Gel coat removal - water sanding vs. straight line sanding
Old February 6th 10, 05:54 PM posted to rec.aviation.soaring
LS3 Pilot
Default Gel coat removal - water sanding vs. straight line sanding
Trying to do some work on my ship. Does anyone that reads this forum
have experience in the best way to remove gelcoat? I've got an area
thats too big to hand sand on the wing that needs some work. A friend
suggested I buy a water sander that continuously feeds water to the
sander (similar to a pneumatic powered straight line sander).
What's the best tools to safely and effectively removing the old gel?
Old February 6th 10, 09:18 PM posted to rec.aviation.soaring
On Feb 6, 12:54*pm, LS3 Pilot wrote:
Trying to do some work on my ship. *Does anyone that reads this forum
have experience in the best way to remove gelcoat? *I've got an area
thats too big to hand sand on the wing that needs some work. *A friend
Hand sanding with 100 grit.
You didn't want to hear that.
UH
JJ Sinclair
The last one I did using an 8" grinder turning 1800 rpm with a 40 grit
sanding disc! Be careful to stop just short of hitting any glass, then
finish up with 60 Grit and a small 6"hand disk grinder.
Does that answer your question?
:) JJ
Old February 6th 10, 09:56 PM posted to rec.aviation.soaring
LS3 Pilot
Well, specifically, what about this one?
http://www.google.com/products/catal...822&sa=title#p
Old February 6th 10, 10:23 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
http://www.google.com/products/catal...en&show=dd&cid...
Sand dry. Use a vacuum of some sort if you want to try and keep dust
in the area to a minimum. Didn't want to hear that either, did you?
Steve
Old February 6th 10, 10:31 PM posted to rec.aviation.soaring
Craig[_2_]
in the area to a minimum. *Didn't want to hear that either, did you?
Steve
One of more than a few reasons I don't do it for a living anymore.
Craig
Old February 6th 10, 10:54 PM posted to rec.aviation.soaring
UH
I gave you the smart ass answer first. We use 5 inch Porter Cable
orbital with soft pad and Mirka 80 grit discs.
We put in a dust collection system because it's pretty darned messy.
Start slow and take your time. Impatience leads to lots more work.
Good luck
Uh
Old February 7th 10, 12:57 AM posted to rec.aviation.soaring
bildan
There's a thing called an "air file" auto body shops use.
http://www.pivco.net/index.php?main_...238#googlebase
It's a linear oscillating compressed air driven sander about 18" long
and 2.25" inches wide. I've been told they work pretty well with 80
grit and they have less chance of digging into the fiberglass than a
rotary grinder. Since it's air driven, I suppose you could safely use
wet sanding and avoid the dust.
Old February 7th 10, 01:23 AM posted to rec.aviation.soaring
Bob Kuykendall
Sawzall
Old February 7th 10, 01:33 AM posted to rec.aviation.soaring
T8
Junior club members.
Sanding of plywood before epoxy [email protected] Home Built 6 July 15th 08 01:21 PM
Sanding or Waxing - PIK 20 Question culverflyer Soaring 22 September 22nd 05 09:01 PM
Advice on sanding fibreglass [email protected] Home Built 12 April 28th 05 10:39 PM
Sanding composites [email protected] Home Built 12 January 31st 05 06:47 AM
Fear of Sanding Stuart Grant Soaring 7 January 17th 05 05:28 PM
