Group,
I have a Karl Pfeifer trailer which is missing one of the two latches on the front access hatch. The latch has a little nub for your index finger, and a plunger you depress with your thumb. Ideally, I'd like a replacement that matches the existing bolt hole pattern, and just bolts on with no further modification. Hopefully someone in this group has done the leg work to source such a latch, or maybe someone has an old Pfeifer trailer to part out. Regards, David Walsh |
Try searching for "67 VW Beetle locking glove box latch" and see if
that matches your latch. Jim |
On Oct 15, 10:08*pm, David Walsh wrote:
Group, I have a Karl Pfeifer trailer which is missing one of the two latches on the front access hatch. * The latch has a little nub for your index finger, and a plunger you depress with your thumb. * Ideally, I'd like a replacement that matches the existing bolt hole pattern, and just bolts on with no further modification. * Hopefully someone in this group has done the leg work to source such a latch, or maybe someone has an old Pfeifer trailer to part out. Regards, David Walsh http://www.chircoestore.com/catalog/...i75b hhtipvv2 You need a deck lid. Check the length to get the correct one. Buy two with the same key, cheaper than rekeying yoour old one. |
On Oct 16, 12:08*am, David Walsh wrote:
Group, I have a Karl Pfeifer trailer which is missing one of the two latches on the front access hatch. * The latch has a little nub for your index finger, and a plunger you depress with your thumb. * Ideally, I'd like a replacement that matches the existing bolt hole pattern, and just bolts on with no further modification. * Hopefully someone in this group has done the leg work to source such a latch, or maybe someone has an old Pfeifer trailer to part out. Regards, David Walsh Jim, Tim Bingo! You guy's nailed it! That's what I was looking for, a bolt on solution, that doesn't need any modifying or rigging, and looks like it belongs with the trailer. What an obscure question to ask.....the next morning, I get an exact answer, with a link to the part!!! Thanks Guys! Once again r.a.s. kicks ass! Regards, David Walsh |
Karl Clauser Ft Worth, TX | Chris | Soaring | 0 | October 22nd 08 12:32 PM |
Latch repair on Cobra trailer | Tuno | Soaring | 2 | April 8th 08 01:21 AM |
Dog Days of Aviation, pt 2 - Fokker Dr-I 150-17 Oblt Karl Bodenschatz.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | June 5th 07 01:22 PM |
Ping karl and Matt: My JPI probes' ambient temperatures | Peter R. | Owning | 8 | October 6th 06 05:29 PM |
Karl Jatho | robert arndt | Military Aviation | 1 | December 19th 03 08:54 AM |
