Expanding a bronze bushing?
Old September 14th 09, 08:44 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Expanding a bronze bushing?
I have a small bronze bushing whose OD I'd like to expand slightly so
it fits the ID of a tube.
I seem to recall there was a way to expand the OD slightly with
something like a knurling tool.
Does that sound familiar?
Is there an easy way to do this? - Mike
Old September 15th 09, 12:18 AM posted to rec.aviation.homebuilt
Tim[_8_]
"Michael Horowitz" wrote in message
Depends on how much you want to expand it. Knurling in a lath will give you
up to .010 or so.
Old September 15th 09, 12:31 AM posted to rec.aviation.homebuilt
Brian Whatcott
That method is generally recognized as cowboy engineering.
You might hope for better life from using a metal powder filled epoxy
to fill the gap, and that's no great shakes either.
Pick a bigger bush and reduce it, if you possibly can.
Brian W
Old September 15th 09, 01:38 AM posted to rec.aviation.homebuilt
Peter Dohm
"brian whatcott" wrote in message
something like a knurling tool. Does that sound familiar? Is there an
You might hope for better life from using a metal powder filled epoxy to
Brian W
What??? Is "cowboy engineering" the newest politically correct version of
political incorrectness in describing a "kluge" or generally unacceptable
practice?
Peter ;-)))
You're gonna upset some guys who're real good with .44s
Old September 15th 09, 02:55 AM posted to rec.aviation.homebuilt
Dan[_12_]
Brian W
practice?
Peter ;-)))
.44 is for sissies, try .500 S&W magnum. In any event knurling isn't
a good solution for something on which your life may depend. There
simply isn't enough surface generated by knurling. I have done it for
toy steam engines, but would never do it for something that has
significant forces applied. Bear in mind bronze and the tube material
have different temperature expansion rates.
If you don't need to apply a lot of force to it you can use a prick
punch to stipple the outside of the bushing if you don't have access to
a lathe and knurling tool.
If you choose to make your own bushing bear in mind there are
different bronze alloys each with its own characteristics. I use
phosphor bronze for most of my bearing applications.
Dan, U.S. Air Force, retired
Old September 15th 09, 01:28 PM posted to rec.aviation.homebuilt
Stealth Pilot[_3_]
On Mon, 14 Sep 2009 15:44:02 -0400, Michael Horowitz
MIKE, for crissake!!! aaaaaaaaaaaaaaaaaarrrrrrrggggggghhhhhhh!!!!!!!
post the dimensions you need and I'll machine you a new one.
sTEALTH pILOT
sEE YOU'VE UPSET ME THAT MUCH THAT THE CAPS LOCK HAS JAMBED.
Old September 15th 09, 02:36 PM posted to rec.aviation.homebuilt
jerry wass
sTEALTH pILOT
mINE DOES THAT aLL THE tIME!!--jERRY
Old September 15th 09, 03:03 PM posted to rec.aviation.homebuilt
Stealth Pilot[_3_]
On Tue, 15 Sep 2009 13:36:29 GMT, Jerry Wass
sTEALTH pILOT
we should make it an internet project.
absolutely everyone in the world with a lathe makes him a new bushing
insert and sends it to him.
maybe after the 80,000th bushing arrives it will sink in that in
aircraft you do it properly or not at all.
(have you been too embarrassed to ask for a bushing jERRY?)
Stealth :-) Pilot
Old September 15th 09, 04:37 PM posted to rec.aviation.homebuilt
Peter Dohm
"Dan" wrote in message
Brian W
of political incorrectness in describing a "kluge" or generally
unacceptable practice?
Peter ;-)))
.44 is for sissies, try .500 S&W magnum. In any event knurling isn't a
good solution for something on which your life may depend. There simply
isn't enough surface generated by knurling. I have done it for toy steam
engines, but would never do it for something that has significant forces
applied. Bear in mind bronze and the tube material have different
punch to stipple the outside of the bushing if you don't have access to a
If you choose to make your own bushing bear in mind there are different
bronze alloys each with its own characteristics. I use phosphor bronze for
AFAIK, the .44 was the percussion cap wheel gun that became the .45 Long
Colt, a/k/a The Gun That Won The West, and extremely popular amoung cowboys
during the brief period of the Old West.
In any case, I agree with you about knurling.
Peter
Old September 15th 09, 05:50 PM posted to rec.aviation.homebuilt
Dan[_12_]
sTEALTH pILOT
HeY, dOn'T mAkE fUn Of ThOsE wItH oNe ArM lOnGeR
tHaN tHe OtHeR.
?replace bushing on compressor wheels? mhorowit Home Built 4 September 22nd 08 03:43 AM
Expanding my flying comfort zone (long) Ron Lee[_2_] Piloting 2 December 8th 07 03:02 AM
Enlarging a bushing hole? Michael Horowitz Home Built 18 September 17th 07 11:57 AM
(CNN & AP) U.N: Iran expanding rather than freezing nuclear program AirRaid[_3_] Naval Aviation 3 February 26th 07 06:49 PM
Rubber Bushing Replacement Boelkowj Home Built 8 December 12th 03 12:45 AM
