visualisation of the lift distribution over a wing
Old November 30th 09, 03:08 AM posted to rec.aviation.homebuilt
Alan Baker
Default visualisation of the lift distribution over a wing
brian whatcott wrote:
Alan Baker wrote:
Interesting comment: what would YOU call it when the fabric on the upper
wing surface wants to pull away from the ribs?
Air pressure from inside the wing pushing up on it more than the air
above is pushing down...
Let me take a wild guess he you did physics for an uundergraduate
degree. Is that right?
Brian W
No. But it doesn't matter.
If the fabric is moving upward, it can only be because there is more
pressure on its bottom surface than there is on its top surface.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old November 30th 09, 03:19 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
For a couple of seconds, perhaps.
Wings aren't typically hermetically sealed.
Brian W
I'll take Physics Majors for $500, Alex!
Old November 30th 09, 03:20 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Brian W
I'm kind of curious about how that higher pressure got on the bottom
of that wing though...
Old November 30th 09, 04:38 AM posted to rec.aviation.homebuilt
Brian Whatcott
Brian W
It seems that you are uncomfortable with the entire concept of suction.
For example, how do you suppose suction cups work?
Or how about a suction pump that happens to be limited to a 30 ft lift?
Well duh, it's also atmospheric pressure that enables suction pumps and
suction cups etc., etc. Yes indeed , but it's an academic issue at
the junior high level, isn't it?
Brian W
Old November 30th 09, 04:39 AM posted to rec.aviation.homebuilt
Morgans[_2_]
"Alan Baker" wrote
Anyone who thinks that the pressure of a fluid on a surface can act in
any direction but towards the surface is simply wrong.
I see. You are not lookng at the wing as a system, but taking an
observation at one point only, without reguard to what is happening around
it.
Point made.
Jim in NC
Old November 30th 09, 05:20 AM posted to rec.aviation.homebuilt
Beryl[_3_]
it.
Point made.
He looked inside the wing, at the entire upper surface, at the lower
surface... that pretty much covers most of it. Air can't be in tension.
Old November 30th 09, 05:48 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
upper wing surface wants to pull away from the ribs?
Brian W
Have you ever seen the top surface of a fabric covered wing?
The skin does not bulge upwards.
Not usually anyway.
  #28
Old November 30th 09, 05:49 AM posted to rec.aviation.homebuilt
Jim Logajan
If it had a stressful day it might become tense. Air can be under a lot of
pressure at times, and work can cause it to get hot. Put under too much
pressure, air can blow a gasket.
That's why it's best to let air blow off steam after a hard day at work and
maybe offer it a smoke with a gin and tonic to cool off:
http://www.bobblum.com/Images/Humor%.../subgenius.jpg
  #29
Old November 30th 09, 05:55 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
I think it's about time for a little remedial aerodynamics for the group.
http://www.messybeast.com/dragonqueen/liftdemon.htm
LIFT DEMONS AND THRUST PIXIES
Title of Paper: The Role of Lift Demons and Thrust Pixies in Heavier Than Air Flight
Publication Date: 2004
Abstract: The role of Lift Demons in aeronautics was first explained in 1994 by
Mary Shafer (NASA). Since then, Shafer's work has been explored and revised.
This paper summarises advances in Lift Demon technology over the last decade.
Keywords: Lift Demons, Thrust Pixies, lemon fondant
Authors: Sarah Hartwell, DEF Smith, Peter Rieden, Gavin Bull
  #30
Old November 30th 09, 06:10 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Yes, but the person that observed that the pressure on the bottom was one
third responsible (for lift) and the low pressure on top was responsible for
two thirds of the lift is also correct, when you look at the wing as a whole
system, even if those fractions are approximate.
I think his view of individual points of observations are splitting
toadstools.
But that is my opinion, and like everyone, we all have but-holes and
opinions.
Jim in NC
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
