Can someone point me to a reference describing how to complete the
"Description of Work Accomplished" section of a 337? I have seen maybe a dozen completed 337s and they appear to be all over the map! What I'm trying to do is draft a planning document describing what and how I'm going to do my repairs to my fuselage and show not that my IA has approved the work, but has OKed my approach. The same wording woujld appear in the 337 when the work is accomplished. I'm having to do this because there are large time spans between when my IA OKs my approach and when the work is done and when a 337 is generated. I think it would be a good idea to document that my IA had approved my approach. - Mike |
Found it - AC 43-9-1e
On Sat, 22 Aug 2009 06:53:20 -0400, Michael Horowitz wrote: Can someone point me to a reference describing how to complete the "Description of Work Accomplished" section of a 337? I have seen maybe a dozen completed 337s and they appear to be all over the map! What I'm trying to do is draft a planning document describing what and how I'm going to do my repairs to my fuselage and show not that my IA has approved the work, but has OKed my approach. The same wording woujld appear in the 337 when the work is accomplished. I'm having to do this because there are large time spans between when my IA OKs my approach and when the work is done and when a 337 is generated. I think it would be a good idea to document that my IA had approved my approach. - Mike |
I'm having to do this because there are large time spans between when my IA OKs my approach and when the work is done and when a 337 is generated. I think itwould be a good idea to document that my IA had approved my approach. - Mike Is this a homebuilt? No 337 required, No IA necessary. You do have to note substantial changes to the FAA however. |
"Ron" wrote in message
... I'm having to do this because there are large time spans between when my IA OKs my approach and when the work is done and when a 337 is generated. I think itwould be a good idea to document that my IA had approved my approach. - Mike Is this a homebuilt? No 337 required, No IA necessary. You do have to note substantial changes to the FAA however. I was thinking of that as well and you are right--with the addition that a certified mechanic, who need not also hold an IA, is requered to sign of the work if the owner is not the original builderof record. |
On Aug 22, 3:04*pm, Ron wrote:
Is this a homebuilt? * I think Michael is working on a Taylorcraft. Thanks, Bob K. |
"Bryan Martin" wrote in message
... In article , "Peter Dohm" wrote: "Ron" wrote in message ... I'm having to do this because there are large time spans between when my IA OKs my approach and when the work is done and when a 337 is generated. I think itwould be a good idea to document that my IA had approved my approach. - Mike Is this a homebuilt? No 337 required, No IA necessary. You do have to note substantial changes to the FAA however. I was thinking of that as well and you are right--with the addition that a certified mechanic, who need not also hold an IA, is requered to sign of the work if the owner is not the original builderof record. You don't need an A & P to sign off any changes or repairs to a homebuilt, even if you are not the original builder. Anyone can work on a homebuilt airplane. An A & P is only needed to sign off the annual condition inspection. -- Bryan Martin N61BM, CH 601 XL, Ram Subaru, Stratus redrive. In this case, I am glad to stand corrected. Peter |
Michael Horowitz schreef:
Found it - AC 43-9-1e On Sat, 22 Aug 2009 06:53:20 -0400, Michael Horowitz wrote: Can someone point me to a reference describing how to complete the "Description of Work Accomplished" section of a 337? I have seen maybe a dozen completed 337s and they appear to be all over the map! You meaning a Cessna Skymaster or what? I never knew that to be homebuilt, neither from plans or kits? |
"jan olieslagers" wrote in message ... Michael Horowitz schreef: Found it - AC 43-9-1e On Sat, 22 Aug 2009 06:53:20 -0400, Michael Horowitz wrote: Can someone point me to a reference describing how to complete the "Description of Work Accomplished" section of a 337? I have seen maybe a dozen completed 337s and they appear to be all over the map! You meaning a Cessna Skymaster or what? I never knew that to be homebuilt, neither from plans or kits? In case you are serious about this question, I will attempt to shed light on the subject. If you are joking, sorry; it went over my head! g I recall you are not from the United States, and may be unaware of the FAA forms system. A form number 337 is what you are required to fill out when certain types of changes are made to any certified aircraft. There are particular ways the form must be completed and submitted, so the change is registered and found to be an acceptable change. The point was made in a previous post that the form 337 does not apply to a homebuilt aircraft, since they are not certified. I hope that help clear the muddy water. ;-) -- Jim in NC |
"Morgans" wrote in message ... "jan olieslagers" wrote in message ... Michael Horowitz schreef: Found it - AC 43-9-1e On Sat, 22 Aug 2009 06:53:20 -0400, Michael Horowitz wrote: Can someone point me to a reference describing how to complete the "Description of Work Accomplished" section of a 337? I have seen maybe a dozen completed 337s and they appear to be all over the map! You meaning a Cessna Skymaster or what? I never knew that to be homebuilt, neither from plans or kits? In case you are serious about this question, I will attempt to shed light on the subject. If you are joking, sorry; it went over my head! g I recall you are not from the United States, and may be unaware of the FAA forms system. A form number 337 is what you are required to fill out when certain types of changes are made to any certified aircraft. There are particular ways the form must be completed and submitted, so the change is registered and found to be an acceptable change. The point was made in a previous post that the form 337 does not apply to a homebuilt aircraft, since they are not certified. I hope that help clear the muddy water. ;-) -- Jim in NC The best way to deal with a 337, is to immediately put your certified ship up for sale and build an experimental homebuilt aircraft. A lot of your expensive problems go away. By building it you become the manufacturer and all inspections can be performed by you. No one is out there telling you to fill out a form for modifications thay you deem needed or to make you craft better. Stu Fields |
... "jan olieslagers" wrote in message ... Michael Horowitz schreef: Found it - AC 43-9-1e On Sat, 22 Aug 2009 06:53:20 -0400, Michael Horowitz wrote: Can someone point me to a reference describing how to complete the "Description of Work Accomplished" section of a 337? I have seen maybe a dozen completed 337s and they appear to be all over the map! You meaning a Cessna Skymaster or what? I never knew that to be homebuilt, neither from plans or kits? In case you are serious about this question, I will attempt to shed light on the subject. If you are joking, sorry; it went over my head! g I recall you are not from the United States, and may be unaware of the FAA forms system. A form number 337 is what you are required to fill out when certain types of changes are made to any certified aircraft. There are particular ways the form must be completed and submitted, so the change is registered and found to be an acceptable change. The point was made in a previous post that the form 337 does not apply to a homebuilt aircraft, since they are not certified. I hope that help clear the muddy water. ;-) -- Jim in NC To add just a little more, and with the understanding that I am a former avionics technician and have never been a mechanic--much less an IA--my understanding is that a form 337 is a return to service following a major repair or a modification that was not sufficient to require an STC. In effect, the modification or repair should not alter the original operating limitations of the aircraft, which would require that issuance of an STC; but may alter the weight and balance calculations for the specific aircraft. I hope this helps. Peter |
| Complete HP-18 Sailplane Kit | Wayne Paul | Aviation Marketplace | 0 | August 17th 06 05:34 PM |
| Complete HP-18 Sailplane Kit | Wayne Paul | Home Built | 0 | August 17th 06 05:31 PM |
| Complete HP-18 Kit | Wayne Paul | Soaring | 0 | August 17th 06 05:31 PM |
| For Sale: L-Nav, Gps-Nav, complete | [email protected] | Soaring | 0 | November 22nd 05 01:23 PM |
| Complete Idiots? | John Galban | Piloting | 1 | July 1st 04 07:14 PM |
