Night Currency - Why Full Stops?
Old August 12th 09, 12:39 AM posted to rec.aviation.piloting
Default Night Currency - Why Full Stops?
Subject says it all. Why do the landings for night currency have to
be made to a full stop?
Thanks
Chris
Old August 12th 09, 02:38 AM posted to rec.aviation.piloting
a[_3_]
On Aug 11, 6:39*pm, wrote:
Subject says it all. *Why do the landings for night currency have to
Thanks
Chris
Look at the regs for day time currency. . The easy answer is, if you
bounce enough you could otherwise get 2 touch and go a littles, then
a full stop, on a 5000 foot runway.
Why would you want to skimp on proving to yourself you were still
sharp enough? If you did three and weren't happy with them, even if to
a full stop, would you stop because you could put a check mark next to
current, or would you go back for some more to prove to yourself, not
anyone else, you were good enough? I'd not want to fly with someone
else as a PIC if he or she told me she had been inactive, then did 3
touch and goes. Would you?
Steve Hix
Thanks
Chris
Safety.
Old August 12th 09, 03:03 AM posted to rec.aviation.piloting
Matt Barrow[_8_]
Because the takeoffs should be from a dead start.
Old August 12th 09, 06:56 PM posted to rec.aviation.piloting
RandyL[_3_]
because the FAA says so...
Randy L.
Remember: Any landing that you can walk away from,
is a landing that you can be fined, sued, or prosecuted for.
"a" wrote in message
Thanks
Chris
Old August 12th 09, 08:15 PM posted to rec.aviation.piloting
a[_3_]
Thanks
Chris
I read the replies and I hope this is a better answer. One poster said
it correctly, the FARs say you have to.
But, night flying is so different than day. The perspectives of the
runway environment are different and whether you have a dark night or a
full moon night. Safety would be an answer, but I think it is more the
difference. Night flying on a moonless night is akin to IFR, almost,
especially in a sparsely populated area.
Just another bit of information. Before I had to sell my plane, our
local airport wanted to get night approach lights. I took the airport
sponsor and another pilot and went to a couple of airports that had VASI
lights. I made much better landings at night following the VASI than I
did at my home airport without them. I really found it amazing. I guess
ThenI tended to be high on approach at night.
Regards, Ross
C-172F 180HP
Sold
KSWI
If you want to really test your night time skills, find an isolated
uncontrolled airport with minimal lighting -- be sure it has a 4000
foot or more runway. Then, do your landings planning touchdown a
thousand feet from the approach end. The only way I can do it
consistantly is to put the Mooney in landing configuration, set the
manifold pressure to where I want it, and fly the approach airspeed. I
make throttle adjustments until my target flare point stays fixed in
my sight picture when I'm 500 feet above the ground. I would much
rather fly an ILS to minimums with a crosswind component near max
allowable than fly into small airports with basic lighting at night.
At least on an ILS when I look up and see the airport invironment I
know where things are supposed to be. Landing between the RR lights,
or just setting up right, means among other things factoring in the
width of the runway when imagining the sight picture to look for. I
prove all too often that that 'Right Stuff" is really hard to find in
my flight bag.
Old August 13th 09, 04:19 AM posted to rec.aviation.piloting
Matt Barrow[_8_]
"Ross" wrote in message
Thanks
Chris
I read the replies and I hope this is a better answer. One poster said it
I think he already knew that, but wanted the logic behind it, so the below
certainly helps.
But, night flying is so different than day. The perspectives of the runway
environment are different and whether you have a dark night or a full moon
night. Safety would be an answer, but I think it is more the difference. Night
flying on a moonless night is akin to IFR, almost, especially in a sparsely
populated area.
Just another bit of information. Before I had to sell my plane, our local
airport wanted to get night approach lights. I took the airport sponsor and
another pilot and went to a couple of airports that had VASI lights. I made
much better landings at night following the VASI than I did at my home airport
without them. I really found it amazing. I guess I tended to be high on
approach at night.
I find night landing not so much a problem as takeoffs, since we're pretty much
in open, dark country and once airborne the depth perception diminishes rather
quickly. It's not so bad when in and out quickly.
Matt
Old August 13th 09, 06:24 PM posted to rec.aviation.piloting
Ross
BT wrote:
what are "night approach lights"?
do not recall hearing that term before
BT
snip
Regards, Ross
C-172F 180HP
Sold
KSWI
It was my lame term for VASI, etc type of approach landing light systems.
Regards, Ross
C-172F 180HP
Sold
KSWI
Why must night landings be full-stop? Ron Garret Piloting 25 March 17th 08 01:34 PM
Night currency question john Piloting 55 December 19th 07 08:00 AM
Radio protocol regarding full stops on full stop only nights Ben Hallert Piloting 33 February 9th 05 08:52 PM
regaining night currency but not alone Teacherjh Instrument Flight Rules 11 May 28th 04 03:08 PM
Night Currency Doug Campbell Instrument Flight Rules 21 October 17th 03 11:53 PM
