visualisation of the lift distribution over a wing
Old November 30th 09, 12:42 PM posted to rec.aviation.homebuilt
Brian Whatcott
Default visualisation of the lift distribution over a wing
cavelamb wrote:
Have you ever seen the top surface of a fabric covered wing?
The skin does not bulge upwards.
Not usually anyway.
I find your tone impertinent.
Brian W
  #42
Old November 30th 09, 12:46 PM posted to rec.aviation.homebuilt
Brian Whatcott
Alan Baker wrote:
brian whatcott wrote:
Alan Baker wrote:
Interesting comment: what would YOU call it when the fabric on the upper
wing surface wants to pull away from the ribs?
Air pressure from inside the wing pushing up on it more than the air
above is pushing down...
Let me take a wild guess he you did physics for an uundergraduate
degree. Is that right?
Brian W
No. But it doesn't matter.
If the fabric is moving upward, it can only be because there is more
pressure on its bottom surface than there is on its top surface.
It seems that you are uncomfortable with the entire concept of suction.
For example, how do you suppose suction cups work?
The pressure outside the cup keeps it in place.
Or how about a suction pump that happens to be limited to a 30 ft lift?
Because a vacuum cannot do any actual pulling, you can only lift water
as far as the pressure allows, right.
Well duh, it's also atmospheric pressure that enables suction pumps and
suction cups etc., etc. Yes indeed , but it's an academic issue at
the junior high level, isn't it?
Yup.
OK you certainly cut the cookie at Junior High.
Now can we go back to using terms like suction the way 99.99% of the
technical and scientific population understands it? :-)
Brian W
  #43
Old November 30th 09, 12:48 PM posted to rec.aviation.homebuilt
Brian Whatcott
Alan Baker wrote:
Nope.
I'm making the point that the upper surface contributes absolutely *no*
lifting force.
None.
Zero.
In fact, it provides a downward force. Every time.
....and you are making the point that when you are breathing in, you are
not SUCKING air at all. It's atmospheric pressure on your chest that
inspires the air. Wow! Who would have guessed? :-)
Brian W
  #44
Old November 30th 09, 04:42 PM posted to rec.aviation.homebuilt
Alan Baker
upper
Brian W
Yup.
Brian W
No one understands "suction" to actually mean a pulling force. Not since
they tried to pump water out of mines and discovered that they could
only "pull" it a certain number of feet, but no further.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
  #45
Old November 30th 09, 04:46 PM posted to rec.aviation.homebuilt
et
On Nov 29, 11:19*pm, Alan Baker wrote:
*cavelamb wrote:
Alan Baker wrote:
*"Morgans" wrote:
"Alan Baker" wrote
Anyone who thinks that the pressure of a fluid on a surface can act in
any direction but towards the surface is simply wrong.
I see. *You are not lookng at the wing as a system, but taking an
observation at one point only, without reguard to what is happening around
it.
Point made.
Nope.
lifting force.
None.
Zero.
Sorry, Alan, old boy, I find must disagree.
Disagree all you want, it won't make the upper surface of the wing
experience anything but a downward force.
In actuality, BOTH surfaces are below ambient pressure.
('splain why?)
Bernoulli.
But without that reduction of the pressure across the top curve of the wing,
the pressure below it can't do much at all, can it?
Which I never disagreed with.
But anyone who thinks the upper surface of the wing is experiencing
anything but a downward force is just sadly misinformed.
Alan Baker
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg- Hide quoted text -
- Show quoted text -
When I fly my Cheerokee I can detect a slight bulge in the upper
skin. For what it's worth.
Ed
  #46
Old November 30th 09, 04:53 PM posted to rec.aviation.homebuilt
Alan Baker
In article
*cavelamb wrote:
Alan Baker wrote:
*"Morgans" wrote:
in
around
it.
Point made.
Nope.
lifting force.
None.
Zero.
('splain why?)
Bernoulli.
wing,
Alan Baker
text -
Ed
Great. Do you think that is caused by the air above the skin pulling on
it?
Alan Baker
  #47
Old November 30th 09, 05:54 PM posted to rec.aviation.homebuilt
Brian Whatcott
Default Alan Baker Edict: No more Suction References (was visualizationof the lift distribution...)
Remember folks: no more talk of sucking soda through a straw!
Just suck it up!
Brian W :-)
  #48
Old November 30th 09, 08:51 PM posted to rec.aviation.homebuilt
et
On Nov 30, 8:53*am, Alan Baker wrote:
In article
*cavelamb wrote:
Alan Baker wrote:
*"Morgans" wrote:
in
around
it.
Point made.
Nope.
lifting force.
None.
Zero.
('splain why?)
Bernoulli.
wing,
Alan Baker
text -
skin. * For what it's worth.
Ed
it?
Alan Baker
Has to be a pressure differental I would think.
Ed
  #49
Old November 30th 09, 11:33 PM posted to rec.aviation.homebuilt
Alan Baker
In article
In article
*cavelamb wrote:
Alan Baker wrote:
*"Morgans" wrote:
act
in
happening
around
it.
Point made.
Nope.
*no*
lifting force.
None.
Zero.
('splain why?)
Bernoulli.
wing,
Alan Baker
text -
Ed
it?
Alan Baker
text -
Ed
Then you understand reality.
Alan Baker
  #50
Old November 30th 09, 11:34 PM posted to rec.aviation.homebuilt
Alan Baker
Default Alan Baker Edict: No more Suction References (was visualization of the lift distribution...)
Just suck it up!
Brian W :-)
Talk about it all you want...
....just don't pretend that there is a force acting upward on the surface
of the liquid inside the straw...
....because you'll be wrong.
Alan Baker
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
