visualisation of the lift distribution over a wing
Old December 2nd 09, 07:38 PM posted to rec.aviation.homebuilt
Alan Baker
Default visualisation of the lift distribution over a wing
brian whatcott wrote:
Alan Baker wrote:
/snip/
I have never noticed the fabric lifting on my wings, however I have
seen the fuel siphon out of a wing tank due to an improperly applied
fuel cap.
And greater pressure in the tank than outside of it...
Right, but in a sealed metal tank, is all that other fuel PUSHING the
fuel out of the vent since air can't PULL it out?
First of all, the tank is not completely sealed. If it were, the fuel
pumps would soon have difficult pumping the fuel out of the tank.
So, yes, the greater pressure inside the tank is pushing the fuel out.
Hmmm...it probably goes more like this: there's a 100 mph? wind past an
open port, with some venturi effect certainly, but plenty of
turbulence. If you beat up the surface with a gusty blow, it gets
wavelets which can lap the filler and blow out the fuel.
Which reminds me of that trick that suction pumps use for high lift.
As you probably know, if you pump down even to a vacuum above a tall
3water pipe, the water will not rise more than about 30 ft - (if it were
mercury, it would not rise more than 29.92 inches on a standard day,
remember?)
Anyway, the mine engineers who want to pump up water MORE than 30 ft,
say 40 ft without placing a force pump at the foot of the head, blow air
into the water column which has the effect of reducing the density of
the mix. If the relative density goes down from 1.0 to 0.5 they COULD
pump up to nearer 60 ft. How bout that!
Brian W
How about it? It still doesn't change the physical reality that air
doesn't *pull* on the wings.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
  #82
Old December 3rd 09, 01:07 AM posted to rec.aviation.homebuilt
Brian Whatcott
Alan Baker wrote:
Jim Logajan wrote:
Any change in pressure is *by definition* a change in the number of
particles in the fluid that are impacting the surface.
That assertion is incorrect. You are no dummy so I'm sure you'll correct it
when you realize the errors.
Sorry, but it's not. Pressure is created by particle collisions.
Hmmm...looks like Jim expected too much from you: the kinetic theory of
gases has it that pressure may be computed from the temperature AND the
density of gases... that is to say, by retaining the SAME molar quantity
of gas, and raising its temperature (which translates to a higher
velocity), the pressure is increased P.V = R.t and all that....
Put it another way: each "hotter" molecule reverses direction at a
surface with greater force.
Brian W
  #83
Old December 3rd 09, 01:11 AM posted to rec.aviation.homebuilt
Brian Whatcott
fuel cap.
/snip/
You're still singing the last hymn, Alan.
We are now discussing how an open tank, with a 100 mph wind blowing over
its top, can lose its fuel over the top. Do you think the tank has
GREATER pressure due to the venturi effect of the airflow?
Brian W
  #84
Old December 3rd 09, 01:14 AM posted to rec.aviation.homebuilt
Alan Baker
it
Brian W
I'm perfectly aware of that, but that hardly matters for the scope of
our discussion of the effect of pressure on a wing. The point I'm making
is that all else being equal, more collisions means higher pressure and
fewer means lower pressure, but that pressure is therefore always a
positive value that acts toward the surface to which it is applied.
It is *never* acting away from that surface; i.e. "pulling".
That is the only reason I mentioned a vacuum, because it is a situation
in which there is *by definition* zero absolute pressure.
Alan Baker
  #85
Old December 3rd 09, 01:19 AM posted to rec.aviation.homebuilt
Alan Baker
fuel cap.
/snip/
No. I think that the venturi effect lowers the pressure below the
pressure that already exists in the tank. Contrary to what the PP wrote,
a tank cannot be sealed if you are to pump fuel out of it. If it were
the pump would have to work against a rising pressure difference as it
removed fuel from the tank. Hence we know the tanks pressure must be
allowed to equalize.
If the pressure over an open filler is less than that in the tank -- and
assuming the filler is not simply pulling from the air/fuel vapor
mixture, then it will pull fuel from the tank if the pressure difference
is sufficient to lift the fuel the from its level in the tank to the
level of the open filler.
But it is being *pushed* out by higher pressure inside, not pulled.
Alan Baker
  #86
Old December 3rd 09, 12:54 PM posted to rec.aviation.homebuilt
Brian Whatcott
Alan Baker wrote:
/snip/
it when you realize the errors.
Brian W
I'm perfectly aware of that...
It took me too long to realise the problem: you have a problem with
saying: "Oh yes, I got it worng."
People who WON'T do that in technical discussions qualify as people who
are just happy to stir up heated debate.
I am going to leave this thread now: wrasslin' with pigs gets the
hands jest too soiled...
Brian W
  #87
Old December 3rd 09, 06:34 PM posted to rec.aviation.homebuilt
Alan Baker
Alan Baker wrote:
/snip/
Brian W
I didn't get anything wrong.
I am and was perfectly aware of the fact that the temperature of a gas
indicates a different average speed for the gas molecules and thus a
different momentum when the strike a surface.
I agree. What of it.
You can go.
Alan Baker
  #88
Old December 4th 09, 03:01 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Alan Baker wrote:
/snip/
Brian W
You can go.
I feel the same as Brian.
This had not been a discussion as much as a troll.
OF BLOODY COURSE, the high pressure area under the wing pushes up.
So what.
It couldn't possibly do that without the reduction of pressure on the top.
That's where all the magic is.
And you, sir, are a bloody bore.
So now, please also dismiss me.
  #89
Old December 4th 09, 03:26 AM posted to rec.aviation.homebuilt
Alan Baker
cavelamb wrote:
Alan Baker wrote:
/snip/
correct
Brian W
You can go.
So what.
Look, I started out to clarify the point for those who have the wrong
perception of the situation...
....and it turned that there were such people.
I explicitly stated that if the OP meant that the low pressure above the
wing is responsible for two thirds of the pressure *difference* then he
was on solid ground (while allowing as how I didn't know what the
precise figures actually were).
Ever since then, types like you have been coming in and saying "IT
DOESN'T MATTER", when very clearly (because there are people who don't
understand the situation) it does.
It's like the downwash argument. You can say "IT DOESN'T MATTER", when
people argue that the air behind an aircraft is not deflected downward,
but it *does* matter. Having an accurate understanding of the physical
processes of flight matters.
Alan Baker
  #90
Old December 4th 09, 05:16 AM posted to rec.aviation.homebuilt
Beryl[_3_]
It isn't really deflected downward, not for long anyway. It's churning
in a torus. Like a smoke ring.
Pressure Distribution Charts sisu1a Soaring 0 September 21st 08 05:53 PM
Soundwaves Boost Wing Lift [email protected] Home Built 30 September 5th 05 10:21 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
Alternator load distribution in a Baron Viperdoc Owning 7 December 9th 03 10:27 PM
