#41
Ed Rasimus wrote:
: In 1966, while I was flying the F-105 over N. Vietnam, we lost one : every 65 missions. In 1991, during Desert Storm we lost one fixed wing : aircraft every 3500 mission. In 2003 in Iraqi Freedom we lost one : fixed wing aircraft in 16,500 mission. However, the last two operations were characterized by an almost total lack of opposition in the air. The biggest threat to US combat aircraft these days seems to come from small and IR-guided, portable missiles; or even from machine guns. Very expensive anti-radar stealth seems to offer little protection against these. Reducing the IR signature seems to be more useful, but only really effective against a primitive seeker. (But MANPADS tend to be much smaller than AIM-9 and I suppose that it will be difficult to equip them with an all-aspect or imaging IR seeker.) : Stealth aircraft are more survivable. We don't have many, because the : military competes for $$$ against the welfare princesses and : redistribution of wealth candidates who run for election on a platform : of taking from "them" and giving to the masses. AFAIK the US social security system runs with a positive balance, i.e. money is flowing from it into other departments, not the other way around. But that aside, the US military budget is huge, it vastly outspends every other nation, and if it has few stealth aircraft that is in part because until now, these have really been prohibitively expensive both to buy and to operate in large numbers. Besides, the numbers were not needed anyway: The B-2 and even more so the F-117 were ver^y specialized designs, and aircraft that require special maintenance procedures and climate-controlled hangars are of limited operational usefulness. For stealth to be really useful, it must be made compatible with dirt strips and pierced metal planking. However, that was in part because the design of the F-117 and the B-2 were willing to compromise very little stealth for other characteristics. The F-22 and F-35 must involve an increase in RCS as a penalty for lower cost and easier maintenance, while relying on new materials and manufacturing procedures to get good results. Part of the attractiveness of a new design is that it may actually be cheaper to buy and operate than its precedessor. Manufacturers and officials seem to have promised this for every weapons program since the late 1960s; I don't actually know of a program that also achieved this goal. For the F-22 a high degree of stealth may be worth the investment. For the F-35 I am not so su I expect that 80% of the time, these aircraft will be flying with large non-stealthy external ordnance. -- Emmanuel Gustin |
#42
![]() "Emmanuel.Gustin" wrote in message ... Ed Rasimus wrote: snip The B-2 and even more so the F-117 were ver^y specialized designs, and aircraft that require special maintenance procedures and climate-controlled hangars are of limited operational usefulness. They have already proven their operational usefullness. In view of that fact, the above is an unsupportable assertion. For stealth to be really useful, it must be made compatible with dirt strips and pierced metal planking. It already is "really useful". The loss of one stealth aircraft against how many hundreds of sorties into environments that were rich with radar directed threats in Iraq and former Yugoslavia. Again, your statement is not supported by the facts. snip Emmanuel Gustin |
#43
![]() "fudog50" wrote in message ... Yes, in addition to a 60,000 (?) lb rated holdback chain. The F-105 had to be chained down for trim. On Fri, 09 Jan 2004 18:19:16 GMT, Ed Rasimus wrote: On Fri, 9 Jan 2004 09:50:55 -0800, "Tarver Engineering" wrote: I think we can pretty well know the iris on the J-75 was taking out 1% of the F-105s. Are you referring to the turbine Christmas tree? Failures of the Christmas tree which held the three stages of turbine blades caused a number of unexplained losses. I mention the bailout of Joe Vojir on takeoff at Korat as well as the loss of Buzz Bullock and Dain Milliman in takeoff accidents caused by turbine failure in When Thunder Rolled. The AB nozzle (iris) didn't cause any accidents that I know about. And, the nozzle is not synonymous with the speed brake petals or pizzas (which were removed in '65). When Ed posted here that the F-105's brakes could not hold the airplane in AB, I could see that iris stuck open/closed/half way between. No afterburner equipped aircraft that I know about can be held by wheel brakes in AB. Carrier aircraft get into AB for launch by employing a "hold back". The F-4, for example, couldn't be held in military power by the wheel brakes. Engines were checked at 100% one at a time. Takeoffs were done with a runup to 85% prior to brake release, then to mil and finally to AB. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
#44
Kevin Brooks wrote:
: The B-2 : and even more so the F-117 were very specialized designs, and : aircraft that require special maintenance procedures and : climate-controlled hangars are of limited operational usefulness. : They have already proven their operational usefullness. In view of that : fact, the above is an unsupportable assertion. I wrote "limited operation usefulness", not "no operational usefulness". Penalties such as these are acceptable for a small number of aircraft with specialized roles. They are not acceptable for the main body of an air force. If the F-16 had had the maintenance requirements of the B-2, the Gulf Wars would simply not have been fought. In some ways stealth has been a backward step; since the 1960s engineers have aimed to reduce maintenance requirements and turn-around time, and to make aircraft less dependable on well-equipped bases. The need for this was obvious in Korea and Vietnam, as well as from the budget... The first generation of stealth aircraft reversed this trend, a most unwelcome limitation on their use. : For stealth to be really useful, it must be made compatible : with dirt strips and pierced metal planking. : It already is "really useful". The loss of one stealth aircraft against how : many hundreds of sorties into environments that were rich with radar : directed threats in Iraq and former Yugoslavia. Allow me to point out that the USAF has bought only 59 F-117s and equipped only two operational squadrons with them. To me this reflects a rather sober view of the operational usefulness of the type: An useful accessory to the arsenal, but not able to replace more conventional types. Before Stealth can be incorporated in the backbone of the air frce, serious technical problems need to be solved, and compromises must be made. It is true that the loss rate of the F-117 has been low: The low rate of other USAF aircraft has also been low, to the point of making a comparison statistically insignificant. -- Emmanuel Gustin |
