You’ve probably seen the sign in a repair shop that reads something
like: “Fast Job, Cheap Job, or a Good Job; - choose any two”. I am happy to share with you that there is one shop where all three are available, Mike Robinson’s at Tom Knauff's Ridge Soaring in PA. The Freedom’s Wings Canada Grob 103 Twin II suffered a puncture in the wing skin when it was taxied into a flight line and the wing went under the tow hook of a SGS 1-34. The sages had deemed the Grob unairworthy, as the tensional stresses imparted to the wing by the aileron could cause the damage to propagate. The repair was fascinating to watch. The wing structure is an inner layer of glass cloth, a layer of high density foam core, and two layers of glass cloth on the outer side, covered with gel coat. The wound itself was about 3.5” long by ¼” wide, and punctured the top skin into the foam. Mike used his air tools with the dexterity of a surgeon, and quickly cut a 3” by 4” rectangle with rounded corners into the wing, down to, but not through, the inner layer of glass. He then fitted a replacement rectangle of foam with resin to glue it to the inner layer of glass, cured at ambient temperature followed by a heat pad. A club member/volunteer assisted with the timely application of the heating pad during the night. Next morning Mike applied two layers of cloth atop the foam at a bias to each other, overlapping the rectangle into the surrounding structure he had shaved out. The cure procedure again, and then a fill with bondo and sand to contour. In fact, a much larger area, 1.5’ by 2’, was sanded and sprayed with gelcoat and again sanded to contour, followed by a second coat of gel coat and sanding, fine sanding, and then our volunteer took over on buffing and waxing. Mike was finished in just 24 hours, and billed for only his 7 hours of actual work. Damaged on Saturday, a call to Mike on Tuesday, and it was back in service Friday morning. BTW, for those of you not burdened with the benefits of a classical education, the title line translates as “Honor to Whom Honor is Due” Thanks Mike, you’re the best! |
