So long
Old November 29th 09, 05:36 PM posted to rec.aviation.soaring
Ian
Default So long
Dear All
It's been a while since I've been much of a contributor here, but I've
been around since about 1992, when I took up gliding. No more, though
- my Pirat went off to a new home today and I am now officially an ex
glider pilot ... for the next few years I plan to concentrate on
sailing.
I'd therefore like to say a hearty thanks and goodbye to all those I
have talked to, argued with and learned from on here. Good flying to
you all.
Ian
Old November 30th 09, 04:22 AM posted to rec.aviation.soaring
glidergeek
Default So long
No not cheaper, you could drown, get eaten by sharks and no way could
you do 500k in 4-5 hours. And really....what do you do if the wind
stops? hahaaaaaaaaaa. Couldn't resist that one, get it? In a glider
you just glide, in a sailboat you gotta start the motor, what if the
motor wont start? You'll be screwed matie.
Old November 30th 09, 04:58 AM posted to rec.aviation.soaring
ZZ
Default So long
Ian
I did that once...just once. I discovered that I could not overcome
motion sickness while in the boat. I went back to flying gliders.
Perhaps you will return too someday.
Regardless, good luck.
Paul
ZZ
Ian wrote:
Dear All
sailing.
you all.
Ian
Old November 30th 09, 05:00 AM posted to rec.aviation.soaring
Pete[_5_]
Default So long
He's right, as a sailboater, you have bigger problem now but what you
need is more help from a soaring friend, in this case, a British
Seagull motor.
Old November 30th 09, 05:57 AM posted to rec.aviation.soaring
Jim Logajan
Default So long
sailing.
you all.
But I only just got here (relatively speaking!) Have fun sailing - I still
have a very old copy of "Chapman Piloting, Seamanship, and Small Boat
Handling" when I took a short stab at it a couple decades ago. At least in
gliding I don't have to learn how to tie those bloody knots!
Remember the old adage: a boat is a hole in the water in which you throw
your money. But is there a similar adage about gliding?
[OT] So Long Integrity the Arse Pounding Shetland Pony Piloting 0 November 2nd 09 01:49 PM
AOPA Expo, meeting JayB, getting stuck in Lancaster on the way home,fulfilling the commercial certificate long solo x-c...long Jack Allison Piloting 6 November 19th 06 02:31 AM
Why do I Fly? (LONG) [email protected] Piloting 18 September 20th 06 02:56 PM
Been AFK too long Jeff Piloting 3 July 20th 06 02:24 PM
Another Long Cross Country: HPN to PAO in 6 Days (long) Journeyman Piloting 19 June 15th 06 11:47 PM
