Declared first emergency last week
Old September 10th 09, 09:09 PM posted to rec.aviation.piloting
Mickybadia
Default [OT] Declared first emergency last week
Black holes are where God is dividing by zero.
Sorry to be useless, but LOL
  #32
Old September 10th 09, 11:18 PM posted to rec.aviation.piloting
Flaps_50!
Default Declared first emergency last week
On Sep 8, 5:28*pm, EventHorizon wrote:
I thought you might all find this story interesting.
Me, I'm 53 and have been flying since 1988 with about 1000 hrs. My
partner is a CFI and we've been in a Cherokee 140 partnership for about
12 years. We have a 1974 Cherokee Cruiser, which we normally keep well
maintained (!).
About a week ago my partner and I decided to fly after work. We are
still breaking in a new cylinder so we thought we'd fly local here in
Southern California. I flew left seat and we took off from Camarillo and
flew around Malibu, then I flew over to Santa Paula for a landing. We
had agreed we wanted to fly about 1.5 hrs, so as I was landing at Santa
Paula I was at about 45 minutes. After I landed I asked my partner if he
wanted to switch sides, but he said no, he'd fly from the right side.
We taxied back and he took off. At about 1500'agl he tapped me on the
shoulder (I was looking outside for traffic). He said "we have a
problem". There had been no apparent change in the flight so I thought
he might be joking. He pointed down at the throttle and he was moving it
full to idle and back, but it had no effect! We were still at full
throttle and obviously we had a broken cable or something similar.
So your mind goes rapidly over the situation. How bad is this? What are
the challenges? What are the options? We had a brief discussion and I
mentioned that although this didn't seem real bad, we had some risks and
I had read so many stories of pilots being reluctant to declare an
emergency. We were only about 5 miles from Camarillo, our home airport
which has a 5000' runway. We discussed and within about 20 seconds
agreed that I would fly the plane since I was left seat, he would handle
radio, and we would declare and emergency since we did not have throttle
control. We had decided that I would try to modulate power with the
mixture, but if necessary I could fly over the the airport and then just
kill the engine and we would glide down.
The weather was very clear and it was just about dusk. My partner called
Camarillo tower, reported our position (about 5 miles out) and indicated
we had a throttle problem and we needed to declare and emergency. The
tower immediately cleared us to land on runway 8 and cleared out one
other plane in the pattern. The runway in use was 26 but it was calm and
rwy 8 was the closer approach. I was at about 1700' and full power; I
leveled off and flew at about yellow line toward the airport. As I got
closer I started a dive to lose altitude and flew fast; I had not yet
adjusted the mixture.
I realized that I was going to be quite high - I was on a 1 mile base so
I began to pull the mixture back and the engine roughened as it slowed
down some more. Still flying fast, I descended. I realized I was still
pretty high so I overshot the centerline a bit before turning to about a
.5 mile final to lose some more altitude. I leaned the mixture more
aggressively and the engine ran really rough with some backfiring.
As we came in a bit high on final and I knew the runway was assured I
asked my partner for flaps. I leaned more aggressively and the engine
was really choking now. As we came over the threshold a bit high I told
my partner I was going to kill the engine. I didn't want to be trying to
modulate a full throttle enging with mixture once I was on the runway.
About 20 feet or so I pulled to idle cutoff and it was weird to see a
prop stopped as I flared for a nice landing. I rolled out and used
residual speed to pull off on a turnoff and coast to a stop.
Airport security showed up and the guy didn't quite know what to do. We
told him we just needed a tow into our tiedown spot. He took our names
and certificate numbers and a brief statement of what had happened.
In discussion with my partner, we felt we did almost everything
correctly. We did not panic, we did not hesitate to declare the
emergency, we quickly agreed on roles and everything went smoothly. We
never really felt scared about the situation (a power failure might have
felt different!). When the situation first presented itself I thought
about flying to over the airport and cutting power, but I felt it would
be better not to have a guaranteed engine failure. We both felt this was
the less-risky way to handle the situation. We sort of stood there
saying to ourselves "we can't believe we just had an emergency!". It was
the first one for both of us in more than 20 years of flying each.