#45
![]() incorporated in the backbone of the air frce, serious technical problems need to be solved, and compromises must be made. It is true that the loss rate of the F-117 has been low: The low rate of other USAF aircraft has also been low, to the point of making a comparison statistically insignificant. -- Emmanuel Gustin Sort of a narrow view of air operations, I would say. Having particiapted in a number of 100 plane raids in SEA against a single point target that a single B-2 cold take out now I'd say the tradeoffs with Stealth is no brainer. The high maintenance requirements for stealth and the controlled hangar environments are mainly a matter of materiels used in maintaining stealth coatings and those materials have been much inproved in the past decade. |
#46
Your comment that was refuted was that Boyd & Co. and Stealth were two
concepts gleaned from Vietnam that were proven erroneous or invalid. Boyd's work on energy maneuverability and three imensional maneuver is still the basis for 1-v-1 BFM and led to the development of supporting element maneuver in multi-plane engagement. Without Boyd, we'd still have Eagles, Vipers and Raptors running around in fighting wing. Everything you said is correct and explains why the ideas of Boyd&Co were "fundamentally" wrong. They developed tactics for a world without situational and global awaraness tools and designed warplanes to excel under such circumstances. Lets put that way, during Vietnam war US had only rudimentary situational awareness tools no global awareness tool at all. Boyd&Co identified wrong problem and tried to solve wrong problem with a step in the wrong direction,the real reason for not so perfect performance of US aircraft in Vietnam was not their inability to perform high energy maneuvers or missing cannons,it was unavailability of situational and global awareness tools that we have today. So,it would be much better if Boyd and others should have asked a couple of questions to themselves before developing their concepts: a)How it would be if US had total situational awareness in Vietnam? b)Whats if such tools brcome available in next 10-15 years? Unfortunately they developed their concepts without answering such questions and also without fully understanding the direction of technological development,so we have now full situational and global awareness but also 100 M $ fighters that are not only capable of destroying MIG17s in dogfights also capable of doing jack knife type fighting with Red Barons Fokker. But thanks to such wonderful capabilities that they never ever need under full situational awareness conditions,their ranges will never meet the criterias. Stealth, and the idea of denying the defenses accurate az/el/range data through a variety of technologies is going to be a foundation for aircraft (and defense) designs for a long time to come. Thats even worse than Boyds ideas,"passive" stealth was already obsolete in 70s,(Might stay as a foundation for aircraft designs for a long time to come though,specially if your adversaries are backward third world countries like Panama,Iraq,Iran,NK,Somalia,Zambia etc) As for what "combat vets should try to do", please acknowledge that like all professions, military aviators are not one-dimensional humans. We do a lot of things in a life time, and don't simply disappear into the attic when the war is over. I hope so,but Let me repeat the Battleship example,after Mitchell demonstration it was obvious the the era of Battleships was over but Admirals all over the world continued to order bigger better ,more capable and of course more expensive Battleships (their showboats) till they learn the truth hard way during WWII, I am pretty sure,without WWII we,and probably everbody else, would still be building bigger and better battleships.As for the relevance of the lessons of Vietnam to F-16, F-22 or SU-37, let me point you to Santyana---"those who will not learn the lessons of history are condemned to repeat them." Thats true but only if learn correct lessons. Lots of science and technology, but it is directed by the experiences gathered along the way. You gotta problem wid dat? Historically wars,unfortunately,were one of the driving forces behind the scientific&technological development but calling Boyds ideas and passive stealth a development would be strecth |
#47
the B-2 were willing to compromise very little stealth for other characteristics. The F-22 and F-35 must involve an Frontal RCSs of B2 and f22 are identical. |
#48
![]() I don't understand why such emphasis is put on that stealth stuff when we use the same old planes from previously. We have less tolerance today than we did in 1970 for losing our pilots in combat against enemy air defenses. I'll bet there were days when Ed Rasimus wished that his F-105 had stealthy characteristics. all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
#49
![]() Boyd&Co identified wrong problem and tried to solve wrong problem with a step in the wrong direction, Would you share with us your combat flight experience? all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
#50
"Cub Driver" wrote
I'll bet there were days when Ed Rasimus wished that his F-105 had stealthy characteristics. It wouldn't have mattered, as the white house was building the ATO, and most of them flew the same waypoints year after year. It was a war designed to be lost, by officers who were pretty much derelict in everything they did. |
Stealth homebuilt | C J Campbell | Home Built | 1 | September 15th 04 08:43 AM |
SURVEY on manuals - most important for builders, but never good?? | T-Online | Home Built | 0 | January 23rd 04 04:37 PM |
F-32 vs F-35 | The Raven | Military Aviation | 60 | January 17th 04 08:36 PM |
How long until current 'stealth' techniques are compromised? | muskau | Military Aviation | 38 | January 5th 04 04:27 AM |
Israeli Stealth??? | Kenneth Williams | Military Aviation | 92 | October 22nd 03 04:28 PM |
