#51
![]() "Gene Storey" wrote in message news:tzwMb.10086$6l1.1052@okepread03... snip It was a war designed to be lost, by officers who were pretty much derelict in everything they did. Well, the comment about micromanagement from the White House was generally accurate, so I guessed you are getting a *bit* better, but then you toss out this unsubstantiated crap. Please provide some evidence that US military officers intended to lose the war...no? That's right, you can't. No doubt there were decisions made by some officers that were, in hindsight, wrong. But "pretty much derelict in everything they did"? It is amazing that you have recently spent so much time and effort defending the actions of folks like Hitler and Saddam, and then come out with an indictement like the above. Brooks |
#52
#53
#54
Which is:
1.) incorrect I hate to disappoint you,but correct 2.) irrelevant. You are correct here,in the era of multistatic and UWB radars,classical RCS values are IRRELEVANT. |
#55
#56
![]() "Denyav" wrote in message ... I hate to disappoint you,but correct Prove it. |
#57
You garble apples and oranges here. While situational awareness is
critical, it's not the same issue as developing the principles of three dimensional maneuver between two aircraft. The analytical tools of P-sub-s diagramming to compare aircraft and optimize your own performance are important and whether or not you possess total SA I think you are contradicting yourself here,you gave an excellent answer to another poster and explained how things are done in the era of full situational awareness,as you correctly implied there is no need to acquire target with your Mk.I eyeballs,you dont even need to acquire target with your own sensors,somebody else could do it for you,what you need is only to fire your missiles. Do you need high energy manouvers or jack knife type fights for that? If we had current SA tools in 60s,the Missilleer project would be a great success. And, we still don't have total SA. AWACS and data-fusion/sharing are great advances, but the "fog of war" will remain. We did have Disco, Red Crown, T-Ball and Combat Tree as well as our own sensors and nav Fog of war will always be part of the business. Let me give a simple example, Is there any guarantee that your family will start every time when you turn the ignition key? No But no auto manufacturer nowadays offers cranking handle type starting option in their cars. You really should read a bit more history. While F-4s without guns got a lot of notice, there were a lot more gun-equipped aircraft than non-gun. The failures didn't relate to lack of SA as much as to political gradualism and lack of will to win. Factors you mentioned were obviously the main factors at the national decision making level,but less relevant at air-air combat level. You really should read a bit more history. While F-4s without guns got a lot of notice, there were a lot more gun-equipped aircraft than non-gun. The failures didn't relate to lack of SA as much as to political gradualism and lack of will to win. The answer is easy. It would be great. But, if you are running the war for political purposes and trying to avoid major power nuclear confrontation, it doesn't matter what your SA is. Unless you bombed production bases of NV,which were located inside USSR and China,you would not risk a nuclear war. Politically it does not matter much how you shoot down an enemy plane,with guns or with BVR missiles.I did not distinguish active or passive stealth, but simply refuted your contention that stealth is a failure. Loss rates for stealth aircraft are statistically zero and target success rates are very close to 100%. It makes little difference whether the opposition is first or third world. Target success rate during DS I is more close to 1/10 th of what you are quoting and during Balkan conflict more f117s damaged than convantionel ones,even though f117s made up only small part of allied air fleet. Regarding target success rate during whole Balkan war only 3 serbian air defense radars were destroyed. Even simple internetting of old serbian radars proved to be very effective aganist stealth aircraft. Did you ever wonder why US started destroying Chinese built Iraqi fiberoptic network months before starting of Iraqi freedom using Special Forces and no fly zone flights? Chances of stealth aircraft aganist a sophisticated enemy using multistatics and/or UKW radars? Not any better than an old battleship without air cover. |
#58
#59
"Kevin Brooks" wrote
"Gene Storey" wrote Please provide some evidence that US military officers intended to lose the war The war was lost, and officers are in charge of war. It was lost in 1946 when we allowed the French to decolonize. http://www.lexisnexis.com/academic/2...ietnamMACV.asp Basically, if you fly a B-52 down the same route as the previous three B-52, and do it at the same altitude, and with the same waypoints, you and whoever drew-up the operation are derelict. The fact that anyone survived is pure luck, and those that died were very brave, but very wasted (much as going over the top in the great war in the face of machine guns). The way to lose a war is to suffer casualties so great, with such waste, the people back home won't want to go, and either burn their draft cards, or joined the Reserves. |
#60
Stealth homebuilt | C J Campbell | Home Built | 1 | September 15th 04 08:43 AM |
SURVEY on manuals - most important for builders, but never good?? | T-Online | Home Built | 0 | January 23rd 04 04:37 PM |
F-32 vs F-35 | The Raven | Military Aviation | 60 | January 17th 04 08:36 PM |
How long until current 'stealth' techniques are compromised? | muskau | Military Aviation | 38 | January 5th 04 04:27 AM |
Israeli Stealth??? | Kenneth Williams | Military Aviation | 92 | October 22nd 03 04:28 PM |
