PZL compass
Old September 25th 09, 06:42 PM
Solo Solo is offline
Junior Member
First recorded activity by AviationBanter: Oct 2006
Default PZL compass
I have a PZL KI-13A compass. The fluid seems to have drained out. I contacted PZL for information on how to repair but, their recommendation was to replace the unit because of the shipping cost.
Is there a way to refill the compass with the appropriate fluid?
Old September 25th 09, 08:49 PM posted to rec.aviation.soaring
Dave Nadler
Default PZL compass
On Sep 25, 1:42*pm, Solo wrote:
I have a PZL KI-13A compass. *The fluid seems to have drained out. *I
Solo
If the fluid has leaked out, its cracked.
Often because the mounting ring was over-tightened.
You'll want to read this thread:
http://groups.google.com/group/rec.a...718b5728fffbca
Hope that helps,
Best Regards, Dave "YO electric" (which has a good 'ole Airpath)
Old September 26th 09, 04:11 AM posted to rec.aviation.soaring
John[_25_]
Default PZL compass - Searching past posts??
Solo
You'll want to read this thread:http://groups.google.com/group/rec.a...wse_frm/thread...
Hope that helps,
Has anyone else noted that all RAS posts older than about a month are
no longer returned by 'Search this group' ? Dave's direct link to the
thread works fine, but a search on 'PZL' will not produce it. I hope
there is an easy alternative to searching our archives, because if
not, we've all lost a good source of knowledge. New postings also
become a waste of time if only accessible via search for such a short
time.
John
Old September 26th 09, 03:55 PM posted to rec.aviation.soaring
jcarlyle
This inconvenient situation has existed for about 2 months now -
apparently Google "improved" things a while ago (not!) You can still
search the archives, though, everything is there. Do this:
1. Go to this page: http://groups.google.com/
2. In the search field type "group:rec.aviation.soaring" (without the
quotes), followed by your query
Hope this helps.
-John
time.
Old September 26th 09, 04:12 PM posted to rec.aviation.soaring
Leroy Tire
Default PZL compass
If you fix it and refill it, be sure to leave a small air bubble in it
for fluid expansion or else you will be back to where you started.
WTB: PZL KI-13 Compass Romeo Delta Soaring 1 October 30th 17 07:47 AM
I want a PZL K-13 compass Jim Archer Soaring 2 June 6th 11 08:03 PM
Compass for SZD-55 Steve Freeman Soaring 3 July 24th 07 02:13 AM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
mag-compass for a B55 JerryK Owning 3 July 11th 03 06:18 AM
