The AP and Reuters are reporting that the Blackhawk that was lost last
Thursday was apparently a victim of hostile fire based upon results from a preliminary investigation. Both sources also report that Danish troops have found the first confirmed chemical weapons in Iraq--36 artillery or mortar rounds (reports vary as to specific type) filled with a blister agent, and that another 100 rounds may be in the cache. No doubt some folks will soon be screaming that 36, or 136 for that matter, chemical rounds are not indicitive of Saddam having had chemical munitions despite his protestations otherwise... Brooks |
On Sun, 11 Jan 2004 06:32:58 GMT, "Kevin Brooks"
wrote: The AP and Reuters are reporting that the Blackhawk that was lost last Thursday was apparently a victim of hostile fire based upon results from a preliminary investigation. Both sources also report that Danish troops have found the first confirmed chemical weapons in Iraq--36 artillery or mortar rounds (reports vary as to specific type) filled with a blister agent, and that another 100 rounds may be in the cache. No doubt some folks will soon be screaming that 36, or 136 for that matter, chemical rounds are not indicitive of Saddam having had chemical munitions despite his protestations otherwise... Brooks According to some news reports the U.S. is tentivaly stating that they appear to be left over from the Iran-Iraq war. They certainly are corroded enough. OTH, this could also be a desire to cross every T and dot every I, so that should they be detirmend to be from after the gulf war, the U.S. will have maximum credibility. |
On Sun, 11 Jan 2004 07:27:47 GMT, Charles Gray wrote:
On Sun, 11 Jan 2004 06:32:58 GMT, "Kevin Brooks" wrote: The AP and Reuters are reporting that the Blackhawk that was lost last Thursday was apparently a victim of hostile fire based upon results from a preliminary investigation. Both sources also report that Danish troops have found the first confirmed chemical weapons in Iraq--36 artillery or mortar rounds (reports vary as to specific type) filled with a blister agent, and that another 100 rounds may be in the cache. No doubt some folks will soon be screaming that 36, or 136 for that matter, chemical rounds are not indicitive of Saddam having had chemical munitions despite his protestations otherwise... Brooks According to some news reports the U.S. is tentivaly stating that they appear to be left over from the Iran-Iraq war. They certainly are corroded enough. OTH, this could also be a desire to cross every T and dot every I, so that should they be detirmend to be from after the gulf war, the U.S. will have maximum credibility. Well, they just found them, so they are clearly from "after the Gulf War. They may have been built before the war, but they exist, and are WMD. Al Minyard |
"Alan Minyard" wrote in message ... On Sun, 11 Jan 2004 07:27:47 GMT, Charles Gray wrote: On Sun, 11 Jan 2004 06:32:58 GMT, "Kevin Brooks" wrote: The AP and Reuters are reporting that the Blackhawk that was lost last Thursday was apparently a victim of hostile fire based upon results from a preliminary investigation. Both sources also report that Danish troops have found the first confirmed chemical weapons in Iraq--36 artillery or mortar rounds (reports vary as to specific type) filled with a blister agent, and that another 100 rounds may be in the cache. No doubt some folks will soon be screaming that 36, or 136 for that matter, chemical rounds are not indicitive of Saddam having had chemical munitions despite his protestations otherwise... Brooks According to some news reports the U.S. is tentivaly stating that they appear to be left over from the Iran-Iraq war. They certainly are corroded enough. OTH, this could also be a desire to cross every T and dot every I, so that should they be detirmend to be from after the gulf war, the U.S. will have maximum credibility. Well, they just found them, so they are clearly from "after the Gulf War. They may have been built before the war, but they exist, and are WMD. and they were required to be accounted for and destroyed. |
"Alan Minyard" wrote in message ... On Sun, 11 Jan 2004 07:27:47 GMT, Charles Gray wrote: On Sun, 11 Jan 2004 06:32:58 GMT, "Kevin Brooks" wrote: The AP and Reuters are reporting that the Blackhawk that was lost last Thursday was apparently a victim of hostile fire based upon results from a preliminary investigation. Both sources also report that Danish troops have found the first confirmed chemical weapons in Iraq--36 artillery or mortar rounds (reports vary as to specific type) filled with a blister agent, and that another 100 rounds may be in the cache. No doubt some folks will soon be screaming that 36, or 136 for that matter, chemical rounds are not indicitive of Saddam having had chemical munitions despite his protestations otherwise... Brooks According to some news reports the U.S. is tentivaly stating that they appear to be left over from the Iran-Iraq war. They certainly are corroded enough. OTH, this could also be a desire to cross every T and dot every I, so that should they be detirmend to be from after the gulf war, the U.S. will have maximum credibility. Well, they just found them, so they are clearly from "after the Gulf War. They may have been built before the war, but they exist, and are WMD. Al Minyard Although all the testing has not been completed on these rounds. A similar find of badly corroded mortar rounds, back in October, gave off the same initial readings and turned out to have been white phosphorus after final testing. This also happened with an ASM warhead found at an Iraqi airbase - initial meter readings were reported to the media, but subsequent testing proved it not to have been a chemical round. TJ |
On Tue, 13 Jan 2004 23:51:36 +0100, "Emmanuel Gustin"
