Expanding a bronze bushing?
Old September 15th 09, 05:51 PM posted to rec.aviation.homebuilt
Dan[_12_]
Default Expanding a bronze bushing?
Stealth Pilot wrote:
On Tue, 15 Sep 2009 13:36:29 GMT, Jerry Wass
On Mon, 14 Sep 2009 15:44:02 -0400, Michael Horowitz
I have a small bronze bushing whose OD I'd like to expand slightly so
it fits the ID of a tube.
I seem to recall there was a way to expand the OD slightly with
something like a knurling tool.
Does that sound familiar?
Is there an easy way to do this? - Mike
MIKE, for crissake!!! aaaaaaaaaaaaaaaaaarrrrrrrggggggghhhhhhh!!!!!!!
post the dimensions you need and I'll machine you a new one.
sTEALTH pILOT
sEE YOU'VE UPSET ME THAT MUCH THAT THE CAPS LOCK HAS JAMBED.
mINE DOES THAT aLL THE tIME!!--jERRY
we should make it an internet project.
absolutely everyone in the world with a lathe makes him a new bushing
insert and sends it to him.
maybe after the 80,000th bushing arrives it will sink in that in
aircraft you do it properly or not at all.
(have you been too embarrassed to ask for a bushing jERRY?)
Stealth :-) Pilot
If all else fails make it too big and hammer it in place?
Dan, U.S. Air Force, retired
Old September 15th 09, 05:54 PM posted to rec.aviation.homebuilt
Dan[_12_]
Peter Dohm wrote:
"Dan" wrote in message
Peter Dohm wrote:
"brian whatcott" wrote in message
something like a knurling tool. Does that sound familiar? Is there an
That method is generally recognized as cowboy engineering.
You might hope for better life from using a metal powder filled epoxy
to fill the gap, and that's no great shakes either.
Pick a bigger bush and reduce it, if you possibly can.
Brian W
What??? Is "cowboy engineering" the newest politically correct version
of political incorrectness in describing a "kluge" or generally
unacceptable practice?
Peter ;-)))
You're gonna upset some guys who're real good with .44s
.44 is for sissies, try .500 S&W magnum. In any event knurling isn't a
good solution for something on which your life may depend. There simply
isn't enough surface generated by knurling. I have done it for toy steam
engines, but would never do it for something that has significant forces
applied. Bear in mind bronze and the tube material have different
temperature expansion rates.
If you don't need to apply a lot of force to it you can use a prick
punch to stipple the outside of the bushing if you don't have access to a
lathe and knurling tool.
If you choose to make your own bushing bear in mind there are different
bronze alloys each with its own characteristics. I use phosphor bronze for
most of my bearing applications.
AFAIK, the .44 was the percussion cap wheel gun that became the .45 Long
Colt, a/k/a The Gun That Won The West, and extremely popular amoung cowboys
during the brief period of the Old West.
In any case, I agree with you about knurling.
Peter
Oh, THAT 44 Mine is a replica Colt army. Did you know if one
doesn't crimp the caps correctly they all drop off when the first one is
fired? Not that anything like that ever happened to me or anything.
Old September 15th 09, 06:42 PM posted to rec.aviation.homebuilt
Steve Hix[_2_]
In article , Dan
Brian W
Peter ;-)))
Peter
And then you're left with trying to decide whether scrabbling on the
ground to pick up caps and try again, or to get a new batch out of the
tin will be less obvious to onlookers.
Generally, they won't notice, being doubled over, laughing hysterically.
Never happened to me, either. Nope.
Old September 15th 09, 06:57 PM posted to rec.aviation.homebuilt
vaughn[_2_]
Oh, THAT 44 Mine is a replica Colt army. Did you know if one doesn't
crimp the caps correctly they all drop off when the first one is fired?
One also quickly learns to turn the gun upside-down whilst re-cocking the
hammer after each shot. Otherwise you risk having the used cap drop down
and jam the action.
Vaughn
Old September 15th 09, 07:29 PM posted to rec.aviation.homebuilt
Dan[_12_]
Steve Hix wrote:
In article , Dan
Brian W
Peter ;-)))
Peter
Have you ever noticed a truly good foul up is almost always
accomplished with an appreciative audience?
Old September 15th 09, 07:31 PM posted to rec.aviation.homebuilt
Dan[_12_]
and jam the action.
Vaughn
One also rapidly ;earns not to go target shooting on a totally
windless day. Waiting an hour to be able to see the target again gets
old fast. Smokeless powder? We don't need no steenking smokeless powder.
Old September 15th 09, 10:28 PM posted to rec.aviation.homebuilt
Michael Horowitz
On Tue, 15 Sep 2009 12:28:49 GMT, Stealth Pilot
sTEALTH pILOT
Don't bother
Old September 16th 09, 03:34 AM posted to rec.aviation.homebuilt
Brian Whatcott
Peter Dohm wrote:
I have a small bronze bushing whose OD I'd like to expand ... with
What??? Is "cowboy engineering" the newest politically correct version of
political incorrectness in describing a "kluge" or generally unacceptable
practice?
Peter ;-)))
Hmmm...you have a point... :-)
B
Old September 16th 09, 05:06 AM posted to rec.aviation.homebuilt
jerry wass
sTEALTH pILOT
Stealth :-) Pilot
NO--I have a lath--Steif & Bruin 11X22--melt down old 45-70 hulls for stock.
Old September 16th 09, 08:53 AM posted to rec.aviation.homebuilt
Stealth Pilot[_3_]
On Tue, 15 Sep 2009 17:28:57 -0400, Michael Horowitz
sTEALTH pILOT
Don't bother
michael.
I once drove 600km getting a bushing sorted out.
the first time it was too tight.
trimmed off a bit.
slightly too loose.
worked out the fit needed, next time a perfect drive fit, just tap in
place.
600km to get it just right.
the project now sits in my backyard workshop.
do it properly or the bushing will wear prematurely.
if you cant get one locally I can machine one in phos bronze and post
it to you.
is easy.
you've probably still got my email address.
Stealth Pilot
?replace bushing on compressor wheels? mhorowit Home Built 4 September 22nd 08 03:43 AM
Expanding my flying comfort zone (long) Ron Lee[_2_] Piloting 2 December 8th 07 03:02 AM
Enlarging a bushing hole? Michael Horowitz Home Built 18 September 17th 07 11:57 AM
(CNN & AP) U.N: Iran expanding rather than freezing nuclear program AirRaid[_3_] Naval Aviation 3 February 26th 07 06:49 PM
Rubber Bushing Replacement Boelkowj Home Built 8 December 12th 03 12:45 AM
