#31
On Dec 8, 4:24*pm, Tim Taylor wrote:
On Dec 8, 5:18*pm, Mike wrote: On Dec 8, 4:50*pm, David wrote: I does look somewhat like the Edelweiss, except that the Edelweiss was a standard class, no flaps. *Perhaps this was an alien (i.e. Roswell type) modification. David Martin Also the Edelweiss was a mostly wood ship, except for the ailerons. My first guess was the Edelweiss also, then I saw the flaps and notieced that it was not shredded wood on the wings, but paint and filler. The C34 I believe had flaps http://www.flickr.com/photos/10983301@N06/2954270888/ Yes but I think the C34 also had top and bottom spoilers. And unless my eyes are being fooled thre are no spoilers in the photos Mike linked to. See http://www.airport-data.com/aircraft/photo/209736.html Darryl |
#32
On 8 Dec, 20:10, Darryl Ramm wrote:
On Dec 8, 4:24*pm, Tim Taylor wrote: On Dec 8, 5:18*pm, Mike wrote: On Dec 8, 4:50*pm, David wrote: Could it be a Prue? http://www.sailplanedirectory.com/Pl....cfm?PlaneID=1 |
#33
At our airfield we have three "V" Schreder designs (a HP-11, a HP-14 and several HP-18s undergoing restoration.) I own the HP-14.
I am sure the tailcone and ruddervators are from a Schreder kit. Notice that the tail-feathers control surfaces are hinged on the top at 50% of the chord leaving a large gap on the bottom side. The mass balance design is the same. Finally ruddervators fold for trailering and can fold past the vertical like all Schreder "V" tails. (The past the vertical fold causes problems with which I am all too familiar.) Are there any other "V" tail glider designs which match the above description? If so, do the wing have large span flaps and no spoilers? As I stated before, there is nothing HP about the wing spar, or steel tube structure associated with the landing gear. There are several one-of-a-kind gliders, some still flying, that were built using parts purchased from Dick Schreder. I think this wreck is one of them. BTW, I think Bob K knows more then he is telling us. Wayne http://tinyurl.com/N990-6F "Darryl Ramm" wrote in message ... On Dec 8, 3:22 pm, Junior Team 2007 wrote: Come on guys, it's got to be an Edelweiss! http://www.probertencyclopaedia.com/...0Edelweiss.jpg Mike Westbrook I don't think it is an Edelweiss, flaps and no top surface spoilers being one issue as others have mentioned. But if it is French, I will be outraged and will demand to know what the SSA is doing about its 3,000 hour inspection! Darryl |
#34
I think so too. Bob's earlier speculation on the wing construction matches precisely what I observed. Tell us, please Bob. |
#35
On Dec 8, 5:38*pm, Scott Lamont wrote:
On 8 Dec, 20:10, Darryl Ramm wrote: On Dec 8, 4:24*pm, Tim Taylor wrote: On Dec 8, 5:18*pm, Mike wrote: On Dec 8, 4:50*pm, David wrote: Could it be a Prue? *http://www.sailplanedirectory.com/Pl....cfm?PlaneID=1 The Prue 215 was short winged at 12.2m, this looks longer. The nose is different, the wing is lower mounted than the Prue 215 (got to imagine a turtledeck added to the wreck), the tail boom looks thinner than a 215 etc. In additon to the sailplane directory, we can also now make use of the Soaring Magazine archives John Leibacher and Kathleen Taylor put together. See http://soaringweb.org/Soaring_Index/...962_issue.html for a cover photo, and in a separate issue an article and back cover illustration of a Prue 215. Darryl |
#36
Well, someone knows the story, because it was stripped clean after it
was totaled. It does like HP'ish to me so my guess is an early HP? |
#37
On Dec 8, 8:52*pm, tstock wrote:
Well, someone knows the story, because it was stripped clean after it was totaled. It does like HP'ish to me so my guess is an early HP? I do not think it is an early HP. The fuse is very low profile for a 60's HP. The v-tails also seem too high aspect ratio. |
#38
I did have a tape measure with me as my son and I were out measuring
desert strips at the time. The span is 15m. The wing skin is fiberglass. It had solid foam in the forward D tube and the spar was riveted aluminum. HP gliders and Irv Prue gliders were metal, metal and metal. At this point, I am pretty confident that Wayne Paul and Bob Kuykendall are the guys that are on the right track here. I think the tail cone and tail feathers are borrowed from an HP and it is a one of glider. Bob knew the internal construction without seeing it. Is Bob the builder of this glider? If so, he is likely feeling sad to see her now in such a state. |
#39
![]() "tstock" wrote in message ... Well, someone knows the story, because it was stripped clean after it was totaled. It does like HP'ish to me so my guess is an early HP? Don't think so. HP-7,8,9 (http://www.soaridaho.com/Schreder/history.html#HP7) HP-10 (http://www.soaridaho.com/Schreder/HP-10/N25D/N25D.htm) HP-11 (http://www.soaridaho.com/Schreder/HP-11/N14GP.htm) HP-12 (http://www.soaridaho.com/Schreder/HP...1DR/N841DR.htm) HP-13 (http://www.soaridaho.com/Schreder/HP.../N2YB/N2YB.htm) HP-14 (http://www.soaridaho.com/Schreder/HP...13G/N1113G.htm) mine has extended ruddervators. (http://www.soaridaho.com/Schreder/HP...P-14_6F_5a.jpg) HP-15 (http://www.sailplanedirectory.com/Pl...fm?planeID=163) HP-16 (http://www.soaridaho.com/Schreder/HP...rst_Flight.htm) HP-17 (http://www.soaridaho.com/Schreder/history.html#HP17) HP-18 (http://www.soaridaho.com/Schreder/HP-18/N5568/N5568.htm) Wayne http://tinyurl.com/N990-6F |
#40
Possibly Oldshaw O-2 or its variant? I saw one at Soaring Museum at
Moriarty. http://picasaweb.google.com/gens2000...34513734628274 http://picasaweb.google.com/gens2000...34528476336658 -Gen |
IO-540 mystery | Paul Tomblin | Owning | 27 | August 31st 07 08:59 PM |
glider transport chicago - arizona | BB | Soaring | 0 | February 11th 07 12:01 AM |
Mystery Propellor | M Pengelly | Restoration | 7 | November 1st 04 08:42 PM |
GPS Mystery | tony roberts | Owning | 5 | February 3rd 04 12:54 AM |
Eta crashed | Erich Kohlenberger | Soaring | 33 | October 6th 03 11:56 AM |