wrote: "Kevin Brooks" wrote in message t... that another 100 rounds may be in the cache. No doubt some folks will soon be screaming that 36, or 136 for that matter, chemical rounds are not indicitive of Saddam having had chemical munitions despite his protestations otherwise... Always happy to oblige :-) Assuming these are indeed filled with a blister agent, which still needs to be evaluated properly: Looking at their condition, this hardly amounts to "having chemical ammunitions." Surely the crime here is "having toxic waste". No remotely sane gun crew is going to try to load and fire these rounds! If this is your WMD standard, then I can tell Belgium must have a larger WMD arsenal than Iraq: We have tons of leftovers from WW1, in similar conditions. Farmers regularly unearth them while plowing their fields. Usually they just drag them to the side and leave them there until the collection truck comes round... the question isn't "are they usable" but "when were they buried" if it was during or after the Iranian conflict, it's very reasonable to assume they were just forgotten, probably deliberately by whoever might have had to try and dig them up. If they were buried a year ago, that puts and entirely different complex on things-- in that case, bush was right and Iraq DID have combat ready munitions. I've been told by some people that teh condition of the munitions is not neccesarily a sign of how old they are-- it depends on how they were buried the chemcical composition of the soil (!), and other details, many of which, absent something convenient, like an inspectors stamp with June 1st, 2003 on it, are fairly time consuming-- and as one poster above said, there's always a chance that they are not chemical munitions at all. |
"Emmanuel Gustin" wrote in message ... "Kevin Brooks" wrote in message ... that another 100 rounds may be in the cache. No doubt some folks will soon be screaming that 36, or 136 for that matter, chemical rounds are not indicitive of Saddam having had chemical munitions despite his protestations otherwise... Always happy to oblige :-) Assuming these are indeed filled with a blister agent, which still needs to be evaluated properly: Looking at their condition, this hardly amounts to "having chemical ammunitions." Surely the crime here is "having toxic waste". No remotely sane gun crew is going to try to load and fire these rounds! So because they were just *stupid* in how they stored those rounds (reportedly wrapped in mylar and buried), that exhonerates Saddam of having them....that does not sound very logical to me. If this is your WMD standard, then I can tell Belgium must have a larger WMD arsenal than Iraq: We have tons of leftovers from WW1, in similar conditions. Farmers regularly unearth them while plowing their fields. Usually they just drag them to the side and leave them there until the collection truck comes round... I was unaware the Belgians ever developed or fielded chemical munitions (would have been a bit hard to do, since the German's were occupying them through most of the war). And i suspect you really know that your analogy here falls flatter than a pancake--the munitions in question were undeniably Iraqi in origin. Saddam was supposed to have (a) destroyed all of his chemical munitions, and (b) accounted for same. It is obvious that in this case (a) any destruction was unintentional (or why would they have wrapped them up before burying them?), and (b) he did not account for them. That would put him in violation of both the ceasefire agreements and the subsequent UN resolutions. Brooks -- Emmanuel Gustin |
"Emmanuel Gustin" wrote in message ... "Kevin Brooks" wrote in message ... that another 100 rounds may be in the cache. No doubt some folks will soon be screaming that 36, or 136 for that matter, chemical rounds are not indicitive of Saddam having had chemical munitions despite his protestations otherwise... Always happy to oblige :-) Assuming these are indeed filled with a blister agent, which still needs to be evaluated properly: Looking at their condition, this hardly amounts to "having chemical ammunitions." Surely the crime here is "having toxic waste". No remotely sane gun crew is going to try to load and fire these rounds! If this is your WMD standard, then I can tell Belgium must have a larger WMD arsenal than Iraq: We have tons of leftovers from WW1, in similar conditions. Farmers regularly unearth them while plowing their fields. Usually they just drag them to the side and leave them there until the collection truck comes round... Some pretty serious avoiding of the issue there. Saddam was not only required to destroy what he had, but to account for the destruction. If those rounds were missing from earlier wars or atrocities, they should still have been accounted for up until the point at which they were issued to a unit and then listed as missing as of whatever date and time. If Saddam can walk away from accounting for 36 buried chem rounds (assuming they are chem), why not 360 - at what point would you agree that he should have accounted for the rounds? |
and (b) accounted for same. It is obvious that in this case (a) any destruction was unintentional (or why would they have wrapped them up before burying them?), and (b) he did not account for them. That would put him in violation of both the ceasefire agreements and the subsequent UN resolutions. The rounds were found from former swamp bed (Saddam dried these swamps in effort to catch the Shiia rebels after 1991) and were estimated to be 10+ years old by US specialists. |
"tadaa" wrote in message ... Saddam was supposed to have (a) destroyed all of his chemical munitions, and (b) accounted for same. It is obvious that in this case (a) any destruction was unintentional (or why would they have wrapped them up before burying them?), and (b) he did not account for them. That would put him in violation of both the ceasefire agreements and the subsequent UN resolutions. The rounds were found from former swamp bed (Saddam dried these swamps in effort to catch the Shiia rebels after 1991) and were estimated to be 10+ years old by US specialists. Uhmm...the last I heard the dating was inconclusive as of yet, with various sources making differing claims, from "ten years" (which would of course have been *after* ODS--it could be over *thirteen* years old and still have been a post-ODS cache), to "the Iran-Iraq War". In the end, it does not really matter--Saddam turned in repeated and differing accounts detailing his alleged destruction of WMD...do you think he listed any of it as "Gee, we lost it and don't know *where* it is"? I doubt it. Face it, he did not meet the requirements. Brooks |
