iPAQ 310 serial
Old August 4th 09, 05:00 PM posted to rec.aviation.soaring
Jim White[_3_]
Default iPAQ 310 serial
At 04:56 04 August 2009, Al wrote:
On Aug 3, 8:15=A0am, Jim White wrote:
Looking at the fora it looks as though the problem is that the
aircable
mini uses the same baud rate for serial and bluetooth ports. Therefore
as
the LX transmits at 4800 baud the bluetooth goes at 4800 baud which
HP3xx interprets as gobbledegook.
SNAFU!
Still looking for a cable solution? or a Baud rate converter?
At 09:30 03 August 2009, Jim White wrote:
This one is more programmable...
http://www.aircable.net/serial.html
Google bluetooth serial adatper there are at least 10 types out
there....
Looks the same problem...same baud rate in and out.
Old August 4th 09, 06:36 PM posted to rec.aviation.soaring
Nick Hill
Jim White wrote:
Looking at the fora it looks as though the problem is that the aircable
mini uses the same baud rate for serial and bluetooth ports. Therefore as
the LX transmits at 4800 baud the bluetooth goes at 4800 baud which the
SNAFU!
The following would solve the problem:
http://serialgadget.com/index.php
You can use it to take the 4800 baud signal from the slow devices and
feed it out at 9600 or 19200 etc. Not the cheapest little gadget but
does the job.
The spec on the web says it requires 5V but a friend of mine has one
which they made up for him which takes 8-16V as input. He uses it in his
glider to upscale a Colibri output from 4800 to 19200 to feed to his
Ipaq so he can switch between the Colibri and Flarm NMEA streams as the
Flarm only outputs the extra flarm data at 19200 or higher.
Nick Hill
Old August 4th 09, 08:05 PM posted to rec.aviation.soaring
Al[_7_]
SNAFU!
feed it out at 9600 or 19200 etc. *Not the cheapest little gadget but
does the job.
Nick Hill
This one is configurable $99 usd's
Anyone tried this one?
http://www.iogear.com/product/GBS301/
Old August 5th 09, 02:22 AM posted to rec.aviation.soaring
QT[_2_]
SNAFU!
does the job.
Nick Hill
On the HP31x, it turns out that the usb cable is a 5 (not 4) wire
cable. If you ground the 5th wire, it turns the usb port into a TTL
level serial port. Combining this with a level converter and a baud
rate converter should let the 31x talk to 4800 baud devices (assuming
you don't overrun the buffer in the baud rate converter). And then
there is the issue of the software on the 31x making assumptions about
what baud rates various devices (SN10, CAI 10/20/25 etc) can
communicate at.
Working on the problem with all the necessary parts. Standby.
Old August 5th 09, 09:30 AM posted to rec.aviation.soaring
Jim White[_3_]
Same problem I am afraid, one baud rate for in and out, but in this case
minimum 9600 so wont talk to the Garmin or LX that I have in the glider.
Good try. Serial cable still preferred if someone knows the spec.
Jim White[_3_]
At 01:22 05 August 2009, QT wrote:
On Aug 4, 1:36=A0pm, Nick Hill wrote:
aircable
Therefore
as
SNAFU!
feed it out at 9600 or 19200 etc. =A0Not the cheapest little gadget
but
does the job.
his
Nick Hill
communicate at.
Good work Nick. I await with bated breath! Can you magic up some charge
current at the same time??
JIm
Old August 6th 09, 06:28 AM posted to rec.aviation.soaring
Al[_7_]
On Aug 4, 1:36=A0pm, Nick Hill *wrote:
aircable
Therefore
as
SNAFU!
but
does the job.
his
Nick Hill
level serial port. *Combining this with a level converter and a baud
you don't overrun the buffer in the baud rate converter). *And then
communicate at.
Working on the problem with all the necessary parts. *Standby.
JIm
Found it....
http://www.usbgear.com/computer_cabl...=158&catid=158
Al.
Old August 6th 09, 08:15 AM posted to rec.aviation.soaring
Jim White[_3_]
Al, afraid I could not make the link work or find what you have on the
site?
At 05:28 06 August 2009, Al wrote:
Found it....
http://www.usbgear.com/computer_cabl...M2B&cats=3D15=
8&catid=3D158
Al.
Old August 6th 09, 08:35 AM posted to rec.aviation.soaring
Al[_7_]
site?
Found it....
http://www.usbgear.com/computer_cabl...DUSBG-BM2B&cat....
8&catid=3D158
Al.
Try this..
http://tinyurl.com/m7epkl
FlashFXP PRO 3.7 + serial - FlashFXPPRO3.7.rar [1/1] Peter Brady Aviation Photos 0 July 17th 09 06:16 PM
USB to Serial Converter RN Soaring 12 March 16th 08 12:21 AM
GTX 327 serial input? weebee Owning 1 December 19th 05 01:04 AM
How get get serial number of GNS-430? Andrew Gideon Owning 15 September 26th 05 11:49 PM
How get get serial number of GNS-430? Andrew Gideon Products 15 September 26th 05 11:49 PM
