Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft
"me123" wrote in message
... Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft -- me123 Start by taking a sheet of copy paper and fold it in half length-wise...... ;-) http://www.youtube.com/watch?v=KZmUaFBCoa0 |
On Aug 19, 2:45*pm, me123 wrote:
Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft -- me123 One part at a time and after a few hundred to a few thousand hours and many parts, you assemble, get it inspected and fly it. Seriously, it is a learning process that you learn as you go and the end result is a smile that will be a very long time fixture of your person. |
On Aug 19, 7:03*pm, "Robert Barker" wrote:
"me123" wrote in message Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft http://www.youtube.com/watch?v=KZmUaFBCoa0 Looks like it has a dutch roll problem. Before you star building try to anticipate what kind of flying you actually will do. Then decide what what material you are comfortable with, or wish to learn. Aluminum? Wood? Composite (fiberglass)? Then start looking for plans or kits that fit you needs. Don't forget to factor in needed build space, heat, and tools needed. Some of us like to build. For the rest keep in mind the old saying "If you want to build, build. If you want to fly....BUY." =============== Leon McAtee |
me123 wrote:
Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft Just like many another homebuilt, you need an iron and a pair of scissors, scotch tape to stick the pattern on.... http://www.instructables.com/id/Foam-Walkalong-Glider/ You start with a scrap of pink rafter insulation - then you iron it flat (!) and end up with a flying wing with a L/D of maybe 30:1 at a flying speed of two MPH.... Brian W |
"brian whatcott" wrote in message
... me123 wrote: Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft Just like many another homebuilt, you need an iron and a pair of scissors, scotch tape to stick the pattern on.... http://www.instructables.com/id/Foam-Walkalong-Glider/ You start with a scrap of pink rafter insulation - then you iron it flat (!) and end up with a flying wing with a L/D of maybe 30:1 at a flying speed of two MPH.... Brian W I just read that instructable last night :-) -- [This comment is no longer available due to a copyright claim by Church of Scientology International] "I like your Christ. I do not like your Christians. They are so unlike your Christ." Gandhi |
me123 schreef:
Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft Begin at the beginning. Go on till the end. Then stop. Each of these takes some doing, some more, some less, all depending on the mission, as already rehearsed. |
"jan olieslagers" wrote in message
... me123 schreef: Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft Begin at the beginning. Go on till the end. Then stop. Each of these takes some doing, some more, some less, all depending on the mission, as already rehearsed. The problem is, once you start, you CAN'T stop! |
"Robert Barker" wrote in message
... "jan olieslagers" wrote in message ... me123 schreef: Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft Begin at the beginning. Go on till the end. Then stop. Each of these takes some doing, some more, some less, all depending on the mission, as already rehearsed. The problem is, once you start, you CAN'T stop! Yup :-) There are a lot of "I'll finish that one day" sitting in sheds all over the world, I doubt that any would be classed as "Ahhh fuggit, I'm going to stop working on that now" :-) -- [This comment is no longer available due to a copyright claim by Church of Scientology International] "I like your Christ. I do not like your Christians. They are so unlike your Christ." Gandhi |
On Aug 19, 3:45*pm, me123 wrote:
Hi I noticed the forum decription says "...building aircraft" so I would just like to know how to build an aircraft -- me123 Get a real big billet of aluminum and cut away everything that doesn't look like an airplane. |
Portable Aircraft HF Radio Build (Going to Be Long) Multiple Posts.... | NW_Pilot | Piloting | 35 | February 6th 08 05:18 AM |
Build an RV of ??? | William Snow | Owning | 12 | September 8th 06 03:12 AM |
Build an RV of ??? | Jim Logajan | Home Built | 1 | September 8th 06 03:12 AM |
How to build a P-38 ? ? ? | Hans-Marc Olsen | Home Built | 42 | December 11th 04 04:06 PM |
RV Quick Build build times... | [email protected] | Home Built | 2 | December 17th 03 03:29 AM |
