Master contactor question
Old November 3rd 09, 09:01 PM posted to rec.aviation.homebuilt
Peter Dohm
Default Master contactor question
On Tue, 3 Nov 2009 06:55:10 -0800 (PST),
On Nov 2, 11:08 pm, wrote:
Define "substantial" and a fuse or breaker WILL disconnect it if
something goes wrong.
And if that fuse or breaker is in the cockpit, you still have
a live feed to it even if it trips. If it's next to the battery
somewhere else, you can't shut it off, reset it or replace it in
flight.
Dan
NEVER attempt to replace a fuse in flight. Assume it blew for a
reason. Concentrate on flying the plane, not fixing it, until you are
on the ground. The ASSumption was the fuse is at the battery. Anywhere
else it is USELESS for protecting the wire.
Generally true, especially for a main electrical circuit, and there is an
excellent argument for always placing a fuse as near as practical to the
power source and sized to protect the wire. I would also replace the fuse
at each annual--since "everything" corrodes in the climate where I live--as
a way to assure that any failure of the fuse is indeed for a reason; because
the 2 or 3 year replacement cycle, that a reasonable person would expect,
would only assure that the replacement will be forgotten and that corrosion
will cause the fuse to heat and fail. (When I was growing up, we leared to
keep our spare household fuses in tightly sealed glass jars so that they
would remain serviceable when needed.)
There are a couple of exceptions to the "do not replace" and "do not reset"
rules--the classics being the need to retract the flaps in order to "go
around" or, on some airplanes, to lower the wheels.
Peter
  #42
Old November 4th 09, 12:53 AM posted to rec.aviation.homebuilt
On Tue, 3 Nov 2009 16:01:25 -0500, "Peter Dohm"
flight.
Dan
Peter
A good reason to have manual flaps - and a non-electric "emergency"
wheels down mechanism.
If the fuse blew for a reason, you want to be able to get the wheels
down - WITHOUT electricity
Master cylinders [email protected] Home Built 25 July 29th 08 02:08 AM
Battery Contactor Diode? Skrud Home Built 25 September 11th 06 06:17 PM
PA28-180 Power Contactor Relay source? Mike Noel Owning 5 August 10th 05 04:40 AM
Master Switch Lakeview Bill Piloting 23 July 20th 05 01:46 AM
RC Plane Master Steve Simulators 0 December 20th 03 02:40 PM
