Wanted: Article from Soaring, March 1998
Old November 16th 09, 03:58 PM posted to rec.aviation.soaring
Doug Hoffman[_3_]
Default Wanted: Article from Soaring, March 1998
On Nov 16, 10:38*am, JJ Sinclair wrote:
Are we talking about the mod where the pivot bolt is hack-sawed away
from the brake housing and allowed to float free?
No. Steckner specifically warns to *not* do that as he had heard that
some tried it with the results you describe. I will send you the
article.
Regards,
-Doug
Old November 16th 09, 06:49 PM posted to rec.aviation.soaring
jsbrake
I have been given an electronic copy of the article.
Thanks to all for the advice and information, both in the forum and
directly -- I greatly appreciate it.
Anyone know of a Canadian company? I think it would be easier than
back and forth across the border.
Thanks!
John
Old November 17th 09, 02:39 PM posted to rec.aviation.soaring
JJ Sinclair
No. *Steckner specifically warns to *not* do that as he had heard that
some tried it with the results you describe. *I will send you the
article.
Regards,
-Doug
My condemnation was in reference to the 'cut-off pivot bolt'
modification which will lock the brake. The Tillmann modification is
well thought out and should give much better braking if the close
tolerence parts are properly constructed and installed. I stand
corrected.
JJ
Soaring Webinar, Saturday, March 7th Frank Whiteley Soaring 10 March 8th 09 02:39 AM
Soaring Seminar Pennsylvania March 29/30 [email protected] Soaring 0 December 9th 07 07:13 PM
March '07 Soaring: Glider Stamp from Yugoslavia [email protected] Soaring 3 April 5th 07 11:35 PM
Soaring Seminar March 24 [email protected] Soaring 0 February 21st 07 11:59 AM
Marfa Soaring Report Saturday 20 March Snead1 Soaring 0 March 22nd 04 02:58 AM
