years and when it was working
it gave the smoothest launches I have ever had. It was fitted with
automatic drum engagement which was permanently switched off as the
drivers could do the selection much more efficiently. The control systems
were very very complex and it required many hours of maintenance during
the week to make sure it would run for the weekend. If it had been a
private club it would never have worked but the Royal Air Force had the
manpower to keep it maintained. Despite this many of the advanced systems
did not work. The winch drivers however were well trained and in the main
skillful so they worked round many of the minor problems. The winch was a
perfect example of a complex and technically advanced machine which did
not stand up to the rigors of being operated in the real world, it was
just too complex. Following that I flew for 7 years at a club using a
Skylaunch. The ability to accelerate the glider was not much less than the
MVG but it was nowhere near as smooth. The engineering was simple, one
could say agricultural, but that was it's main saving, there was nothing
complex to go wrong. The winch was made up of well tried and test indusrty
standard units which worked even with minimal servicing and I do mean
minimal. The only critisism I would make is that some of the engineering
was not agricultural enough to stand up to the abuse of club member winch
drivers. Bits fell off from time to time but the the winch engine,
transmission and drums continued to work and work well.
The MVG winch and the Skylaunch winch do the same job but the MVG does it
with much less effort. The MVG has 6 drums and it was a minor miracle if
they were all available for use. It drank deisel like there was no
tomorrow.
The Skylaunch has two drums and you could purchase 2 Skylaunch winches = 4
drums for the same amount the RAF paid for the MVG 15-20 years ago.
My current club operates a Supercat winch modified by Skylaunch to take
their engine, transmission and control. It is certainly as good as a
standard Skylaunch and has almost no downtime. They all run on LPG. (It's
what passes for cheap fuel in the UK)
With winches I believe that the KISS principle is essential
Old July 28th 09, 06:45 AM posted to rec.aviation.soaring
Derek Copeland[_2_]
I understand that the Van Gelder (MVG) winch at Dunstable (UK) is taken out
of service for half a day each week for routine maintenance and for one
week a year for a major overhaul. This done during their competition week
when they only aerotow.
In comparison, the Skylaunch is much like a modern automobile in that you
just check the levels and give it a daily inspection (DI) every day, and
change the oil, filters and the cables every so many thousand launches.
One of the reasons Lasham decided to change from Tost to Skylaunch (apart
from better launches) was that our long serving maintenance engineer
reached retirement age and the Tosts required quite a lot of servicing and
maintenance, and an annual rebuild which took about a month each. We did
these in the winter, but we still operate then, so if anything went wrong
with the winch in service we had no backup.
When we first started winch launching we tested a 6-drum MVG winch, which
as a driver I found really impressive with lots of flashing lights and
hydraulic and pneumatic systems. However it was very expensive and it was
felt that it was rather putting all our eggs in one basket. Particularly
when we (not me BTW) had a foul up which wrapped a cable many times around
the common drive shaft and put the whole thing out of operation for nearly
two hours. In the end we decided to buy two much more basic two drum Tosts
on the grounds that if you had a major foul up or a problem on one, you
could continue to launch with the other.
Incidentally I believe that the World Record height for a glider winch
launch (over 1500m) is currently held by the relatively simple MEL Leopard
winch, and was previously held by a slightly modified Tost fitted with
higher capacity drums. See:
http://www.youtube.com/watch?v=zFKsjDIjmDg
http://www.youtube.com/watch?v=-VlRd9-wxQI
Derek Copeland
winch
actually
working.
rates.
Bruce
working
systems
systems
main
a
nothing
indusrty
winch
it
tomorrow.
4
(It's
Old July 31st 09, 02:15 PM posted to rec.aviation.soaring
Del C[_2_]
Yesterday, launching into a moderate headwind at Lasham on a Skylaunch
winch, we were getting better than 2000ft launches from a 1200 metre run
in K13 and K21 training gliders. The best launch in a K21 was 2500ft.
This was using 4.5mm stranded steel cable, so we might have got a couple
of hundred feet higher using lightweight synthetic cables.
There were no cable or weak link breaks, frightening incidents, or launch
failures of any sort, despite rather gusty conditions.
Derek Copeland
Old July 31st 09, 07:00 PM posted to rec.aviation.soaring
Jim White[_3_]
launch
Derek Copeland
Good grief Del, give it up. I am sure the yanks are as bored of this
thread as we are.
Old July 31st 09, 09:08 PM posted to rec.aviation.soaring
Bob
We have the Skylaunch telemetry installed in one of our ships as a
trial, and have found it to be a very useful tool for the winch
driver. The winch cab display "lights up" at about the time of
rotation and a quick scan of the glider airspeed is very useful in
assessing the airspeed trend during the climb. It is particularly
useful as the glider begins the round out as an airspeed cue during
the reduction in line tension. The low cost makes this a very nice
innovation and we plan to install the units in our other club gliders.
Bob
On Jul 27, 1:45�pm, Derek Copeland wrote:
Skylaunch sell a telemetry system called 'Launch Assistant' which relays
the actual airspeed of the glider to an LCD display mounted somewhere in
the view of the driver. It costs a few hundred dollars in total. See:
Derek Copeland
At 16:49 27 July 2009, Chris Nicholas wrote:
At Feshiebridge, Scotland, AIUI they developed telemetry for
indicating glider airspeed to the winch driver, and it was said to
work very well. IIRC, it did not send an airspeed number in knots, but
rather an indication of too slow, a bit slow, OK, a bit fast, or too
fast (or something like that) which is what the winch driver really
needs to know, they believed. The unit in the glider was calibrated
for the glider type.
It needs somebody with first hand experience of it to tell more, and I
don=92t know if it has been kept going.
Chris N.- Hide quoted text -
- Show quoted text -
Old August 1st 09, 05:45 AM posted to rec.aviation.soaring
Derek Copeland[_2_]
run
couple
launch
Derek Copeland
thread as we are.
Just because you can't winch launch at Booker Gliding Club because of all
the helicopters and light aircraft you share Wycombe Air Park with...!
I'm only trying to convert the Colonials (and Booker pilots) to the true
faith. Why don't you move a few miles and fly at Bicester or Lasham where
they do winch launch? Bicester is almost the perfect winch launching site,
being approximately circular so that they can always launch into wind.
Del C
SAFE Winch Launching Derek Copeland[_2_] Soaring 185 August 2nd 17 07:12 PM
SAFE Winch Launching and automatic gearboxes bildan Soaring 2 July 20th 09 07:17 PM
SAFE Winch Launching and automatic gearboxes bildan Soaring 0 July 20th 09 05:25 PM
FA: WWII Navy / Career Airline Pilot's Book of Memoirs [email protected] Aviation Marketplace 0 July 31st 05 02:19 AM
FA: WWII Navy / Career Airline Pilot's Book of Memoirs [email protected] Aviation Marketplace 0 July 25th 05 02:55 PM
