#41
On Jul 26, 11:41*pm, D Ramapriya wrote:
Has any of you has ever discovered something during the pre-flight inspection that necessitated a significant deferrment of your flight plan or a cancelation altogether? Just curious, that's all. Thanks, Ramapriya Rubbing noise when checking aileron = interconnect spring came off - canceled flight Bad mag during runup couldn't clear - canceled flight |
#42
In article , lefty133
@bellsouth.net says... "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. How on earth did your pre-flight (spin the prop over?) not catch that one! ![]() -- Duncan |
#43
On Mon, 27 Jul 2009 19:39:29 -0400, Mike Ash wrote:
In article , Gezellig wrote: On Mon, 27 Jul 2009 00:04:45 -0700, Ron Garret wrote: Depends on what counts as "significant deferrment" and what counts as "pre-flight". Which begs this question. How bad does a wood prop have to be to cancel a flight? I was going to take a flight in a DA20 which has a twin blade Sensenich W69EK7-63 wood propeller. On pre-flight, the prop was chipped in several places, no runs but then its painted or enameled white. http://www.controller.com/images/Con...e/80614723.jpg The edges were so rough I was concerned about catching a splinter. I passed. And you? I'm not a propellor sort of guy, but rough enough to catch a splinter would be a definite no-go for me! Being that messed up sounds like a potential structural problem to me. I'd bet that it's *probably* just cosmetic, but I hate to bet on probablies. Having a blade suddenly fail would ruin your whole day.... Dave added: That would be a pass for me! I would stop right there...... For a friend here.... he passed on 3 spinner cracks on a rental 172. One crack was 1 1/2 in long. They (others) continued to fly the aircraft for another week before the spinner was removed Dave Thanks, guys, I was really shocked as the local CFI had no problemo with this prop which was on a student trainer. |
#44
On Tue, 28 Jul 2009 16:48:00 +1200, Dave Doe wrote:
In article , lefty133 @bellsouth.net says... "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. How on earth did your pre-flight (spin the prop over?) not catch that one! ![]() It is obvious that Vaughn is very inexperienced. |
#45
Franklin "Franklin wrote: On Mon, 27 Jul 2009 14:25:04 -0700, Ron Garret wrote: In article , "Peter Dohm" wrote: "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. Heh, funny you should mention that. I once forgot to remove an orange cone that the FBO had "helpfully" placed in front of the prop. It's amazing what a propeller -- even one not moving at full speed -- can do to an orange cone. That one set me back quite a bit as well. rg Are cones expensive or are your poor? Franklin Cones are cheap, but engine rebuilds after a prop strike aren't. (I was, of course, referring not to money, but to the time it took to consult with a mechanic to convince myself that a rebuild would not be necessary.) rg |
#46
On Mon, 27 Jul 2009 18:14:03 -0400, Franklin "Franklin
wrote: On Mon, 27 Jul 2009 14:30:57 -0500, Maxwell wrote: Badly frayed cable on the horizontal stabilizer. AI caught it while fueling the aircraft. Showed it to the pilot who decided it would make back home, about 30 miles. AI actually begged his pax to stay behind. At about 200' on take off the cable failed. Aircraft did a complete loop impacting the ground at about a 60 degree angle. Nothing left of the aircraft more than knee high. Engine buried about 2'. Pilot died instantly, but the pax with all broken bones, struggled for help for almost 5 minutes before expiring. The guilt you should feel for not stopping both of them. What a cad you are. Franklin franklin you should be ashamed of yourself. you have no details of the incident other than what maxwell posted so you are not in a position to judge him. you have no idea what condition the cable actually was. if the aircraft was refuelling it made the last flight ok and there is nothing to say that the pilot may have been correct. in this world you are free to make your own choices ...and wear the consequences. when was the last time you flew an aircraft? tragic as it was maxwell isnt to blame. Stealth pilot |
#47
"Dave Doe" wrote in message
... In article , lefty133 @bellsouth.net says... "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. How on earth did your pre-flight (spin the prop over?) not catch that one! ![]() -- Duncan It was a bit more than 25 years ago and I've forgotten the bit of trivia that led to the error, other than the fact that I was only there to exercise the engine and not to fly; but it was also a good illustration of why maintenance operations need the same attention to detail and safety as flight operations. The cowling shape of the particular aircraft allowed a cable type lock to remain partially hidden from view, when seated in the left front, and my solution was to add a bright yellow wrapping with tassels--so that any repetition would be obvious from inside the cabin and also nearly impossible to forget on the walkaround. Peter |
#48
D Ramapriya wrote:
Has any of you has ever discovered something during the pre-flight inspection that necessitated a significant deferrment of your flight plan or a cancelation altogether? Just curious, that's all. Thanks, Ramapriya Yes. -- Regards, Ross C-172F 180HP Sold ![]() KSWI |
#49
On Mon, 27 Jul 2009 23:09:30 -0700, Ron Garret wrote:
In article , Franklin "Franklin wrote: On Mon, 27 Jul 2009 14:25:04 -0700, Ron Garret wrote: In article , "Peter Dohm" wrote: "vaughn" wrote in message ... "a" wrote in message ... I did watch a PA28 do turns around a tiedown once because the PIC didn't untie the left wing before trying to taxi out. I once watched a rental 172 return from an apparently uneventful flight with the rudder lock still attached to the rudder. Take-home lesson: Some folks fly flat-footed. Also, at least twice I have ran down and stopped planes on the taxiway with flags flying from left-on pitot covers. Take-home lesson: One good reason to put flags on them is so someone else can save your bacon after you do a crappy preflight. Vaughn I nearly started an engine with a propeller lock still in place--and was fortunate enough to have someone wave my down in time. Due to lucky timing and the good samaritan, there was no damage. Heh, funny you should mention that. I once forgot to remove an orange cone that the FBO had "helpfully" placed in front of the prop. It's amazing what a propeller -- even one not moving at full speed -- can do to an orange cone. That one set me back quite a bit as well. rg Are cones expensive or are your poor? Franklin Cones are cheap, but engine rebuilds after a prop strike aren't. (I was, of course, referring not to money, but to the time it took to consult with a mechanic to convince myself that a rebuild would not be necessary.) rg Please be more clear for the beginners next time. Franklin |
#50
On Mon, 27 Jul 2009 07:05:39 -0700 (PDT), D Ramapriya wrote:
On Jul 27, 4:47*pm, "vaughn" wrote: One day I had pulled a glider out to the flight line and completed my pre-flight, only to find that the tow pilot was taking a bathroom break. Just to kill time, I wandered over to the tow plane and gave it a casual once-over. *To my shock, I discovered that one of the struts on the horizontal stabilizer was broken loose from its fuselage attachment. *That plane's next flight might have been its last! This one made my day, Vaughan (or is it spelt Vaugn?) Troll fake modesty. You can clearly see his name above. Franklin |
annual inspections | [email protected] | Soaring | 1 | October 20th 07 01:08 AM |
100 Hour Inspections | Judah | Piloting | 26 | December 1st 06 02:30 PM |
Homebuilt Inspections | john smith | Home Built | 8 | December 25th 04 02:20 PM |
Time Measurement for Inspections | O. Sami Saydjari | Owning | 15 | April 7th 04 05:26 AM |
Pre-buy inspections | Paul Folbrecht | Owning | 12 | March 1st 04 12:27 AM |
