visualisation of the lift distribution over a wing
Old November 29th 09, 01:07 AM posted to rec.aviation.homebuilt
Brian Whatcott
Default visualisation of the lift distribution over a wing
Stealth Pilot wrote:
/snip/ it is the air below pushing
you up that lifts the wing.
Stealth Pilot
In most circumstances, suction on the upper surface contributes about
2/3 rds of the lift, and pressure on the lower surface contributes about
1/3 rd.
That's one reason which rib stitching for rag wings is a biggy.
Brian W
Old November 29th 09, 03:12 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Stealth Pilot
1/3 rd.
Brian W
At high angle of attach - maybe 1/3 on the bottom.
Especially along the leading edge.
At cruise, I believe the lower surface is closer to ambient pressure.
Old November 29th 09, 03:16 AM posted to rec.aviation.homebuilt
Alan Baker
Stealth Pilot
1/3 rd.
Brian W
Ummmm...
It sort of depends what you mean.
If you mean that suction is actually providing an upward force, you're
quite mistaken.
If you mean that the difference in pressure between upper and lower
surfaces is 2/3 the result of lower pressure on the upper surface, then
you might be right. I don't know.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old November 29th 09, 03:57 PM posted to rec.aviation.homebuilt
Brian Whatcott
Stealth Pilot
1/3 rd.
Brian W
Ummmm...
quite mistaken.
Interesting comment: what would YOU call it when the fabric on the upper
wing surface wants to pull away from the ribs?
Brian W
Old November 29th 09, 04:51 PM posted to rec.aviation.homebuilt
Scott[_7_]
Stealth Pilot
about 1/3 rd.
Brian W
Ummmm...
quite mistaken.
then you might be right. I don't know.
Brian W
It's the "wind" blowing through the bottom surface, inflating the wing
like a balloon
Old November 29th 09, 08:18 PM posted to rec.aviation.homebuilt
Alan Baker
Stealth Pilot
1/3 rd.
Brian W
Ummmm...
quite mistaken.
Air pressure from inside the wing pushing up on it more than the air
above is pushing down...
Alan Baker
Old November 30th 09, 12:17 AM posted to rec.aviation.homebuilt
Morgans[_2_]
I hope you are pulling someone's leg, and that your are not that inept in
the field of aerodynamics and physics.
Jim in NC
Old November 30th 09, 12:29 AM posted to rec.aviation.homebuilt
Alan Baker
No, I'm quite serious.
The reduction in *pressure* on the upper surface of the wing cannot
produce any force except downward. A perfect vacuum over the entire
upper surface wouldn't produce any upward force, but simply *zero*
force; allowing the upward force on the lower surface to act alone.
Anyone who thinks that the pressure of a fluid on a surface can act in
any direction but towards the surface is simply wrong.
Alan Baker
Old November 30th 09, 01:19 AM posted to rec.aviation.homebuilt
Brian Whatcott
Let me take a wild guess he you did physics for an uundergraduate
degree. Is that right?
Brian W
Old November 30th 09, 02:19 AM posted to rec.aviation.homebuilt
Steve Hix[_2_]
For a couple of seconds, perhaps.
Wings aren't typically hermetically sealed.
Brian W
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