The plane is in the shop to get its cable replaced, apparently it broke
somewhere between the throttle quadrant and the carburetor, not at
either end.
Event Horizon
Glad it worked out so well.
Cheers
  #33
Old October 25th 09, 03:32 PM posted to rec.aviation.piloting
Aluckyguess[_4_]
"BeechSundowner" wrote in message
On Sep 9, 8:44 pm, Dana M. Hague wrote:
Sounds like you handled the situation well, but it doesn't sound like
an "emergency". My understanding is that you declare an emergency
when you need assistance or clearance RIGHT NOW. In this case, you
weren't in any imminent danger;
Judgement call on the pilots part as you already know, but if you
can't control the engine, if that isn't an emergency, I don't know
what is. For all intent and purposes, he had a runaway plane until he
worked the problem!
No, you still had at least 2 ways to control the engine.
  #34
Old October 27th 09, 10:39 PM posted to rec.aviation.piloting
Ken S. Tucker
worked the problem!
Sounds like OP had a good battery, something I would check then I
would've dialed the emergency frequency, tell tower my situation and
put myself into position for a 'dead-stick', mags-off.
It's a good case to practice some 'dead stick' landings. AFAIK you
should be able to kill the bird anyway in the circuit and dead stick.
That's how I was trained on a cessna-152.
Ken
  #35
Old October 28th 09, 12:23 AM posted to rec.aviation.piloting
Brian Whatcott
Ken
It used to be training SOP to pull the throttle to idle onto base
until the cold shock issue forced a gentler kinder approach
Brian W
  #36
Old October 28th 09, 02:54 PM posted to rec.aviation.piloting
Ken S. Tucker
Ken
Brian W
Never heard of that, but I can understand it.
Ken
  #37
Old October 28th 09, 04:46 PM posted to rec.aviation.piloting
Orval Fairbairn[_2_]
In article
Ken
Brian W
Ken
I was taught to pull the power on downwind, even with the desired
touchdown point.
Remove _'s from email address to talk to me.
  #38
Old October 28th 09, 04:59 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
On Oct 28, 12:46*pm, Orval Fairbairn
In article
Ken
Brian W
Ken
touchdown point.
Remove _'s *from email address to talk to me.
This was pretty standard procedure during the period when I learned to
fly. As an instructor I "altered" the way I approached this a bit by
stressing proper stepped down power reduction on letdowns prior to
entering downwind so that by the time the power was reduced on final,
the engine temps and pressures were under control.
There's always been a "discussion" about the advantages and
disadvantages of doing power off approaches as practice for forced
landings.
What I did was to treat forced landing practice as forced landing
practice and otherwise stressed proper engine management as suggested
by the engine manufacturer.
Dudley Henriques
  #39
a[_3_]
In article
Ken
Brian W
Ken
touchdown point.
In my Mooney with its IO 360, we consider it a good approach if the
throttle does not have to be advanced from downwind until turning off
of the active (and using the brakes to slow down on the runway is
considered bad form). At most airports I use good planning would be a
touchdown maybe a 1000 feet past the numbers to make the first turnoff
comfortably, so my thinking is if the engine chooses to fail I do have
some altitude in the bank.
  #40
Old October 28th 09, 05:04 PM posted to rec.aviation.piloting
Ken S. Tucker
On Oct 28, 9:46 am, Orval Fairbairn
In article
Ken
Brian W
Ken
touchdown point.
Yeah, I had no prob with dead stick, but I respect what Brian wrote,
as I flew a lot in cold weather. Shutting off the heat flow to the air
cooled fins, while the core (cylinder temp) is hot and the exterior
cools rapidly may induce a thermal gradient stress due to uneven
contraction of the metal as it cools from the outside in.
Ken
A few from - Last Week 00.jpg (0/1) RustY© Aviation Photos 1 May 23rd 08 02:01 PM
More Evidence Bush Was Actually Declared a Deserter WalterM140 Military Aviation 9 August 23rd 04 11:36 PM
Declared "minimum fuel" O. Sami Saydjari Instrument Flight Rules 14 April 4th 04 02:43 AM
A record: 1 in 73 US households declared bankruptcy in '03 Krztalizer Military Aviation 7 March 15th 04 09:27 PM
