High Visibility Paint Schemes
Old October 14th 09, 11:32 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default High Visibility Paint Schemes
On Tue, 13 Oct 2009 15:11:07 -0700, Uncle Fuzzy wrote:
I wonder about painting the undersides of wings and tail black while
leaving the rest of the glider white. That should stay cool while
showing up well against anything except ice and snow.
I like that idea, except that Black is boring. A nice rich RED is very
close to black in grey scale value, and so much less boring. You've
probably noted as much while looking up chasing runaway FF models.
The best scheme for FF I've used is black undersides on the inner panels
and dayglo orange top and bottom on the tips. The inner panel top colour
doesn't matter much. I've used yellow, scarlet and white - all are
equally good. However, the both the black inners and the orange tips show
up really well against any sky and, as a bonus, the orange tips are
highly visible on the ground as well. The pictures he
http://www.gregorie.org/freeflight
are a bit washed out, but do show why I like the scheme. I don't think
the dayglo works as well on a sailplane because a lot of its visibility
comes from light shining through the translucent wing covering and
powering up the dayglo[*].
A friend uses purple inners and yellow/green dayglo. The yellow/green is
pretty good but I don't think the purple is as visible in the air as
black.
[*] the reason that dayglo always looks so bright is that it absorbs
ultraviolet and visible wavelengths of light and uses the energy to
fluoresce, so it actually is brighter than other colours. Under more than
a few feet of water almost all light is blue-green but even here orange
dayglo fluoresces orange. Panels of it have been used to improve the
colour balance of underwater photographs.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old October 14th 09, 05:11 PM posted to rec.aviation.soaring
bildan
On Oct 14, 4:32*am, Martin Gregorie
I like that idea, except that Black is boring. *A nice rich RED is very
black.
martin@ * | Martin Gregorie
org * * * |
Actually, while ultraviolet works, most florescent (Trademark Dayglo)
materials also absorb blue wavelengths and re-emit as a bright (but
longer wavelength) color. As proof, use a blue LED to illuminate a
florescent material and watch it light up.
Old October 14th 09, 05:35 PM posted to rec.aviation.soaring
ContestID67[_2_]
A couple of years back I was watching some local scale model glider
pilots flying (interesting winch launching mechanism) and noticed that
they used reflective tape on their leading edges. This was also
mentioned in the http://www.dg-flugzeugbau.de/Data/gl...uity-study.pdf
article.
I asked the scale model pilots about it and they said they often loose
their gliders, especially during overcast days, so they circle and
pick up the "flash" of the tape. The tape that they used is used for
reflective fishing lures. See http://www.jannsnetcraft.com/reflect...es/309100.aspx
for examples.
So I bought some of the tape and used wing tape to attach about 3' on
the leading edge near my wing tips. I communicated with Dick Johnson
about it and he expressed interest in the concept. Unfortunately,
life interfered and I never completed a reasonable study if I was more
visible or not. I plan on being in a contest in 2010 which might be a
good proving ground.
The question is would it affect the aerodynamics of the wing? If so
it might be a hard sell for competition pilots, which is a prime at-
risk group.
My $0.02.
- John DeRosa
Old October 14th 09, 09:45 PM posted to rec.aviation.soaring
Mike Bamberg
they used reflective tape on their leading edges. *This was also
mentioned in thehttp://www.dg-flugzeugbau.de/Data/glider-conspicuity-study.pdf
article.
pick up the "flash" of the tape. *The tape that they used is used for
reflective fishing lures. *Seehttp://www.jannsnetcraft.com/reflector-tape-eyes/309100.aspx
for examples.
the leading edge near my wing tips. *I communicated with Dick Johnson
about it and he expressed interest in the concept. *Unfortunately,
visible or not. *I plan on being in a contest in 2010 which might be a
The question is would it affect the aerodynamics of the wing? *If so
risk group.
My $0.02.
- John DeRosa
I have flown model XC soaring gliders for the past 22 years. It's not
unusual for the model to be over 3000 above and up to 1 mile away from
the pilot during the race.
I have used several types of the reflecting tape and found for the
models that the best result was with simple chrome film. The "swirly"
patterns may be good to simulate motion to a fish, but the plain
chrome gives a bigger brighter flash in the air.
Top Flite (modeling company) sells an adhesive film, marketed as
TrimCote, in a number of neon colors as well as the chrome. A 4"x30"
sheet is about $4 at most hobby shops. You can buy a selection of
colors and reflectivity and do your own evaluation. Checkerboard
patterns in several colors are also available!
Mike
Old October 17th 09, 03:44 PM posted to rec.aviation.soaring
bildan
article.
for examples.
risk group.
My $0.02.
- John DeRosa
I have flown model XC soaring gliders for the past 22 years. *It's not
models that the best result was with simple chrome film. *The "swirly"
TrimCote, in a number of neon colors as well as the chrome. *A 4"x30"
sheet is about $4 at most hobby shops. *You can buy a selection of
colors and reflectivity and do your own evaluation. *Checkerboard
Mike
A flash of reflected sunlight is by far the best way to see an
aircraft at long range. Simple "Heliographs" with 6" mirrors were
used by desert armies in the 19th century for "optical communication
networks" spanning hundreds of miles. Survival packs are still
equipped with signaling mirrors.
I've wondered if this technology could be brought into the digital
age. A simple 2" mirror driven by tiny stepper motors might direct
flashes at a known target. Of course, you'd have to know where the
observer was in 3D space, the sun angle as well as your own 3D
position and attitude. Fortunately, devices like FLARM can determine
that information. Even if I know the abstract location of another
glider, actually seeing a flash is comforting.
Old October 17th 09, 04:49 PM posted to rec.aviation.soaring
Jim Kellett
aircraft at long range. *. . .
age. *. .
snip
In a study done some years ago at the Cranfield Institute in the UK on
conspicuity schemes, one of the best was to put some highly reflective
foil - perhaps like that mentioned in an earlier post about RC models
- on the control surfaces of a glider (rudder, elevator, ailerons).
The movement of the control surfaces, far more frequent that movements
of the airframe itself, was remarkably good at alerting others of the
presence of the glider.
Military Paint Schemes Marco Leon Piloting 10 August 29th 07 11:38 PM
Aircraft paint schemes [email protected] Owning 4 December 31st 04 07:27 PM
Paint Schemes [email protected] Owning 0 December 29th 04 05:23 PM
High Visibility markings research? Craig Reynolds Soaring 2 June 3rd 04 11:25 PM
FS2004: Ceilings/visibility too high ajohnson Simulators 2 March 15th 04 10:55 AM
